Computing Polyakov Loops in Lattice QCD (Basic Question)
In summary: PhysicsForumsIn summary, the conversation discusses the extraction of physical parameters from lattice QCD simulations by using the Polyakov loop correlator. The equation -log <P(m) P(n) ^\dagger> \propto V(|m-n|) is used to extract the potential between quark and anti-quark by considering the distance between the two loops. The issue with the logarithm is addressed, where it is clarified that it should be taken as the natural logarithm, which is defined for complex numbers. Both the SU(3) and U(1) cases are briefly discussed, and recommendations for further reading are provided.
Jaydeep
Hi PhysicsForums,
I have a pretty basic question about extracting physical parameters from lattice QCD simulations. As described in "Quantum Chromodynamics on the Lattice" by Gattringer and Lang, it seems we should be able to extract the static quark/anti-quark potential by considering the behavior of the Polyakov loop correlator as a function of the distance between loops included in the correlator. Specifically, they give the equation in chapter 3,
[tex] - \log < P(m) P(n) ^\dagger> \propto V(|m-n|), [/tex] where [itex] P(m), V(a) [/itex] are the Polyakov loop from position [itex] m [/itex] and the potential across distance [itex] a [/itex], respectively. It just seems that the Polyakov loop, being a product of traces of group elements, will in general be complex, so the log is throwing me off. Are we to take both real part/absolute value prior to taking the logarithm, or am I missing something? I'm interested both in the SU(3) context, as well as the simpler U(1) case. Apologies for the simple question, but would appreciate any advice/references. Thank you!
Hi there,
Thank you for your question. It's great to see interest in lattice QCD simulations and their applications in extracting physical parameters. To address your question, I'll provide a brief explanation of the equation you mentioned and then discuss the issue with the logarithm.
The equation you mentioned is indeed a key tool in extracting the static quark/anti-quark potential in lattice QCD simulations. The Polyakov loop, denoted as P(m), is a measure of the average color charge of a quark at position m in the lattice. By considering the behavior of the Polyakov loop correlator, <P(m)P(n)^\dagger>, as a function of the distance between the two loops, we can extract the potential between the quark and anti-quark at positions m and n, respectively.
Now, onto your question about the logarithm. You are correct in pointing out that the Polyakov loop, being a product of traces of group elements, can be complex. However, the logarithm in this equation is meant to be taken as the natural logarithm, which is defined for complex numbers. Therefore, you do not need to take the real part or absolute value prior to taking the logarithm.
In the SU(3) context, the Polyakov loop will be complex and the logarithm will give a complex number as well. But when taking the absolute value, we get a real number which is proportional to the potential between the quark and anti-quark. In the simpler U(1) case, the Polyakov loop is real and the logarithm will give a real number directly proportional to the potential.
I hope this helps clarify your question. For further reading on this topic, I recommend checking out "Quantum Chromodynamics on the Lattice" by Gattringer and Lang, as well as "Lattice Gauge Theories: An Introduction" by DeGrand and DeTar.
Best of luck with your research. Keep asking questions and exploring the fascinating world of lattice QCD simulations.
Related to Computing Polyakov Loops in Lattice QCD (Basic Question)
1. What is lattice QCD and how is it used to study quark-gluon interactions?
Lattice QCD (Quantum Chromodynamics) is a computational approach to studying the strong force, which is responsible for interactions between quarks and gluons. It uses a discrete space-time lattice to simulate the behavior of quarks and gluons, allowing for calculations of their properties and interactions.
2. What is a Polyakov loop in lattice QCD and how is it computed?
In lattice QCD, a Polyakov loop is a measure of the average color charge of a quark-antiquark pair that are separated in the temporal direction. It is computed by summing over the product of color charges along a closed loop in the temporal direction of the lattice.
3. What are the challenges in computing Polyakov loops in lattice QCD?
One challenge in computing Polyakov loops is dealing with the fermion sign problem, which arises due to the presence of complex numbers in the fermion determinant. Another challenge is the large computational resources required to simulate the lattice and perform the necessary calculations.
4. What are some applications of computing Polyakov loops in lattice QCD?
Polyakov loops in lattice QCD can provide valuable insights into the properties of quark-gluon plasma, which is a state of matter that is thought to have existed in the early universe and is also created in high-energy particle collisions. They can also be used to study the behavior of quarks and gluons in extreme conditions, such as in the presence of strong magnetic fields.
5. How do the results from computing Polyakov loops in lattice QCD compare to experimental results?
Currently, there is a good agreement between the results from lattice QCD calculations and experimental results for the properties of quark-gluon plasma. However, due to the complexities of the calculations, there are still some uncertainties and further research is needed to improve the accuracy of the results.
