Computer Communication Theory & Information Theory - A name change?
In summary, the discussion revolves around the potential renaming of the fields of Computer Communication Theory and Information Theory to better reflect their evolving nature and relevance in modern technology. The debate highlights the importance of adapting terminologies to encompass new advances and interdisciplinary connections while considering the historical significance of the existing names.
Lou Arnold
TL;DR Summary
Communications Theory Renamed to Information Theory? And a good book for Communication channel characterizations?
Retired computer engineer here. I have a professor's unpublished notes, back to 1974 entitled "Computer Communication Theory" that containing a great deal of probability, random variables, and Markov chain sections as well as old Bell Systems Journal notes about hardware and protocols. Has this been renamed to Information Theory and cover roughly the same mathematics?
Also, I'm looking for a book about Communications Theory (graduate level) that is largely mathematical covering channel characterizations, etc. Any one know of a good one?
Thanks,
Lou
Here are a couple textbooks that I used in EE grad school -- I don't know if they are what you are looking for.
https://www.amazon.com/Principles-C...n-Wozencraft/dp/0881335541/?tag=pfamazon01-20
https://www.amazon.com/Introduction...ell-Stremler/dp/0201184982/?tag=pfamazon01-20
Are you looking for foundational stuff like Claude Shannon or more like communication protocols.
Years ago I took a communications protocols course at work. The instructor had a lot of stories surrounding the design and implementation of various popular communications protocols.
1) an systems guy had a lot of terminals that didn't seem to connect to his modems. He figured out that if a particular line was high then they would start to work so his solution was to add a 9v battery to each terminal to make the line high so they would work. The problem he now had was changing out the batteries every few months on a hundred or so terminals. The instructor chuckled and said he didn't have the heart to tell the hapless engineer that there would have been a dip switch on the terminal so make that line high as an option.
2) Another protocol designer assigned character values to strings of zeros and ones based on usage. As an example the letters ETAON are the five most commonly used in English words so he'd make E=01 T=011 A=0111 ... Sadly his protocol took way longer to send streams of data. It was later tracked down to rubouts being sent and he had given them the code 01111111111.... 127 ones. The rubouts were spacng between the terminal screens being sent over the comm line and they were by far the most common character.
3) The last story I recall was a means to trick a bank into sending money by hacking into their network and slowly sending messages with broken CRC checks. Initially they would be flagged as bad and rejected but as more and more were sent and getting rejected an operator might step in and let them pass thinking there's an issue with the CRC bits and bingo you slip in your money transfer to a swiss bank and you'e made for life until the authorities catch up and you're in for life.
His theme was to each the protocol and then show its weaknesses with these humorous stories and anecdotes.
I wish I could remember his name but it was in the early 1980s when I was getting acquainted with the Honeywell Level 6 mini-computer when mini meant the size of several large book shelves stacked together.
FAQ: Computer Communication Theory & Information Theory - A name change?
What is the difference between Computer Communication Theory and Information Theory?
Computer Communication Theory focuses on the transmission of data over communication channels, including protocols, network architecture, and error detection. In contrast, Information Theory is concerned with the quantification, storage, and communication of information, primarily dealing with concepts like entropy, data compression, and coding theory.
Why is there a proposal to change the name from Computer Communication Theory to Information Theory?
The proposed name change aims to reflect the broader scope of the field, emphasizing the foundational principles of information theory that underpin modern communication systems. It seeks to unify the disciplines and highlight the importance of information processing in both theoretical and practical applications.
What are the implications of this name change for researchers and practitioners?
The name change could lead to a greater interdisciplinary collaboration, encouraging researchers to integrate concepts from both fields. It may also enhance the visibility of information theory principles in computer science curricula, leading to a more comprehensive understanding of communication systems among students and professionals.
Will the content of the field change with the name change?
While the name change itself does not alter the fundamental theories or practices, it may influence the direction of research and education. Scholars might place greater emphasis on the theoretical aspects of information processing, potentially leading to new methodologies and applications in computer communication.
How does this name change align with current trends in technology?
This name change aligns with the increasing convergence of communication and information technologies, such as cloud computing, big data, and machine learning. As these fields evolve, a unified approach that incorporates both communication and information theory will be essential for addressing complex challenges in data transmission and processing.
