Concentric coils for power generation
In summary, adding nested coils to a generator does not significantly increase its power output due to the conservation of energy and the limited efficiency of current generators.
samstergurl
TL;DR Summary
Can nested coils be used for generation power from a magnetic field?
Most generators work by rotating a coil within a magnetic field. This induces a current in the coil and can be harnessed as electricity. I was wondering if it would be possible to generate more power by using more than one coil with each one being progressively larger wrapped around the others. I also know that the current induced in the coil creates a magnetic field that tries to oppose the change in the fields around it.
Does this prevent something like this from working or being useful? Or is there some other reason that this isn't done?
:welcome:
Nope. Conservation of energy is the dominant effect here. Many electric generators are already 98-99% efficient. The 1-2% losses are due to heating, friction and windage. And >100% efficiency is truly impossible. So there's not much room for improvement, no matter what you do on the electrical side.
It is so much easier evaluating ideas in terms of conservation of energy rather than thinking about amps, and volts, and flux density.
Likes jrmichler, BvU and DaveE
samstergurl said:
Summary:: Can nested coils be used for generation power from a magnetic field?
In addition to the overall energy considerations mentioned by @anorlunda the current induced in the inner coil generates a back-flux that lowers the available flux for the outer coil. If the two coils share the same radius, it's just like using a longer coil if you series connect them, or if you parallel connect the two coils you still get the same energy out but just at a different source impedance.
One way to see the flux-stealing effect is if you put a shorted turn around the same area as your pickup coil. The shorted turn kills almost all of the flux from the source, so your pickup coil picks up almost no energy.
Likes anorlunda and DaveE
anorlunda said:
:welcome:
So you're already getting 99% of the energy out of that flux area, adding another coil inside of it doesn't improve that. Like how adding a smaller funnel inside of a bigger one doesn't increase the amount of water you get out in the end?
Likes berkeman
Related to Concentric coils for power generation
1. What are concentric coils for power generation?
Concentric coils for power generation are a type of electrical coil design in which multiple coils are arranged in concentric circles. These coils are used in generators to produce electricity by converting mechanical energy into electrical energy.
2. How do concentric coils work in power generation?
Concentric coils work by utilizing the principle of electromagnetic induction. As the rotor of the generator spins, it creates a changing magnetic field which passes through the concentric coils, inducing an electric current. This current is then collected and used as electricity.
3. What are the advantages of using concentric coils for power generation?
There are several advantages to using concentric coils for power generation. These include higher efficiency, compact design, and easier maintenance. The concentric arrangement also allows for a higher power output compared to other coil designs.
4. Are there any limitations to using concentric coils for power generation?
One limitation of using concentric coils for power generation is that they can only produce alternating current (AC). This means that additional components, such as a rectifier, may be needed to convert the AC to direct current (DC) for certain applications.
5. How are concentric coils designed for power generation?
The design of concentric coils for power generation involves considering factors such as the number of turns, wire gauge, and spacing between coils. These factors affect the strength and efficiency of the coils. Computer simulations and testing are often used to optimize the design for specific power generation needs.
  • Electrical Engineering
