Concavity and the First Derivative Test.
In summary, the author is trying to find if a function is concave up or down on an interval but is having difficulty because of a discontinuity at the left endpoint.
Calcatron
Hello everyone. I'm going to start off by saying that this post may seem like a problem that could be solved with intuition, but I'm a bit of a purist and I like to assure that my ideas are backed up with strong mathematical evidence. I'm studying the Calculus textbook by Thomas and Finney. It's a great book but I'm a bit puzzled at the use of a Calculus theorem. The question is how do we find if a function is concave upward, or concave downward on an interval.
The First Derivative Test for Increasing and Decreasing functions tells us that given that a function is continuous on [a, b] and differentiable on (a, b) then we can apply the following conditionals:
If f' > 0 at each point of (a, b), then f increases on [a, b]
If f' < 0 at each point of (a, b), then f decreases on [a, b]
Here's the precise definition for increasing decreasing functions (you can skip if you already know.)
Let f be a function defined on an interval I and let x1 and x2 be any two points in I.
1. f increases on I if x1 < x2 ==> f(x1) < f(x2)
2. f decreases on I if x1 < x2 ==> f(x2) < f(x1)
So what if we're trying to find whether a function f, differentiable over it's entire domain, is concave up on an interval (x, y). We would take the first derivative, make sure that it's continuous on [x, y] and differentiable on (x, y), then we would see if the second derivative is positive over this interval. At this point we could apply the The First Derivative Test to say that f' increases on the interval [x, y].
But herein lies the problem with certain functions. Suppose we take the first derivative f', but f' is undefined at x, which would imply a discontinuity at it's left endpoint. Then what would we do, could we still apply the The First Derivative Test to the second derivative to see if the first derivative is increasing? I find this difficult to do with mathematical integrity, if you look at the law of Increasing Decreasing functions, it says it only applies if the first function (the one we're trying to find is increasing or decreasing) is continuous on [x, y] and differentiable on (x, y), but our 'first function' the first derivative, tells us that it is not continuous at it's left endpoint!
This observation was based on my analysis of an example where the book assumed everything was 'OKAY' at this point, but I wonder if the book was correct in that assumption and how it was correct if it was.
Any help would be appreciated!
What happens at an endpoint has nothing to do with whether f is concave up or down in the interior of the interval which is what is asked. There is no such thing as being "concave up" or "concave down" at an individual point.
Thank you for the help :)
FAQ: Concavity and the First Derivative Test.
1. What is concavity and why is it important in calculus?
Concavity is a measure of the curvature of a function. In calculus, it is important because it allows us to determine whether a function is increasing or decreasing at a given point and to identify the presence of extrema (maximum and minimum points) on a graph.
2. How is concavity related to the first derivative test?
The first derivative test is a method used to determine whether a critical point on a graph is a maximum, minimum, or point of inflection. It involves analyzing the concavity of the function at that point. A point with a positive first derivative and a concave down graph will be a local maximum, while a point with a negative first derivative and a concave up graph will be a local minimum.
3. Can a function have more than one point of inflection?
Yes, a function can have multiple points of inflection. These are points where the concavity of the graph changes from concave up to concave down or vice versa. They occur when the second derivative of the function is equal to zero.
4. How do you find the concavity of a function?
To find the concavity of a function, you need to take the second derivative of the function and evaluate it at a given point. If the second derivative is positive, the function is concave up at that point. If the second derivative is negative, the function is concave down at that point.
5. Are there any limitations to using the first derivative test to find extrema?
Yes, the first derivative test only works for continuous functions. In addition, it can only identify local extrema and cannot determine whether a point is an absolute maximum or minimum. Also, the first derivative test may not work for functions with sharp corners or cusps, as these points do not have a well-defined slope.
