CONCEPTUAL: isothermic expansion
In an isothermal expansion, the total internal energy of an ideal gas remains constant since it is proportional to temperature, while non-ideal gases may experience an increase in internal energy due to changes in molecular potential energy. The work done during isothermal expansion can be calculated using the formula W = -nRT∫(dV/V), applicable only to ideal gases. For adiabatic processes, the work done is calculated differently, using W = -nC_vΔT, reflecting changes in temperature. The distinction between work done on versus by the gas is emphasized, with the latter being the preferred convention. Understanding these principles is crucial for accurately applying the first law of thermodynamics in different thermodynamic processes.
lackos
37
I was wondering about the first law of thermodynamics and isothemic expansion. Is there an increase in the the total internal energy of a gas through this process. If not is there a way to calculate heat (i can calculate work) through this process as both pressure and volume vary.
Also is an isothermal expansion the only time when you can use W=-nRT\intV.dV.
or can you use that for say an adiabatic expansion where temperature varies
lackos
It depends on the gas. If it is an ideal gas, the internal energy is proportional to temperature, so there is no change in internal energy during an isothermal process. If it is a non-ideal gas, expansion will result in an increase in potential energy of the molecules (for most non-ideal gases) and therefore will increase internal energy.
I think you meant: W=-nRT\int dV/V where W is the work done ON the gas. I prefer to use W as the work done BY the gas. This is true only for isothermal processes for an ideal gas.
W = \int PdV where W is the work done BY the gas. This is always true. And since for an ideal gas P = nRT/V, W = \int nRTdV/V
For isothermal processes, \int PdV = nRT\int dV/V since T is constant.
For an adiabatic process, \int dW = -\int dU = -\int nC_vdT = -nC_v\Delta T
AM
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
