Conceptual misunderstanding of Velocity-Time Graphs
In summary, the displacement in a velocity-time graph can be calculated by subtracting the areas above the x-axis from the areas below the x-axis. This may result in a negative value for the displacement, but it is still considered positive due to the definition of area under the curve. Additionally, when the graph line is below the x-axis, the definite integral is negative, but the area is still positive due to the way it is defined. It is important to understand the difference between displacement and distance traveled, as well as the concept of definite integrals, in order to properly interpret and calculate area under a curve.
zabachi
33
Hi all I have a confusion regarding a physics concept. When you consider area under graph (velocity time graph), if the area is below x axis, is the area considered to be negative?
For example, look at the attachment. There are 2 shaded areas. Let the area above x-axis be A and area below x-axis be B and ignore all the numerical values on the graph. Is the displacement A+B or A-B? I am very confused.
  • Physics.zip
The displacement is A-B. It is like this. In your graph the velocity rises to a certain extent and then comes constant. Then it drops down to zero. Now the body is not in motion. Since velocity is a vector, negative means the direction has reversed. So, as the line drops down you must understand that the body is reversing.Then absolutely the displacement will be less Than the amount it had covered before reversing. Hence the area/displacement would be A-B.
but isn't the area under graph of B negative (since it is below x axis?)? if u were to use the values in the graph, area of B= 1/2 x 2 x -2 + 1 x -2 = -4. then A-B will become A-(-4) which is A + 4. That would be wrong right?
But see! The area of B (neg) is smaller than area of A (pos)
A-B must give you a positive area.
Logically acceptable...
But you see if you did the working for the total displacement, you get:A = 1/2 x 2 x 3 + 2 x 3 + 1/2 x 3 x 3, B = (1/2 x -2 x 2) + (1 x -2)
A + B gives you the actual displacement of 9.5m while A - B gives 17.5m, which is wrong
isnt it?
That's wrong.
If you take the areas A and B as absolute values (which are always positive), then the *displacement* at 10s will be given as A - B and the total *distance* traveled at 10s is A + B.
Areas are always positive, but you must be careful to distinguish the value of a definite integral from the area "under" a curve (or between a curve and the horizontal axis).
In this case, [itex]\int_0^7v(t)dt > 0[/itex] whereas [itex]\int_7^{10}v(t)dt < 0[/itex]. The sum, which is equal to [itex]\int_0^{10}v(t)dt[/itex], which yields the displacement at 10s, is positive because the second integral (from 7 to 10) is of smaller magnitude than the first (from 0 to 7).
The respective areas A and B are given by the absolute values of the integrals, i.e.
[itex]A = |{\int_0^7v(t)dt}|[/itex] and [itex]B = |{\int_7^{10}v(t)dt}|[/itex] and the total distance = A + B.
why must areas always be positive? i mean if you use the values from the graph area is negative right? and i haven't learned calculus yet (learning it next semester) so is there a simpler way of explanation please?
The displacement (actual distance between the starting point and the ending point) is A- B. The distance traveled is A+ B. (If you to 90 m straight ahead the go back 30 m toward your starting point, you will end 90- 30= 60 m from the start but you will have traveled a total of 90+ 30= 120 m.)
ok erm you i get that but is area under graph always positive? since the B is below the x axis, B area should be negative right? if u took A = 90, B = -30 then won't the diplacement be A + B?
Area is, by definition, positive. This link may help explain things simply: http://www.teacherschoice.com.au/maths_library/calculus/area_under_a_curve.htm
I realize you haven't started calculus yet, but there's no escaping basic integration if you're talking about the area under a curve.
In the link you provided, there was one part saying total shaded area = A1 + A2 + A3 even though A2 is below x axis. and it was written "but when the graph line is below the ‘x’ axis, the definite integral is negative. " doesn't that mean that area under graph can be negative when below x axis? Or is it just a misunderstanding of the statement by me?
Misunderstanding by you.
When the curve is below the x-axis, the definite integral taken in the direction of increasing x (with the higher x value as the upper bound) will be negative. In that case, the area is specifically defined as MINUS (one) times the integral, so that the area remains positive (minus times minus = plus). Note carefully how they defined A2, and how it differs from how they defined A1 and A3.
So the area is always positive. I don't know where you're getting the idea that area can ever be negative.
Thanks for all the help into making me understand why area must be positive!
FAQ: Conceptual misunderstanding of Velocity-Time Graphs
What is a velocity-time graph?
A velocity-time graph is a visual representation of an object's velocity (speed and direction) over time. The horizontal axis typically represents time, while the vertical axis represents velocity. This graph is useful for understanding an object's motion and how it changes over time.
How do you interpret a velocity-time graph?
The slope of a velocity-time graph represents the object's acceleration, with a steeper slope indicating a greater acceleration. The area under the curve represents the total distance traveled by the object. The shape of the curve can also provide information about the object's motion, such as constant velocity or changing acceleration.
What is the difference between a positive and negative slope on a velocity-time graph?
A positive slope on a velocity-time graph indicates that the object is moving in the positive direction (e.g. to the right or upwards) and increasing in speed. A negative slope indicates that the object is moving in the negative direction (e.g. to the left or downwards) and decreasing in speed.
Can a velocity-time graph show when an object is at rest?
Yes, a horizontal line on a velocity-time graph indicates that the object is at rest. This means that the object is not moving and its velocity is constant at 0.
How can a conceptual misunderstanding of velocity-time graphs impact scientific research?
A misunderstanding of velocity-time graphs can lead to incorrect interpretations of an object's motion. This can result in faulty experimental design, inaccurate data analysis, and incorrect conclusions. It is important to have a thorough understanding of velocity-time graphs in order to accurately interpret and analyze data in scientific research.
