Computing capacitance in the general case
In summary: I suggest you edit your answer, because some things are irrelevant: it is known that the charges are all located at the surface of the conductor. Furthermore, it is also known that the potentials are U1 and U2 at the surfaces of the conductors.
coquelicot
299
67
This may well be a textbook question, or even a duplicate in this forum, but I have no idea of how to compute the capacitance between two conductors in the general case: all the computations I saw in textbooks make heavy use of symmetries to compute the capacitance, e.g. capacitance between two infinite planes separated by a fixed distance d, two concentric spheres etc. But in the general case, even if there is no solution in terms of elementary functions, how to attack this problem whenever symmetries are not available ? if only a simulation is possible, what is the exact method to obtain the simulation ?
As a practical example, I would like to compute (or simulate) the exact capacitance between two rectangular planes at fixed distance d, separated by a dielectric ε (but without approximating the planes by infinite planes).
Note: The following points are know and need not be explained here:
* The potential inside and at the surfaces of the the conductors is constant
* The field inside the conductors is null
* The field at the surfaces of the conductors is normal to the surfaces
* Gauss law
EDIT: In the following link, the author says that it has searched for a formula unsuccessfully, and that he finally derived it himself (but does not explain how):
http://chemandy.com/calculators/rectangular-capacitor-calculator.htm
Please, see the comments of the author there.
coquelicot said:
I think this formula is based on the approximation by infinite planes. Even if it is not, this does not explain the general case.
well if it doesn't, then maybe you could try google yourself
davenn, I think you are missing the point. I've added an "edit" to my question.
I'm afraid for arbitrary shaped conductors you would have to find the exact surface charge distribution and electric field everywhere as a byproduct of computing C.
Here is one way of doing it numerically (first that comes to mind, haven't tried it myself but there is no reason why it shouldn't work):
1. define evenly distributed points xi on a surface of each conductor. Assume point charge qi at each point xi.
2. define arbitrary reference points xj inside the conductors, at sufficient distance from the surface.
3. Compute contribution kij of each surface point i to the Coulomb potential at each reference point j: [itex] k_{ij}=\frac{1}{4 \pi \epsilon_0} \frac{1}{|x_i-x_j|}[/itex], [itex]U_j = \sum_i k_{ij} q_i + C[/itex]
4. Add boundary conditions: Set potential of reference points to 0V and 1V, set sum of surface charges to -Q and Q respectively.
6. Solve the resulting linear system for Q
Likes coquelicot
Thank you Delta kilo: a finite element method is what I expected. It is indeed simpler than what I thought. Nevertheless, from the theoretical point of view, I'm not yet entirely satisfied:
1) there lacks a theoretical proof that there is a unique solution, for given potentials U1 and U2 at the surfaces of each conductor, and
2) By what theoretical mean can you assert that the sum of the surface charges are respectively Q and -Q ? Furthermore, are you sure that arbitrary charge Q is consistent with arbitrary potentials U1 and U2: (suppose for example that Q is very very small, ant that the potentials are 0V and 1V).
Note: I suggest you edit your answer, because some things are irrelevant: it is known that the charges are all located at the surface of the conductors, so the points x_j are unnecessary. I would would also replace the term distributed points by "division of the surface centred at points x_i", and U_i by U1 and U2, since the potential at the surface of each conductor is constant (as you did in step 4). Finally, there are as many unknown q_i as equations, so it is conceivable that it is only necessary to fix arbitrary potentials U1 and U2 to obtain the density of charge q_i.
Well, since we are approximating smooth surface charge distribution with a finite number of point charges, we cannot expect the potential to be exactly the same everywhere inside the conductor, but with sufficient number of points it should be possible to get it reasonably flat. For a given number of point charges on the surface we can always add more and more points inside the conductor until the system is well and truly overdetermined and then solve it in least squares sense. Since it is a linear system, there will be a unique solution minimizing the residuals.
It is an arbitrary choice. I just want the capacitor to be electrically neutral when seen from a distance. There is a (mutual) capacitance between conductors and there is also self-capacitance of individual conductors. Under normal circumstances, the former is orders of magnitude larger, so it shouldn't matter.
Q is the unknown variable we want to find (so we can divide it by voltage to get the capacitance). Sorry I didn't make it clear. Also, when I mentioned 0V and 1V, these are defined up to a constant C. A better way of doing it would be to introduce two more variables U1 and U2 and then set U2 = U1 + 1V.
As I said above, we are trying to approximate a potential induced by a smooth distribution of surface charges by that of a cloud of points. It works fine when the distance from the point of interest to a surface is at least several times greater than distance between charges (which is what I meant by "sufficient distance"). As you get closer, the potential becomes more and more bumpy, until it completely breaks down on the surface itself (it shoots up to infinity at x_i). That is the reason to choose reference points inside the conductor and not on a surface.
Delta Kilo said:
Well, since we are approximating smooth surface charge etc.
Thank you again for answering me Delta Kilo. For the convenience of the future reader, I reformulate here your ideas (tell me if this is OK):
At the macroscopic scale, it is well known that the charges are distributed on the surfaces of the conductors. The distribution of the charges at the surfaces of the two conductors can be approximated by continuous surface densities [itex]\rho_1[/itex] and [itex]\rho_2[/itex], that we have to determine.
To this end,
1) divide the surfaces of the conductors into a large number of small patches [itex]P_i[/itex] , with central point [itex]x_i[/itex], say [itex]n[/itex] patches;
2) Assume the density is approximately constant inside each patch [itex]P_i[/itex] , and denote it by [itex]q_i[/itex];
3) Compute [itex]\alpha_{i,j} = {1\over 4\pi\varepsilon_0||x_i-x_j ||}[/itex] for every [itex]i,j[/itex]. At equilibrium, the potentials at each surface must be constant because if it were not, there would be a current flow. Denote the potentials at surfaces 1 and 2 by [itex]U_1[/itex] and [itex]U_2[/itex] resp. Fix them to arbitrarily values, like 0V and 1V;
3) for every [itex]i[/itex] such that [itex]x_i[/itex] belongs to surface 1, there holds [itex]U_1 = \sum_{j\not= i} \alpha_{i,j} q_j [/itex], and for every [itex]i[/itex] such that [itex]x_i[/itex] belongs to surface 2, [itex]U_2 = \sum_{j\not = i} \alpha_{i,j} q_j [/itex]. This gives [itex]n[/itex] linear equation in [itex]n[/itex] unknowns [itex]q_i[/itex], and solving this system leads to the values of [itex]q_i[/itex] for the chosen potentials [itex]U_1[/itex] and [itex]U_2[/itex];
4) finally, let [itex]Q_1 = \sum_{surface~1} q_i [/itex] and [itex]Q_2 = \sum_{surface~2} q_i [/itex]. There should hold (approximately, since the surface density has been approximated by patches) [itex]Q_1 = - Q_2 [/itex] (is this exact? why?), and the capacitance between the two conductors is [itex]C = |Q_1/(U_2-U_1)|[/itex]. It is known that the capacitance is independent of the choice of the potentials [itex]U_1[/itex] and [itex]U_2[/itex] (the electrostatic field depend only on the ddp [itex]U_2-U_1[/itex], hence also the distribution of charges, and multiplying the ddp by a scalar multiplies the distribution of charges by the same scalar, hence leaves C invariant).
Related to Computing capacitance in the general case
1. How is capacitance calculated?
Capacitance is calculated by dividing the charge stored on one of the conductors by the potential difference between the two conductors. This is represented by the formula C = Q/V, where C is capacitance, Q is charge, and V is potential difference.
2. What is the unit of capacitance?
The unit of capacitance is farad (F). However, in practical applications, smaller units such as microfarads (μF) and picofarads (pF) are commonly used.
3. How does the shape and size of a capacitor affect its capacitance?
The capacitance of a capacitor is directly proportional to the surface area of the conductors and inversely proportional to the distance between them. This means that a larger surface area and a smaller distance between the conductors will result in a higher capacitance.
4. What is the difference between series and parallel capacitors?
In series capacitors, the total capacitance is less than the individual capacitance of each capacitor due to the decrease in effective surface area. In parallel capacitors, the total capacitance is the sum of the individual capacitances because the effective surface area increases.
5. How does the dielectric material between the conductors affect capacitance?
The dielectric material between the conductors affects capacitance by increasing it due to its ability to store more charge. The dielectric constant or relative permittivity of the material determines the extent of this effect.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
