Concentration of evanescent/surface waves
In summary, at the interface between dielectrics and vacuum, there are evanescent waves present that can be generated by thermal fluctuation of charges inside the dielectric. These waves can be concentrated to a small spot using lenses, similar to how we concentrate other light waves. Surface polaritons, specifically surface phonon polaritons, can also greatly enhance energy transfer between two dielectric surfaces at nanoscale gaps. This phenomenon has been demonstrated experimentally and has potential applications in radiative cooling and thermophotovoltaic technologies. The momentum of these surface polaritons is higher than that of incident light from vacuum, and can be activated by evanescent waves from one object activating the SPP on the surface of the adjacent
Karthiksrao
68
Hello,
At the interface between dielectrics and vacuum, there is always evanescent waves present (you can consider them as being generated due to total internal reflection of electromagnetic waves being generated by thermal fluctuation of charges inside the dielectric). In some cases you can have surface waves like surface polaritons as well, which greatly enhances thermal energy transfer when you bring two dielectric surfaces closely apart (due to coupling of these waves)
I was wondering, if there is any way to concentrate these waves to a tiny spot.. Can we use lenses, the way we use to concentrate any other light wave ?
Thanks!
“Surface Phonon Polaritons Mediated Energy Transfer between Nanoscale Gaps”
Sheng Shen †, Arvind Narayanaswamy *‡ and Gang Chen *†
Nano Lett., 2009, 9 (8), pp 2909–2913
Abstract
"Surface phonon polaritons are electromagnetic waves that propagate along the interfaces of polar dielectrics and exhibit a large local-field enhancement near the interfaces at infrared frequencies. Theoretical calculations show that such surface waves can lead to breakdown of the Planck’s blackbody radiation law in the near field. Here, we experimentally demonstrate that surface phonon polaritons dramatically enhance energy transfer between two surfaces at small gaps by measuring radiation heat transfer between a microsphere and a flat surface down to 30 nm separation. The corresponding heat transfer coefficients at nanoscale gaps are 3 orders of magnitude larger than that of the blackbody radiation limit. The high energy flux can be exploited to develop new radiative cooling and thermophotovoltaic technologies."
http://pubs.acs.org/doi/abs/10.1021/nl901208v
Also, see this Wiki page:
"The Plasmonic Lens is intended to manipulate and focus stimulated surface plasmon polaritons (SPP), resulting in a focus beyond the limitations of conventional lenses."
Note the four references to papers, "Surface plasmon subwavelength optics”, "Focusing Surface Plasmons with a Plasmonic Lens", "Plasmonic Lenses", and "Plasmonic lens in the near field for high-speed nanolithography”.
http://en.wikipedia.org/wiki/Plasmonic_lens
Thanks for the reply. On a related note, I am aware that the momentum of surface polaritons are higher than that of incident light from vacuum and hence cannot be excited by just impinging light on a surface of a metal/dielectric.
In the paper you described above (SPP mediated energy transfer between nanoscale gaps), how are these SPPs activated ? Is it the evanescent waves from one object activating the SPP on the surface of the adjacent object or is it something else that I'm missing ? If it is indeed so, then the momentum of evanescent wave is limited by (\omega*n/c) where 'n' is the refractive index. So why is it that as the gap becomes smaller and smaller, higher modes (with higher momentum) start contributing more and more to the energy transfer?
Related to Concentration of evanescent/surface waves
1. What are evanescent/surface waves?
Evanescent waves, also known as surface waves, are a type of electromagnetic wave that propagates along the interface between two materials with different refractive indices. These waves are characterized by their exponentially decaying amplitude as they penetrate into the second medium.
2. How is the concentration of evanescent/surface waves measured?
The concentration of evanescent/surface waves can be measured using techniques such as total internal reflection microscopy or surface plasmon resonance. These methods rely on the interaction between the surface waves and the material they are propagating along, which produces a measurable signal.
3. What factors affect the concentration of evanescent/surface waves?
The concentration of evanescent/surface waves is affected by several factors, including the angle of incidence of the incident light, the refractive indices of the two materials, and the thickness of the interface between them. Additionally, the properties of the material itself, such as its dielectric constant, can also influence the concentration of these waves.
4. What are the applications of evanescent/surface waves?
Evanescent/surface waves have a wide range of applications in various fields, including biosensing, microscopy, and telecommunications. For example, surface plasmon resonance is used in biosensors to detect and measure the concentration of biomolecules, while total internal reflection microscopy is used to image subcellular structures with high resolution.
5. How can the concentration of evanescent/surface waves be manipulated?
The concentration of evanescent/surface waves can be manipulated by altering the properties of the materials they are propagating along. This can be achieved by changing the refractive indices of the materials, adjusting the angle of incidence, or modifying the thickness of the interface. Additionally, the use of specialized materials, such as plasmonic materials, can also enhance the concentration of these waves.
  • Classical Physics
  • Materials and Chemical Engineering
  • Beyond the Standard Models
9K
  • Thermodynamics
  • Electromagnetism
