Compute the Wronskian & Simplify
In summary: The Wronskian is not identically zero for any value of $k$ except $3$.In summary, to compute the Wronskian and simplify, the two given functions must be (infinitely) differentiable and the Wronskian must not be identically zero. This shows linear independence of the functions. The only exception is when $k = 3$, where the Wronskian becomes zero. Therefore, for all other values of $k$, the functions are linearly independent.
shamieh
539
Compute the Wronskian and simplify.
So the first part was easy
a) $y_1 = t^2 + 1$ , $y_2 = 3t^2 + k$
=$6t-2kt$
b) for what values of $k$ are the functions linearly independant
so would I just solve for $k$? I'm confused
What exactly does linearly independant mean?
Ok so I figured out it is Linearly Independant because after I took the Wronskian I didn't get 0. But for what values of $k$ ? Would it just be as long as $k > 0$ ?
You can use the Wronskian to show linear independence as follows: if the Wronskian is not identically zero, and the two functions are (infinitely) differentiable, then the two functions are linearly independent. For what values of $k$ does this happen?
as long as $k$ > 0 ?
the two functions are inifnitely differentiable
because $y_1 = t^2 + 1 $
'= 2t + 1
'' = 2
''' = 0
''''=0
...etc
and $y_2 = 3t^2 + k$
' = 6t
'' = 6
''' = 0
etc
So would it be all values as long as $k \ne 3$
wait so how about
t(6-2k) when k = 3 then t(6-6) = 0?
so would it be k can be any value except when k is 3?
shamieh said:
wait so how about
You got it!
FAQ: Compute the Wronskian & Simplify
What is the Wronskian?
The Wronskian is a mathematical concept used in differential equations to determine if a set of functions are linearly independent or dependent. It is represented by a determinant and can be used to solve various problems in differential equations.
How do I compute the Wronskian?
To compute the Wronskian, you will need to first determine the functions that are involved. Then, write them in a matrix format and calculate the determinant. There are also online calculators and computer programs available that can help you compute the Wronskian quickly and accurately.
What is the significance of the Wronskian?
The Wronskian is significant because it helps us determine if a set of functions are linearly independent or dependent. This information is important in solving certain problems in differential equations, and it also has applications in other areas of mathematics and physics.
Can the Wronskian be used to simplify expressions?
Yes, the Wronskian can often be simplified by using properties of determinants, such as row operations and factorization. This can make solving problems involving the Wronskian easier and more efficient.
Are there any limitations to using the Wronskian?
The Wronskian has limitations in its application, as it can only be used for linear differential equations. It also may not always provide a definitive answer for the linear independence of functions, as certain cases may require further analysis.
