Computing The Arbitrary-Precision Nth Root Of Positive (X) In PHP
In summary: These operations can be used to perform fancy computations that are difficult to do in most other programming languages used on the WWW. However, for higher roots such as the cube root or sixth root, a custom function must be created using the basic operations. The resulting value of the next approximation can be substituted as the new value and the process is repeated until the desired level of precision is reached. This is based on Newton's method for finding roots.
Jay1
PHP has some powerful arbitrary-precision (BC or binary calculator) arithmetic functions which seem to be greatly underused and only consist of the basic arithmetic operations, a square root function, a mod function and an integer power function.
However, those basic operations can be used to perform some very fancy computations much harder to do in most other languages used on the WWW.
There is an arbitrary-precision square root function, but what if we wanted the arbitrary-precision cube root or sixth root, etc.?
For roots higher than the square root, we have to create a custom function built from the basic operations.
Given:
a = Current approximation to Nth root of (x)
N = Root for which to solve (2,3,4 ...)
x = Argument for which to find the Nth root
b = Next generation approximation derived from current generation (a)
Given any initial starting approximation (a) to the Nth root of (x),
the next approximation (b) may be computed by the general formula:
$$b = \frac{\frac{x}{a^{N-1}} + a\cdot(N-1)}{N}$$
The resulting value of (b) is then substituted as the new value of (a) and the process is repeated, each time giving a closer and closer approximation (b) of the Nth root of (x) until it reaches whatever level of precision (decimals) we require.
Below is an arbitrary-precision PHP function designed to compute the Nth root of positive argument (x) to any given number of decimals based on the above recursion formula.
The argument (x) should be given in the form of a numerical string, such as "12.345"
Code:
   function bcNth_Root_Of_x ($N, $x, $NumDecimals=16)
   $a = sprintf("%1.16f", pow($x, 1/$N));
   $n = $N - 1;
   $d = $NumDecimals;
   $D = $d + 8;
   for ($i=1;  $i <= 100;   $i++)
   $b = bcdiv(bcadd(bcmul($n,$a,$D), bcdiv($x, bcpow($a,$n,$D),$D),$D),$N,$D);
   if (bccomp($a,$b,$D) == 0) {break;} else {$a = $b;}
   return rtrim(rtrim(bcadd($b, "0." . str_repeat(0,$d) . "5", $d), "0"), ".");
EXAMPLE:
Below is a small, ready-to-run PHP example program calling the function to compute the 5th root of 100, rounded to 75 decimals.
Code:
<?php
$N = 5;
$x = "100";
$decimals = 75;
print bcNth_Root_Of_x ($N, $x, $decimals);
 $n = $N - 1;
 $d = $NumDecimals;
 $D = $d + 8;
The returned result should be:
Code:
2.511886431509580111085032067799327394158518100782475428679888420908243247724
Here is a commented listing of the above function.
Code:
   This function computes the arbitrary-precision Nth root of a given
   numerical string (x), rounded at any specified number of decimals.
   ARGUMENTS:
   N = Root = Integer 2, 3, 4, ..., etc.
   x = Numerical argument string for which we seek the Nth root.
   NumDecimals = Number of decimals at which to round off the result
                 if exact resolution is not possible.
   ERRORS:
   NO special error checking is done.
// Compute first seed approximation.
   $n = $N - 1;
   $d = $NumDecimals;
// Add 8 extra decimals precision as rounding fuzz buffer
   $D = $d + 8;
// Initialize iteration control loop.  The limit is set to 100 to prevent
// an infinite loop lockup, which would hang the function.  This limit
// should be far more than sufficient and never likely to be reached.
// Compute next generation approximation (b) to Nth root of (x) from the
// current generation approximation (a).
// If (a == b) to desired precision, then done, (b) is root.
// Else current (b) becomes the new (a) for the next cycle.
// Round off root to (d) decimals, then trim redundant zeros and/or decimal.
If you happen to be a PHP math coder, like me, this Nth root function could be part of a library of custom arbitrary-precision PHP math functions.
Some example test values are:
Code:
Cube (3) root of 10 to 32 decimals:
= 2.15443469003188372175929356651935
7th root of 18435.57209 to 50 decimals:
= 4.0679866312376590401866108430333983477514
4th root of 4646545.65686847759871677987 to 80 decimals:
= 46.42827543473103234672521339464313742938263307554617373866851061590663732382853491
etc.
Cheers and tally-ho
P.S.
The formula given above is based on Newton's method for finding roots.
Ref:
https://en.wikipedia.org/wiki/Newton's_method:)
Mathematics news on Phys.org
Given:
Code:
   $n = $N - 1;
   $d = $NumDecimals;
   $D = $d + 8;
EXAMPLE:
Code:
<?php
$N = 5;
$x = "100";
$decimals = 75;
 $n = $N - 1;
 $d = $NumDecimals;
 $D = $d + 8;
Code:
Code:
   ARGUMENTS:
   ERRORS:
   $n = $N - 1;
   $d = $NumDecimals;
   $D = $d + 8;
Code:
etc.
Cheers and tally-ho
P.S.
Ref:
please help me code C# with algorthrm this
FAQ: Computing The Arbitrary-Precision Nth Root Of Positive (X) In PHP
How do I compute the arbitrary-precision nth root of a positive number in PHP?
To compute the arbitrary-precision nth root of a positive number in PHP, you can use the bcpow function. This function takes in three parameters: the base number (x), the power (1/n), and the scale (number of decimal places). For example, to compute the 5th root of 100 with a scale of 2 decimal places, you would use bcpow(100, 0.2, 2).
What is arbitrary-precision and why is it important when computing the nth root?
Arbitrary-precision refers to the ability to store and manipulate numbers with an unlimited number of digits after the decimal point. This is important when computing the nth root because it allows for a more accurate result, especially when dealing with large numbers.
Can I compute the nth root of negative numbers in PHP?
No, the bcpow function in PHP only allows for computing the nth root of positive numbers. If you need to compute the nth root of a negative number, you can use the bcdiv function to first find the absolute value of the number, compute the nth root, and then multiply the result by -1.
How can I change the precision or number of decimal places when computing the nth root?
You can change the precision or number of decimal places when computing the nth root by adjusting the scale parameter in the bcpow function. The scale refers to the number of decimal places after the decimal point in the result. For example, a scale of 2 would give you a result with 2 decimal places.
Are there any limitations to using the bcpow function for computing the nth root?
Yes, there are some limitations to using the bcpow function for computing the nth root. This function may not always return an exact result due to the limitations of computer precision. Additionally, the nth root of large numbers may take a longer time to compute and may require a higher scale for a more accurate result.
