Concentric circles and a certain curve's function
In summary, the conversation discussed drawing concentric circles with segments and finding a function for the resulting curve. The function can be written using polar coordinates and can be extended to spiral towards the origin as n approaches infinity. To express the curve in Cartesian coordinates, the additional exercise of finding the values of x and y is needed, and for n greater than or equal to 2, the curve can be written as the graph of x as a function of y.
24forChromium
155
Draw a large number of concentric circles with constant radii increment (i.e.: 1m, 2m, 3m...). Assign each with a serial number counting from the centre. (i.e.: innermost: 1, second innermost: 2, etc.)
Divide all the circles into segments, the number of segments for each circle is equal to its serial number, the inner most circle will be divided one time, it point of division is on the same direction from the centre point as the first division point of all other circles.
Now, there would be a shape that looks like something in the picture (not the best in the world) I uploaded:
Now, connect all of the points of divisions that is immediately next to the first points in the clockwise direction:
What would be the function of this curve.
I am asking this question in the context of writing a high school research paper, level of maths is up to calculus and complex number with some rigour, would it be possible to find a function to this curve using those?
Mathematics news on Phys.org
The function is easily written using polar coordinates.
Let ##n## be the number of segments in the circle. Then write the values of ##r## and ##\theta## in terms of ##n## for the points you have drawn. By allowing ##n## to have non-integer values larger than 2 you can plot the curve between each pair of points on consecutive circles.
Once you have the formulas for ##r## and ##\theta## in terms of ##n## you can eliminate ##n## to get a formula for ##r## in terms of ##\theta##.
Even more fun: The above gives you a curve for values of ##\theta## in the range ##[-\frac{\pi}{2},\frac{\pi}{2})##. Now you can use the formula obtained above to extend it to ##\theta## in the range ##[-\infty,-\frac{\pi}{2})##, which corresponds to ##n\in(0,2)##. That curve will spiral in towards the origin, without ever reaching it, as it rotates clockwise around it.
Additional exercise: what will the curve do as ##n\to\infty##?
Let ##n## be the number of segments in the circle. Then write the values of ##r## and ##\theta## in terms of ##n## for the points you have drawn. By allowing ##n## to have positive non-integer values you can plot the curve between each pair of points on consecutive circles.
Even more fun: The above gives you a curve for values of ##\theta## in the range ##[-\frac{\pi}{2},\frac{\pi}{2}]##. Now you can use the formula obtained above to extend it to ##\theta## in the range ##[-\infty,-\frac{\pi}{2}]##, which corresponds to ##n\in(0,2)##. That curve will spiral in towards the origin, without ever reaching it, as it rotates clockwise around it.
That's great, thanks, so the polar form would just be: r cis(θ) = n(radius increment) cis (π/2 - 2π/n).
How would you express that in terms of y f(x) again?
I found the formula for x and y in terms of n, but not the two of them in terms of one another.
You can use polar coordinates (parametric form).
[itex]r=n, \ \theta = \frac{\pi}{2}-\frac{2\pi}{n}[/itex]
For any given point ##(r,\theta)## you can express it in Cartesian coordinates for the purpose of plotting using
$$x=r\cos\theta;\ \ y=r\sin\theta$$
Note however that the curve is not the graph of ##y## as a function of ##x## because there will be some values of ##x## that have more than one value of ##y##. To find out what those values are, the additional exercise above needs to be done.
You can write the curve as the graph of ##x## as a function of ##y## if you restrict it to ##n\geq 2##.
There will be no analytic formula for ##x## in terms of ##y##, because to get that you need to express ##n## in terms of ##x##, which will have no closed form solution because ##x=n\sin\frac{2\pi}{n}## and equations with a variable both inside and outside a trig function generally have no such solution. Numerical techniques must be used instead.
Related to Concentric circles and a certain curve's function
1. What are concentric circles and how are they related to a curve's function?
Concentric circles are a series of circles that share the same center point. They are related to a curve's function because they can be used to graphically represent a curve's equation, with each circle representing a different value of the curve's variable.
2. How do concentric circles and a curve's function intersect?
The intersection of concentric circles and a curve's function occurs when the value of the curve's variable matches the radius of a particular circle. This point of intersection can be used to solve for the corresponding x and y coordinates on the curve.
3. Can concentric circles and a curve's function be used to model real-world phenomena?
Yes, concentric circles and a curve's function can be used to model real-world phenomena such as planetary orbits, sound waves, and electromagnetic fields. They can also be used in various engineering and design applications.
4. What is the general equation for a curve's function?
The general equation for a curve's function is y = f(x), where y represents the output or dependent variable and x represents the input or independent variable. The specific form of the equation may vary depending on the type of curve being represented.
5. How can we manipulate concentric circles and a curve's function to achieve desired results?
Concentric circles and a curve's function can be manipulated by changing the values of the curve's variables, such as the coefficients and exponents in the equation. This can result in changes to the shape, position, and size of the circles and the overall curve.
  • General Math
