Conceptual problem regarding pressure and surface area
In summary, the conversation discusses the relationship between air pressure and height in a room. While the force equation suggests that pressure is independent of height, there is a small pressure difference due to the weight of the air above and between the head and the ground. This pressure differential is what creates a buoyant force, as seen with helium balloons.
coconut62
161
Is the air pressure acting on the top of the head of a person standing in a room equal to the air pressure acting on a same area on the floor of the same room?
Since F = pA , it seems as if the air pressure is independent of the height of the surface on which it is acting. But that doesn't seem to make sense because the force on the ground must be due to the weight of the air above the person's head plus the weight of air between the head and the ground?
Thanks.
Technically, you are correct, there is a pressure difference. However, that pressure difference is small in comparison to the total atmospheric pressure.
It is this pressure differential that provides a buoyant force to, for example, helium balloons.
Likes coconut62
That equation just defines pressure in terms of force and area. There's no implication that pressure is independent of height. (Height isn't even mentioned!)
It's certainly true that pressure varies with height. That's what creates the buoyant force on an object (or person).
Likes coconut62
Related to Conceptual problem regarding pressure and surface area
What is pressure?
Pressure is defined as the force per unit area applied perpendicular to the surface of an object. It is typically measured in units of Pascals (Pa) or pounds per square inch (psi).
How does surface area affect pressure?
According to Pascal's principle, pressure applied to a confined fluid will be transmitted equally in all directions. This means that as surface area decreases, the pressure exerted on that surface will increase.
What is the relationship between pressure and depth?
The deeper you go in a fluid, the greater the pressure will be. This is because the weight of the fluid above you increases as you go deeper, resulting in higher pressure.
Can pressure be applied to a point?
No, pressure can only be applied to a surface. This is because pressure is defined as force per unit area, and a point has no area.
How does changing the shape of an object affect pressure?
The shape of an object can affect pressure by changing the surface area that the force is applied to. For example, a sharp point will have a smaller surface area and therefore a higher pressure than a flat surface.
