Computing The Arbitrary-Precision Value Of N-Factorial In PHP
In summary, the general integer factorial can be expressed by the equation N! = ∏x=1^N x = 1 * 2 * 3 * ... * N. This means that N-factorial is the sequential product of all integers from 1 to N. A PHP function is provided for computing arbitrary-precision factorial, but caution should be used with small arguments as they can result in very large numbers. An example program calling the function to compute 52 factorial is also shown. The odds of guessing every card correctly from a shuffled deck of 52 playing cards would be 1 in 80.658 unvigintillion. A factorial calculator is also provided for easy and accurate computation of factorials. Overall, factor
Jay1
The general integer factorial can be expressed by the equation:
$$N! = \prod_{x~=~1}^N {x} = {1 \cdot 2 \cdot 3 \cdot ~~...~~ \cdot N}$$
This simply means that N-factorial is the sequential product of all integers from 1 to N.
Below is a simple PHP function to compute the arbitrary-precision factorial of any positive integer. This function should be used with caution, since small arguments can result in very large factorial values in the hundreds and even thousands of digits. For example, 250 factorial equates to this 493-digit number:
250! =
32328562609091077323208145520243684709948437176737806667479424271128237475551112
09488817915371028199450928507353189432926730931712808990822791030279071281921676
52724018926473321804118626100683292536513367893908956993571353017504051317876007
72479330654023390061648255522488194365725860573992226412548329822048491377217766
50641276858807153128978777672951913990844377478702589172973255150283241787320658
18848206247858265980884882554880000000000000000000000000000000000000000000000000
0000000000000
The function has a built-in safety limit of 9999, but this can easily be changed. However, it is important to point out that factorials of larger values can take several seconds of computation time, depending on the server speed and there is the possibility of a script time-out if the argument is too large.
Code:
   function bcN_Factorial ($N=0)
   if (!is_numeric($N) or $N < 0 or $N > 9999) {return FALSE;}
   $n = bcadd($N, 0);
   $P=1;  for ($i=1;  $i <= $n;  $i++) {$P = bcmul($P, $i);}
   return $P;
Below is an example program calling the function to compute 52 factorial (52!):
Code:
<?php
   $N = 52;
   print "$N factorial =<br>" . bcN_Factorial ($N);
   $n = bcadd($N, 0);
   return $P;
The returned value should be:
Code:
52 factorial =
80658175170943878571660636856403766975289505440883277824000000000000
The above function is useful when you want the EXACT factorial value, far beyond the reach of the standard 16-digit arithmetic, which would only return it as something like: 52! = 8.0658175170944E+67, rather than the full 68-digit value.
If you were to guess at the value of every card drawn at random without replacement from a shuffled standard deck of 52 playing cards, the odds of you guessing every card correctly would be 1 to 52 factorial, or about 1 chance in 80.658 unvigintillion. In other words, a snowball's chance in you-know-where!
Or, as Mr. Spock would say:
Exactly 1 chance out of
80 unvigintillion
658 vigintillion
175 novemdecillion
170 octodecillion
943 septendecillion
878 sexdecillion
571 quindecillion
660 quattuordecillion
636 tredecillion
856 duodecillion
403 undecillion
766 decillion
975 nonillion
289 octillion
505 septillion
440 sextillion
883 quintillion
277 quadrillion
824 trillion
of success.Here's an on-line factorial calculator built around the above function:
Factorial Calculator - PHP Science Labs
Mathematics news on Phys.org
Hello there,
Thank you for sharing this information and the PHP function for computing the arbitrary-precision factorial of any positive integer. I agree with you that factorials can result in very large numbers, especially for larger values, and it is important to use caution when working with them.
I appreciate the example you provided with the odds of guessing every card correctly from a shuffled deck of 52 playing cards. It really puts into perspective just how large the factorial of 52 is.
I also find the on-line factorial calculator you shared to be a useful tool for those who may need to calculate factorials quickly and accurately.
Thank you for contributing to the forum and providing valuable information on the general integer factorial equation. Keep up the great work in the field of science!
Related to Computing The Arbitrary-Precision Value Of N-Factorial In PHP
1. What is "Computing The Arbitrary-Precision Value Of N-Factorial In PHP"?
"Computing The Arbitrary-Precision Value Of N-Factorial In PHP" is a process of using PHP programming language to calculate the factorial of a given number with arbitrary precision, meaning that it can handle large numbers without rounding errors.
2. Why is it important to calculate the factorial of a large number with arbitrary precision?
When working with large numbers, traditional floating-point calculations can result in rounding errors, which can significantly affect the accuracy of the result. By computing the factorial with arbitrary precision, we can get a more accurate and precise value.
3. How does PHP handle arbitrary precision calculations?
PHP has a built-in library called "BCMath" that supports arbitrary precision calculations. It allows us to perform mathematical operations on numbers with a higher number of digits without losing precision.
4. Can you provide an example of computing the arbitrary-precision value of n-factorial in PHP?
Sure, let's say we want to calculate the factorial of 100. We can use the bcdiv() function to compute the result with arbitrary precision. The code would look like this: echo bcdiv(bc_fact(100), 1, 0); The bc_fact() function calculates the factorial of 100, and the bcdiv() function divides it by 1 with 0 decimal places, giving us the precise result of 100 factorial.
5. Are there any limitations to computing the arbitrary-precision value of n-factorial in PHP?
While PHP's BCMath library can handle large numbers, it does have some limitations. It can only handle numbers with a maximum of 2147483647 digits, which may not be enough for extremely large factorials. Additionally, the performance of BCMath operations may be slower compared to traditional floating-point calculations.
  • General Math
17K
