Concentation of Citric Acid in Fruit Juice
In summary, the juice substance is Tang and the solution of juice is prepared by dissolving 4.00 grams of crystals in 100.0 mL of solution. A solution of juice is then titrated using a given solution of sodium hydroxide. Phenolphthalein is used as an indicator. Trial # NaOH(aq) added (mL) Trial 1 3.31 Trial 2 3.18 Trial 3 3.27
Gurvir
This is a lab for Chemistry in grade 12.
I'll give some basic info I have.
Juice substance is Tang.
A solution of juice is prepared by dissolving 4.00 grams of crystals in 100.0 mL of solution. The juice solution is then titrated using a given solution of sodium hydroxide. Phenolphthalein is used as an indicator.
Here is my observations,
Trial 1 3.31
Trial 2 3.18
Trial 3 3.27
a) find mol/L of acid (I can do this but I cannot figure out the balanced equation)
b) how many grams of pure citric acid is in 100 g of tang (as a percent mass)
*Citric Acid is in your databook. Assume it loses 3 hydrogens.
My teacher said you shouldn't need the formula of the Tang
This is all I can think of, I do not know what it will turn into.
C3H5O(COOH)3(aq) + NaOH(aq) ==>
Borek said:
I think I understand it more now!
Let me see,
C3H5O(COOH)3(aq) + 3 NaOH(aq) ==> C3H5O(COO)3(aq) + 3 H2O(l) + 3 Na(s)
But there wasn't any solid from the reaction so I'm not sure where the Na(s) goes, does it just separate or get added onto one for the formula's?
No no, that was completely wrong. Your product will be a sodium salt!
buffer calculator, concentration calculator
pH calculator, stoichiometry calculator
What? Now I'm confused again, how does that work? Please tell me asap, I don't have long until I have to have this lab complete.
Why would it be NaCl? That doesn't make sense with anything. Cl wasn't even part of the experiment. It can't be created through thin air.
This makes sense to me, I don't know where NaCl would go.
A salt in chemistry isn't necessarily table salt (NaCl) but an ionic compound you get, along with water, after the neutralization of an acid and [STRIKE]salt[/STRIKE] base.
You wouldn't actually have C3H5O(COO)3(aq) and Na(s), but rather C3H5O(COO)33-(aq) and Na+(aq). The first one ionized since it lost H+ ions while the Na is still an Na+ ion. It could also be written as Na3C3H5O(COO)3(aq)
Bohrok already nicely explained what is going on. Salt name is sodium citrate.
Related to Concentation of Citric Acid in Fruit Juice
What is citric acid and why is it important to measure its concentration in fruit juice?
Citric acid is a natural compound found in many fruits, especially citrus fruits. It is important to measure its concentration in fruit juice because it affects the taste, acidity, and preservation of the juice. It is also used as a preservative and flavoring agent in many food and beverage products.
How is the concentration of citric acid in fruit juice typically measured?
The most common method for measuring the concentration of citric acid in fruit juice is through titration. This involves adding a known amount of a base solution to the juice until the citric acid is neutralized. The amount of base solution needed to neutralize the citric acid can then be used to calculate the concentration of citric acid in the juice.
What factors can affect the concentration of citric acid in fruit juice?
The concentration of citric acid in fruit juice can be affected by various factors such as the type of fruit, ripeness of the fruit, and storage conditions. The amount of citric acid can also vary depending on the variety of the fruit and the processing methods used to make the juice.
Why is it important to accurately measure the concentration of citric acid in fruit juice?
Accurate measurement of citric acid concentration is important for maintaining consistent flavor and quality of fruit juice. It is also necessary for ensuring the safety of the product, as high levels of citric acid can be harmful to some individuals. Additionally, accurate measurement allows for proper labeling and nutritional information for consumers.
What are some common sources of error when measuring the concentration of citric acid in fruit juice?
Some common sources of error when measuring citric acid concentration in fruit juice include inaccurate measurements, improper calibration of equipment, and contamination from other substances. It is also important to ensure that the sample being tested is representative of the entire batch of fruit juice.
38K
9K
9K
