Computing competitive equilibrium( plus consumption rivalry)
Your Name]In summary, the conversation discusses two agents, Pascal and Friedman, in a pure exchange economy with two goods and no free disposal. They have different utility functions and preferences, and their consumption of one good affects the other's utility. The problem involves solving for their demands, finding the competitive equilibrium price and allocations, and analyzing the effect of a parameter b on the equilibrium. The standard procedure of solving an optimization problem by forming a Lagrangian can be used, along with the technique of substitution. The equilibrium price is determined by the ratio of the agents' marginal utilities of good 2, and changing the parameter b will affect the equilibrium price and allocations.
Dostre
Consider two agents (Pascal and Friedman) in a pure exchange economy with two goods and no free disposal. Pascal has a preference relation give by the utility function
$$u^P(x_1^P,x_2^P)=a\ln (x_1^P)+(1-a)\ln(x_2^P-bx_2^F)$$
while Friedman's preferences are
$$u^F(x_1^F,x_2^F)=a\ln (x_1^F)+(1-a)\ln(x_2^F-bx_2^p)$$
Here 0<a<1 and 0<b<1. Additionally the consumption of good 2 of one agent enters in the utility of the other agent.
Pascal's endownment is $$\vec{w} ^P=(w_1,w_2)\geq 0$$ while Friedman's is $$\vec{w} ^F=(y_1,y_2)\geq 0$$ Let P be the price of good two in terms of good one. Both utility functions are subject to the constraint $$x_1^i+px_2^i\leq w_1^i+pw_2^i$$
1. Compute each other's demands of these goods.
2. Find the competitive equilibrium price and allocations.
3. How are the equilibrium price and consumption allocations affected by he parameter b?
I think I should treat those utility functions separately. When solving the optimization problem of maximizing their utility I should form a Lagrangian. But this problem is weird because I have the consumption of good 2 ([itex]x_{2}^i[/itex]) of one agent int he utility of the other agent. This confuses me and I do not know if a Lagrangian would somewhat different due to this stipulation. Any hints on solving all parts of this problem please.
Thank you for your post. Let me try to help you with your questions.
1. To compute each other's demands, you can follow the standard procedure of solving the optimization problem by forming a Lagrangian and taking the first-order conditions. However, as you mentioned, the presence of the other agent's consumption in the utility function complicates things a bit. In this case, you can use a technique called "substitution," where you substitute the budget constraint into the utility function and then solve the resulting unconstrained optimization problem. This should give you the demand functions for both agents.
2. To find the competitive equilibrium price and allocations, you need to solve for the price that equates the demand of one agent with the supply of the other agent. In this case, since there are only two goods and two agents, the price will be determined by the ratio of the two agents' marginal utilities of good 2. Once you have the equilibrium price, you can plug it into the demand functions to get the equilibrium allocations.
3. Finally, to analyze the effect of the parameter b on the equilibrium price and consumption allocations, you can start by considering the impact on each agent's demand function. How does changing b affect their demand for good 2? This, in turn, will affect the equilibrium price and allocations. For example, if b increases, the demand for good 2 will decrease, which will decrease the equilibrium price and allocations of good 2. On the other hand, if b decreases, the opposite will happen.
I hope this helps. Good luck with your analysis!
Related to Computing competitive equilibrium( plus consumption rivalry)
1. What is computing competitive equilibrium?
Computing competitive equilibrium, also known as the general equilibrium theory, is a mathematical model used to analyze the market economy. It aims to determine the prices and quantities of goods and services that will result in an optimal allocation of resources, where supply equals demand.
2. How is competitive equilibrium computed?
To compute competitive equilibrium, economists use a system of equations and inequalities that represent the demand and supply of goods and services. These equations are then solved simultaneously to find the equilibrium prices and quantities. This process is often done using computer algorithms and mathematical models.
3. What is consumption rivalry in competitive equilibrium?
Consumption rivalry refers to the competition between individuals for the consumption of a good or service. In a competitive equilibrium, the prices of goods and services are determined by the level of rivalry for that particular good. Higher rivalry leads to higher prices, while lower rivalry leads to lower prices.
4. How does consumption rivalry affect the equilibrium outcome?
The level of consumption rivalry directly impacts the equilibrium outcome. In a highly competitive market, where there is intense rivalry for goods and services, the equilibrium prices will be higher and the quantity demanded will be lower. In contrast, in a less competitive market, where there is less rivalry, the equilibrium prices will be lower and the quantity demanded will be higher.
5. What are the assumptions of computing competitive equilibrium?
There are several assumptions that must be made in order to use the competitive equilibrium model. These include perfect information, rationality of buyers and sellers, perfect competition, and no externalities or market failures. Additionally, the model assumes that individuals act independently and make decisions based on their own self-interest.
  • General Math
17K
  • Math Proof Training and Practice
21K
