Computing the derivative of an exponential function
In summary: Just leaving a message so you know that I have not forgotten about this thread.Sorry completely forgot about this thread. I will come back here. Just leaving a message so you know that I have not forgotten about this thread.
member 731016
I am trying to understand why as h approach's zero ##\frac{b^h - 1}{h} = f'(0)##. Dose anybody please know of a good way to explain this? Many thanks!
Pls see below
That is the definition of the derivative of ##f(x) = b^x## at ##x=0##. Notice that they do not say there that the limit and the derivative exist. In fact, the last sentence says "if the exponential function ##f(x) = b^x## is differentiable" (emphasis mine). So there is still something to prove.
Likes member 731016
Thank you for your reply @FactChecker !
How dose ##\lim_{x \rightarrow h} {\frac {b^h - 1} {h}} = f'(0)##?
Many thanks!
You have formula wrong. I think that ##\lim_{h \rightarrow 0} {\frac {f( x+h) - f(x)}{h}} = f'(x)## is a common definition of the derivative. Is that your definition of the derivative? Now plug in ##x=0##.
Likes member 731016
Callumnc1 said:
Homework Statement:: I am trying to understand why as h approach's zero ##\frac{b^h - 1}{h} = f'(0)##. Dose anybody please know of a good way to explain this? Many thanks!
Relevant Equations:: Pls see below
First: The word is "Please", not Pls .
Also, you've been misspelling the word "Does". It is not "Dose".
So, you're back to posting a very detailed explanation of some math or physics topic, then asking some question regarding a detail which has been very well explained.
The best answer I can give as to why ##\displaystyle f'(0)=\lim_{h\to 0} \dfrac{b^h - 1}{h} ## is because ##\displaystyle b^0 = 1## .
Likes malawi_glenn, member 731016 and Mark44
Thank you for your reply @FactChecker!
If I plug in x = 0, to the definition of derivative (the expression that you mentioned, I get
##\frac{0}{0} = undefined ##. I am not sure where to go from here?
Many thanks!
  • Sad
Likes malawi_glenn
Thank you for your reply @SammyS!
But plugging in h = 0 gives ##\frac{0}{0} = undefined##. How can ##f'(0)## be undefined since it is not a number?
Many thanks!
  • Sad
Likes malawi_glenn
Many thanks!
Actually, you went too far. You asked this:
Plug in ##x=0## to get the definition ##f'(0) =\lim_{h \rightarrow 0} \frac{b^{0+h} - b^0}{h} = \lim_{h \rightarrow 0}\frac {b^h - 1}{h}##.
Notice that this is the definition, it does not say that the limits actually exist or the value of the limit. You are trying to prove that, which is a step too far for now. I assume that is proven somewhere else.
Likes member 731016 and malawi_glenn
Many thanks!
That's not how to evaluate this limit.
You are reading something into what is stated which is not there.
Likes member 731016
h should not be zero, should only be close to zero.
Try this, set b =2.72 and evalute that fraction at h = 0.001 and for h = 10^-6 and for h = 10^-9
You should see a pattern now.
Repeat the above but for b = 2.7183
Wha do you find?
Likes member 731016
FAQ: Computing the derivative of an exponential function
What is the derivative of the exponential function \( e^x \)?
The derivative of the exponential function \( e^x \) is \( e^x \). This is because the exponential function \( e^x \) is unique in that it is its own derivative.
How do you find the derivative of \( a^x \), where \( a \) is a constant?
To find the derivative of \( a^x \), where \( a \) is a constant, you use the formula \( \frac{d}{dx} a^x = a^x \ln(a) \). This incorporates the natural logarithm of the base \( a \).
What is the derivative of \( e^{u(x)} \), where \( u(x) \) is a function of \( x \)?
The derivative of \( e^{u(x)} \) is found using the chain rule. It is \( \frac{d}{dx} e^{u(x)} = e^{u(x)} \cdot u'(x) \), where \( u'(x) \) is the derivative of \( u(x) \).
How do you compute the derivative of \( a^{u(x)} \), where \( a \) is a constant and \( u(x) \) is a function of \( x \)?
To compute the derivative of \( a^{u(x)} \), you use the chain rule combined with the formula for the derivative of \( a^x \). The result is \( \frac{d}{dx} a^{u(x)} = a^{u(x)} \ln(a) \cdot u'(x) \), where \( u'(x) \) is the derivative of \( u(x) \).
Why is the natural logarithm used in the derivatives of exponential functions with bases other than \( e \)?
The natural logarithm is used because it simplifies the differentiation process. When differentiating \( a^x \), the natural logarithm \( \ln(a) \) appears naturally from the chain rule applied to the exponential function and the properties of logarithms, making it a crucial component in the derivative formula.
