Computing harmonic oscillator propagator via path integral
In summary, the problem involves showing that a certain function G(q2,q1;t) can be written in terms of a normalization factor and a known function S. This is done by applying a given identity and using a previously known case. The second part involves finding the eigenvectors and eigenvalues of the operator A in order to calculate G in full.
naele
202
Show that
[tex]
G(q_2,q_1;t)=\mathcal{N}\frac{e^{iS_{lc}}}{\sqrt{\det A}}
[/tex]
where [itex]\mathcal{N}[/itex] is a normalization factor independent of q1, q2, t, and w. Using the known case of w=0, write a formula for G such that there is no unknown normalization factor.
I previously showed that
[tex]
G(q_2,q_1;t)=e^{iS_{cl}/\hbar}\int \mathcal{D}xe^{iS[x]/\hbar}
[/tex]
verified that [itex](x_1,x_2)=\int_0^Tx_1(t)x_2(t)dt[/itex] was a scalar product over the real vector space of trajectories x(t) and showed that [itex]S[x]=-\frac{m}{2}(x,A\cdot x)[/itex] where
[tex]
A=\frac{d^2}{dt^2}+\omega^2
[/tex]
and showed that A was self-adjoint. We're also given the following identity
[tex]
\int\! dX\, e^{-\frac{1}{2}(X,A\cdot X)+(J,X)}=\frac{(2\pi)^{n/2}}{\sqrt{\det A}}e^{\frac{1}{2}(J,A^{-1}\cdot J)}
[/tex]
where n is the dimension of the of the vector space.
If I just blindly apply the identity that's given to us, I get confused about the exponent of the prefactor. I know that it should simply be a square root, but when I apply the identity (with J=0) I get N/2 ie
[tex]
G(q_2,q_1;t)=\left(\frac{2\hbar\pi}{im}\right)^{N/2}\frac{e^{iS_{cl}}}{\sqrt{\det A}}
[/tex]
I could collect all that into the normalization factor and get the desired expression anyway but that makes me a little uncomfortable.
As far as the 2nd part I'm not really sure if the problem is asking me to deduce the harmonic oscillator propagator from the free-particle or whatever. I'm confused because in the next question we're asked to find the eigenvectors and eigenvalues of A, and then from there calculate G. At least that part seems really straightforward, especially using the Fourier series method from Feynman & Hibbs.
Thanks for any help.
I think that part of your confusion is that you can't just "blindly apply" the identity
[tex]
[/tex]
This is an integral over a vector [tex]X[/tex] of scalars, whereas the propagator involves an integral over paths. You can make a connection between the two by defining a lattice, but then the normalization factor is only defined up to the limit in which the lattice spacing goes to zero and [tex]N\rightarrow\infty[/tex]. I believe the 2nd part of the problem involves either defining this limit or using some previously known result to rewrite it. I'm not sure what "known case" you've covered so far though.
Yea, I was thinking of doing something like this
[tex]
\int\!\mathcal{D}x\, e^{iS[x]/\hbar}&=\lim_{N\to\infty} B^{(N-1)/2}\int\,\mathcal{D}x\,\exp \left[-\frac{m}{2i\epsilon\hbar}\sum_{i=0}^{N-1}[(x_{i+1}-x_i)^2-\epsilon^2\omega^2x_i^2] \right]
[/tex]
where B is an unknown prefactor to be determined. I can then introduce a a vector [itex]X=(x_1,\cdots,x_{N-1})[/itex]. The only problem I see is a discretized version of A, but I might just wave my hands over that. Then, if I apply the identity I can collect everything into one factor independent of everything.
As for the second part, the only other known case we've seen is the free particle. So I suppose if I naively introduce the same pre-factor instead of B like I have up there, and apply the same procedure I can get the harmonic oscillator result (but with undetermined det A).
Then the next question after that asks to determine the eigenvalues of A so getting the full expression should come right out, I hope.
FAQ: Computing harmonic oscillator propagator via path integral
1. What is a harmonic oscillator?
A harmonic oscillator is a type of physical system that exhibits periodic motion, meaning it moves back and forth in a regular pattern. It is characterized by a restoring force that is proportional to the displacement from its equilibrium position.
2. What is a path integral?
A path integral is a mathematical tool used to calculate the probability of a particle moving from one point to another in space. It takes into account all possible paths that the particle can take and assigns a probability to each path based on the action of the system.
3. How is the harmonic oscillator propagator computed via path integral?
The harmonic oscillator propagator is computed by summing over all possible paths that the particle can take from its initial position to its final position. This is done by integrating the path integral over all possible configurations of the system.
4. What is the significance of computing the harmonic oscillator propagator via path integral?
Computing the harmonic oscillator propagator via path integral allows for the calculation of quantum mechanical observables in a system with a harmonic potential. This method is particularly useful in quantum field theory and statistical physics.
5. What are some applications of computing the harmonic oscillator propagator via path integral?
Some applications of computing the harmonic oscillator propagator via path integral include studying the behavior of particles in quantum field theory, understanding the properties of quantum systems in statistical mechanics, and analyzing the dynamics of molecules in quantum chemistry.
