Conceptual: electric potential
In summary, the proton and electron experience different changes in electric potential energy due to their different masses and charges. The proton experiences a smaller change since it has a smaller speed and charge magnitude. However, it is not possible to directly compare the changes since the particles are moving in opposite directions. The last option may be correct, as the magnitudes of change are the same, but the direction of the change is different. The acceleration of an object depends on the direction of the force acting on it, which can contribute to an increase or decrease in kinetic energy.
calgal260
A proton is released from rest at point A in a constant electric field and accelerates to point B (see part a of the drawing). An electron is released from rest at point B and accelerates to point A (see part b of the drawing). How does the change in the proton's electric potential energy compare with the change in the electron's electric potential energy?
http://www.webassign.net/cj8/c19_q_4.gif
V=EPE/q
The proton experiences a smaller change in electric potential energy, since it has a smaller speed at B than the electron has at A. This is due to the larger mass of the proton.
The proton experiences a greater change in electric potential energy, since it has a greater charge magnitude.
One cannot compare the change in potential energies because the proton and electron move in opposite directions.
The proton experiences a smaller change in electric potential energy, since it has a smaller charge magnitude.
The change in the proton's electric potential energy is the same as the change in the electron's electric potential energy.
Well if one is going in the same direction as the electric force, wouldn't the work be positive and EPE (electric potential energy) be higher since kinetic energy is decreasing? So would the last choice be correct, given that the magnitudes of change are the same but their directions are different?
I'm confuzzled.
if something is moving in the direction of the Force, so that positive Work is done on it, why is its KE decreasing?
Do things accelerate toward high gravity PE, or toward low gravity PE?
Well its KE is decreasing because the force exerted by the field contributes to its forward acceleration...
if it's accelerating forward, that usually means that its speed is increasing.
("released" usually means starting with speed = 0 ...)
I would say that the last choice is the most accurate. The change in electric potential energy for both the proton and the electron is determined by the difference in electric potential between points A and B. Since both particles are moving in opposite directions, their changes in potential energy will have opposite signs. However, the magnitudes of their changes will be the same, as they are both experiencing the same electric field. This is because the change in potential energy is dependent on the charge magnitude and the distance traveled, which are the same for both particles. Therefore, the change in the proton's electric potential energy is equal to the change in the electron's electric potential energy, but with opposite signs.
FAQ: Conceptual: electric potential
What is electric potential?
Electric potential is a measure of the amount of potential energy per unit of electric charge at a certain point in an electric field.
How is electric potential different from electric field?
Electric field is a vector quantity that describes the strength and direction of the force exerted on a charged particle, while electric potential is a scalar quantity that describes the amount of potential energy a charged particle has at a certain point in the electric field.
What are the units of electric potential?
Electric potential is measured in volts (V) or joules per coulomb (J/C).
How is electric potential calculated?
Electric potential is calculated by dividing the electric potential energy by the amount of charge at a certain point in an electric field. It can also be calculated by multiplying the electric field strength by the distance from the source charge.
What is the relationship between electric potential and electric potential energy?
Electric potential is directly proportional to electric potential energy. As electric potential increases, so does electric potential energy. However, the direction of electric potential energy depends on the direction of the electric field, while electric potential is a scalar quantity and has no direction.
