Concentric Spherical Capacitors
In summary, the conversation discusses finding the equivalent capacitance of a system of six concentric conducting spheres connected by wires. The solution involves considering the spheres in parallel and series, and using the formula for spherical capacitance, C = 4πεOR. However, there is ambiguity in the question and the correct approach is uncertain. One possible solution involves treating the system as three spherical capacitors connected in series, with a capacitance of C = a*b/(Ke*(b-a)) where a and b are the inner and outer radii.
msbell1
25
Figure P26.26 shows six concentric conducting spheres, A, B, C, D, E, and F having radii R, 2R, 3R, 4R, 5R, and 6R, respectively. Spheres B and C are connected by a conducting wire, as are spheres D and E. Determine the equivalent capacitance of this system.
Capacitance of a sphere: C = 4pi(epsilon0)R
Capacitance in general: C = Q/V
I’m supposed to find the equivalent capacitance of this arrangement. I was kind of perplexed by this one. But here’s what I’ve been thinking. OK. B and C are at the same potential (because they're connected by a wire). D and E are also at the same potential. So it’s like B and C are in parallel, as are D and E. So I said CBC = CB + CC, and CDE = CD + CE. And then CEQ = 1/(1/CA + 1/CBC + 1/CDE + 1/CF) (since I considered these to be in series). Capacitance of a sphere is C = 4πεOR. So using this approach, I found CEQ = (90/133)( 4πεOR). Do I have the right idea, or am I way off?
I don't think your equation for spherical capacitance is correct. See for example http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/capsph.html
Additionally, I'm pretty sure that the equation you used for equivalent capacitance only applies to parallel-plate capacitors which are separated.
I think the tricky thing here would be using the correct radius in your calculations.
The question is ambiguous. Capacitance is a relative property between two conductors. Between which two spheres are you to determine the capacitance?
Alternatively, the capacitance can refer to a single conductor relative to zero charge at an infinite distance (which is the origin of the formula C = 4πεR). In this alternative interpretation of capacitance, you still need to refer to a particular sphere.
All six spheres taken together have an undefined capacitance (becuase there are more than two disconnected conductors).
OK, that may very well be the case. I just feel like there must be a solution since it is one of the problems in Physics for Scientists and Engineers with Modern Physics (5th Edition) by Raymond A. Serway and Robert J. Beichner (Chapter 26, Problem 26). So I guess I'm stuck. Maybe I'll just skip this problem--I'm not doing this for a class, I'm just working on compiling a complete set of solutions for the homework problems in this 2-volume set. Thanks for your help.
I'm going to take a guess at this one, but it looks to me that you have three spherical capacitors connected in series. Capacitor 1 has radii a&b, connected in series to capacitor 2 with radii c&d which is connected in series to capacitor 3 with radii e&f. The capacitance is dependent on the radius C=a*b/(Ke*(b-a)) where a is the inner radius and b is the outer radius. I would like to see the book answer if there is one.
That's an interesting idea. I see what you mean with the three capacitors connected in series. Actually, that seems like a great idea! So let's say I put +Q on sphere A. Then sphere B must have -Q so that Gauss's Law gives 0 E-field between spheres B and C (otherwise charges would flow in the wire connecting B and C). However, since the combination of B and C was initially uncharged, then C must now have +Q. This means that D has -Q (so again Gauss's Law gives an E-field of 0 between D and E so no current flows in the wire). And thus E has +Q, and finally F will have -Q. However, now that it seems, as you said, that we have 3 capacitors in series, how do they add? I guess charge is the same on all 3 capacitors (since they are in series), so is it true that 1/Ceq = 1/Cab + 1/Ccd + 1/Cef? I think you might be on to something! Thanks a lot!
P.S. Using this approach, I found Ceq = 4πεO(60/37)R.
FAQ: Concentric Spherical Capacitors
What is a concentric spherical capacitor?
A concentric spherical capacitor is a type of capacitor that consists of two concentric spheres separated by a dielectric material. The inner sphere serves as the positive plate and the outer sphere serves as the negative plate.
How does a concentric spherical capacitor work?
A concentric spherical capacitor works by storing electrical charge on its two plates. When a voltage is applied to the capacitor, the positive plate accumulates positive charge and the negative plate accumulates negative charge. This creates an electric field between the plates, which can be used to store energy.
What is the capacitance of a concentric spherical capacitor?
The capacitance of a concentric spherical capacitor depends on the radius of the inner and outer spheres, as well as the permittivity of the dielectric material between the plates. The capacitance can be calculated using the formula C = 4πεr1r2/ (r2 - r1), where ε is the permittivity and r1 and r2 are the radii of the inner and outer spheres, respectively.
What are some applications of concentric spherical capacitors?
Concentric spherical capacitors are commonly used in high voltage and high frequency applications, such as in power transmission systems, radio frequency amplifiers, and radar systems. They are also used in electronic filters, sensors, and energy storage devices.
How does the permittivity of the dielectric material affect a concentric spherical capacitor?
The permittivity of the dielectric material affects the capacitance of a concentric spherical capacitor. Higher permittivity materials, such as ceramics or polymers, can increase the capacitance and allow for the storage of more charge. However, they may also have higher losses and lower breakdown voltages, limiting the capacitor's performance in certain applications.
