Concentration of CO in Los Angeles Basin (matlab)
In summary: You are correct, the way you input the first argument in the ode45 function is not correct. You need to pass a function handle as the first argument, not the result of a function. So it should be:[T, C_CO] = ode45(@fHan,tSpan,C_COs);Also, note that your initial condition should be set as:C_CO0 = 2e-10; % lb mol/ft^3[T, C_CO] = ode45(@fHan,tSpan,C_CO0);And then you can plot the result as:plot(T,C_CO)xlabel('time (hours)');ylabel('CO Concentration (lb mol/ft^3)');title('CO Concentration vs.
gfd43tg
50
Smog begins to build up again immediately after a Santa Ana wind passes through the basin. The volumetric flow rate through the basin has dropped to ##1.67*10^{12} \frac{ft^3}{hr}##. Plot the concentration of carbon monoxide in the basin as a function of time for up to 72 hours and just after a Santa Ana wind. The initial concentration of CO is ##2*10^{-10} \frac{lb mol}{ft^3}##.
Given Information:
[tex]F_{CO,A} + F_{CO,S} - Q*C_{CO} = V\frac{dC_{CO}}{dt}[/tex]
[tex]F_{CO,A} = a + b sin(\pi*t/6)[/tex]
Where ##a = 20254815 \frac {lb mol}{hr}## and ##b = 0.5*a \frac {lb mol}{hr}##
[tex]V=4*10^{13} ft^3[/tex]
##Q=1.67*10^{13} \frac{ft^3}{hr}## for ##t \lt 72## and ##Q= 1.67*10^{12} \frac{ft^3}{hr}## for ##t \ge 72##
[tex]F_{CO,S}=C_{CO,S}*Q[/tex]
[tex]C_{CO,S} = 2*10^{-10} \frac{lb mol}{ft^3}[/tex]
Initial condition: [tex]C_{CO,t=0} = 2*10^{-10} \frac{lb mol}{ft^3}[/tex]
The crux of my problem is using ode45 to solve this differential equation
##F_{CO,A} + F_{CO,S} - Q*C_{CO} = V\frac{dC_{CO}}{dt}##
Hello, I want to give a little context for this problem so that you can understand what is going on. ##F_{CO,S}## is the flow rate of carbon monoxide entering the basin with a concentration of carbon monoxide ##C_{CO,s}## from the Santa Ana winds. ##F_{CO,A}## is the flow rate of carbon monoxide created by the cars driving inside the basin. ##Q*C_{CO}## is the flow rate of carbon monoxide exiting the basin, and ##C_{CO}## is changing with time because this is an unsteady state process. My problem is essentially solving the differential equation given in the problem
There are a couple of problems for me. First, there is the fact that ##Q## changes depending on if ##t < 72## or if ##t \ge 72##, and I'm not sure how to remedy this in the ode45 built in function. It is that ##Q## is a piecewise function of ##t##, as well as ##C_{CO} = f(t)##. Anyways, here is what I wrote so far. I know the function handle is supposed to have @(t,x) for a derivative ##\frac {dx}{dt}##, so I used in my function handle ##@(t,C_{CO})## for ##\frac {dC_{CO}}{dt}##. I keep getting the error Undefined function or variable 't'.
Code:
tSpan = [0 100]; % hr
if t < 72
    Q = 1.67e13; % ft^3/hr
else
    Q = 1.67e12; % ft^3/hr
end
C_COs = 2e-10; % lb mol/ft^3
F_COs = C_COs*Q; % lb mol/hr
a = 20254815; % lb mol/hr
b = 0.5*a; % lb mol/hr
F_COa = a + b*sin(pi*t/6); % lb mol/hr
Volume = 4e13; % ft^3
fHan = @(t,C_CO) (F_COa + F_COs - C_CO*Q)/Volume;
[T, C_CO] = ode45(fHan,tSpan,C_COs);
plot(T,C_CO)
title('CO Concentration vs. time');
What you should do is define your function using "function", such that you can incorporate the code defining Q
Code:
function dC_COdt = fHan (t, C_CO)
   if t < 72
   else
   end
   dC_COdt = (F_COa + F_COs - C_CO*Q)/Volume;
end
I'm confused how to make it work how you are describing
Code:
   if t < 72
       Q = @(t) 1.67e13; % ft^3/hr
   else
       Q = @(t) 1.67e12; % ft^3/hr
   end
   F_COs = @(t) C_COs*Q(t); % lb mol/hr
   F_COa = @(t) a + b*sin(pi*t/6); % lb mol/hr
   dC_COdt = @(t,C_CO)(F_COa(t) + F_COs(t) - C_CO*Q(t))/Volume;
end
[T, C_CO] = ode45(dC_COdt,tSpan,C_COs);
plot(T,C_CO)
Will not work, I get this error
Code:
fHan
Error: File: fHan.m Line: 21 Column: 1
This statement is not inside any function.
 (It follows the END that terminates the definition of the
 function "fHan".)
The file fHan.m should contain only the function, starting from the "function" statement and terminating with the "end".
This function will then be called by your main program. You still need to initialize the time and set the initial conditions. Note also that the function is called "fHan", not "dC_COdt". You simply need to remove some lines from your original posting, leaving:
Code:
plot(T,C_CO)
Something isn't right still, I just copy paste your code in #2
Code:
   if t < 72
   else
   end
end
Then make a separate script, and I put in arguments for fHan in my ode45 call,
Code:
[T, C_CO] = ode45(fHan(0,C_COs),tSpan,C_COs);
plot(T,C_CO)
But I get the error
Code:
Error using exist
The first input to exist must be a string.
Error in odearguments (line 60)
  if (exist(ode)==2)
Error in ode45 (line 114)
[neq, tspan, ntspan, next, t0, tfinal, tdir, y0, f0, odeArgs,
odeFcn, ...
the ode45 function doesn't seem to like the way I input the first argument
Code:
plot(T,C_CO)
Do not put arguments, it's ode45 which supplies the correct arguments.
What was missing in my post is to indicate that fHan is a function:
Code:
Likes 1 person
Thanks, ode45 arguments behave somewhat mysteriously to me. It just magically knows what to put it
Of course, there is nothing magical about it :smile:
It is basically a stepper method: starting from some initial conditions ##y_0## at ##x_0##, it uses a discrete form of the differential equation to find the solution ##y_1## at ##x_1##. For that, it needs to know the differential equations ##dy/dx##, which is what you supply. In the simplest case, you would have
y_1 = y_0 + (x_1 - x_0) \left. \frac{dy}{dx} \right|_{x_0}
which the algorithm can calculate by feeding ##x_0## and ##y_0## into your function.
In reality, the algorithm used by ode45, the Runge-Kutta-Fehlberg 4-5 method, is a more sophisticated version of the equation above with a smaller error. In addition, it can make an estimate of the error on ##y_1##, and it reduces it by subdividing the interval between ##x_0## and ##x_1## into smaller intervals, until a desired accuracy is obtained. For that, it will need to call your function many times to get ##dy/dx## at different values of ##x##. In the end, ode45 returns the values of ##x## for all the intermediate steps it took, along with the corresponding value of ##y(x)##.
A good introduction to the subject can be found in the book Numerical Recipes in C, see http://apps.nrbook.com/c/index.html, starting at page 707.
Related to Concentration of CO in Los Angeles Basin (matlab)
1. What is the current concentration of CO in the Los Angeles Basin?
The current concentration of CO in the Los Angeles Basin varies depending on the time of day and location. However, on average, it is around 0.5-1 parts per million (ppm).
2. How does the concentration of CO in the Los Angeles Basin compare to other cities?
The concentration of CO in the Los Angeles Basin is higher than many other cities due to its large population and heavy traffic. However, it has improved significantly over the years due to emissions control measures.
3. How is the concentration of CO in the Los Angeles Basin measured?
The concentration of CO in the Los Angeles Basin is typically measured using air quality sensors placed throughout the region. These sensors use advanced technology to detect and measure the levels of CO in the air.
4. What factors contribute to the concentration of CO in the Los Angeles Basin?
The main factors that contribute to the concentration of CO in the Los Angeles Basin are emissions from vehicles, power plants, and industrial facilities. Weather conditions, such as temperature and wind, can also impact the levels of CO in the air.
5. How can we reduce the concentration of CO in the Los Angeles Basin?
There are several ways to reduce the concentration of CO in the Los Angeles Basin. These include promoting the use of public transportation, implementing stricter emissions standards for vehicles, and investing in renewable energy sources. Additionally, individuals can reduce their own carbon footprint by carpooling, using energy-efficient appliances, and reducing their overall energy consumption.
  • Materials and Chemical Engineering
10K
