kevin17ym
- 7
If you swing a ball in a vertical circle using a thin string, at the bottom of the circle the tension in the string must be greater than the ball's weight. True or false?
F = mvv/r
F = mg
The correct answer, it says, it's true. But why isn't it false? Why can't the tension and the ball's weight have an equal magnitude of force?
Is it because the "thin" string is also pushing down on the ball so the net weight is ball's weight + thin string weight?
