Computing the Limit of a Power Series
In summary, a power series is a representation of a function as an infinite sum of terms, typically in the form of a<sup>n</sup>. Computing a power series involves finding the sum of all the terms, often using algorithms or computer programs. The limit of a power series is the value approached as the number of terms increases, and it is important in areas such as calculus and statistics. Methods such as the Ratio Test, Root Test, and Comparison Test are used to compute the limit, while tests like the Integral Test and Alternating Series Test help determine the convergence or divergence of the series.
Julio1
69
Compute $\displaystyle\lim_{n\to +\infty}\dfrac{1^p+2^p+3^p+\cdots +n^p}{n^{p+1}}.$
Hello!, how it can calculate this limit? Thanks :)
I am not sure what techniques you are familiar with for calculating limits, but this seems to be a job for Stolz-Cesaro theorem :
$$\begin{aligned}\lim_{n \to \infty} \frac{1^p + 2^p + \cdots + n^p}{n^{p+1}} &= \lim_{n \to \infty} \frac{\left ( 1^p + 2^p + \cdots + (n+1)^p \right ) - \left( 1^p + 2^p + \cdots + n^p \right)}{(n+1)^{p+1} - n^{p+1}} \\ &= \lim_{n \to \infty} \frac{(n+1)^p}{(n+1)^{p+1} - n^{p+1}} \\ & = \lim_{n \to \infty} \frac{(n+1)^p}{(p+1) \cdot n^p + \mathcal{O}(n^{p-1})} \\ &= \lim_{n \to \infty} \frac{1}{p+1} \cdot \frac{1}{1+o(1)} = \boxed{\dfrac1{p+1}}\end{aligned}$$
Where $\mathcal{O}$ and $o$ are asymptotic notations. I am guessing that there might be some elementary way to do to this, so am interested in other solutions.
I'm assuming $p$ is a real number different from $-1$. The limit, which can be written
\(\displaystyle \lim_{n\to +\infty} \frac{1}{n}\sum_{k = 1}^n \left(\frac{k}{n}\right)^p,\)
is the limit of a sequence of Riemann sums for the function $f(x) = x^p$ over the interval $[0,1]$. So it has value
\(\displaystyle \int_0^1 x^p \, dx.\)
Compute the integral to get the result.
FAQ: Computing the Limit of a Power Series
What is a power series and how is it computed?
A power series is a mathematical series that represents a function as an infinite sum of terms. It takes the form of an, where a is a constant and n is the term number. Computing a power series involves finding the sum of all the terms in the series, typically using mathematical algorithms or computer programs.
What is the limit of a power series?
The limit of a power series is the value that the series approaches as the number of terms approaches infinity. It can also be thought of as the value at which the function represented by the series becomes stable and does not change significantly as more terms are added.
What is the importance of computing the limit of a power series?
Computing the limit of a power series is important in many areas of mathematics, including calculus, differential equations, and statistics. It allows us to approximate complicated functions and make predictions about their behavior, as well as evaluate the accuracy of our calculations.
What methods are used to compute the limit of a power series?
There are several methods for computing the limit of a power series, including the Ratio Test, the Root Test, and the Comparison Test. These tests involve comparing the terms of the series to known functions or constants, and determining whether the series converges or diverges.
How do you determine the convergence or divergence of a power series?
To determine the convergence or divergence of a power series, you can use the aforementioned tests or other techniques such as the Integral Test or the Alternating Series Test. These tests help determine whether the series approaches a finite limit or diverges to infinity.
