Conceptual Question about Conservation of Momentum
In summary, momentum is conserved when there is no external force acting on the system, including the Earth. In the case of a collision between two cars with friction present, momentum is still conserved as long as the external forces are balanced and there is no external impulse. In the case of a bicycle coasting to rest with friction present, momentum is not conserved due to the external impulsive forces acting on the system.
jayadds
42
Hi,
I just want to understand this concept a bit better. The law states that momentum is conserved when there is no external force acting on the system.
Now consider this situation where two cars of equal mass and moving at equal speed collide head-on to come to rest.
Would the momentum be conserved? Looking at the situation, there is friction acting on the cars so does that mean momentum is not conserved?
Similarly for this situation: a bicycle rider ceases to pedal and her bicycle coasts along the path until it comes to rest. Is momentum not conserved as well due to friction?
Many thanks.
Yes it is zero all the time. Momentum is a vector, and the conserved net momentum is a vector sum.
Friction with the ground? That is an external force, unless you include the entire Earth in your momentum balance. In a symmetrical cases however, where the cars are identical and have the same rolling resistance the net external force is zero too, because forces are vectors too.
hi jayadds! :smile:
momentum is conserved in any direction in which there is no external force
(And angular momentum is conserved about any axis about which there is no external torque)
in a collision, momentum is conserved in any direction in which there is no external impulse
(and in a collision, angular momentum is conserved in any direction in which there is no external impulsive torque)
friction (unlike say, a step or a barrier) is not impulsive, so you use it before and after the collision, but you ignore it for the collision itself! :wink:
if we ignore the rolling resistance (the continual deformation of the tyre where it meets the road), and the frictional torque on the axle, then there are no external forces or torques, and the bike goes on for ever :smile:
tiny-tim said:
hi jayadds! :smile:momentum is conserved in any direction in which there is no external force
friction (unlike say, a step or a barrier) is not impulsive, so you use it before and after the collision, but you ignore it for the collision itself! :wink:if we ignore the rolling resistance (the continual deformation of the tyre where it meets the road), and the frictional torque on the axle, then there are no external forces or torques, and the bike goes on for ever :smile:
However, given the situation that the bicycle does eventually go to REST as stated in the question, how can it go on forever? Would the momentum be conserved or not if the bicycle eventually goes to rest?
There is resistance due to the Earth, and also the frictional torque on the axle(as Tiny-tim said), and these act for a long duration, unlike in collisions. Meaning that there is external impulsive force. So no conservation of momentum.
yes (except, not impulsive) :smile:
hi,i have the similar problem...if i include the Earth in my system.EARTH HAS ZERO MOMENTUM before and after colision of car right? then acc to conservation of momentum MV+MV=0(WHERE M IS MASS OF CAR AND V IS VELOCITY OF CARS) then V=0?
If you include the Earth in your system, momentum is conserved: the change in momentum of the car is equal and opposite to the change in momentum of the Earth. It's just that nobody will notice the change in momentum of the Earth. Since the Earth is so massive, the change in its velocity will be much too small to be measured.
FAQ: Conceptual Question about Conservation of Momentum
1. What is the law of conservation of momentum?
The law of conservation of momentum states that the total momentum of a closed system remains constant. This means that in the absence of external forces, the total momentum before an event is equal to the total momentum after the event.
2. What is the difference between elastic and inelastic collisions?
In an elastic collision, kinetic energy is conserved while in an inelastic collision, kinetic energy is not conserved. In an elastic collision, the objects involved bounce off each other without any loss of kinetic energy, while in an inelastic collision, there is a transfer of kinetic energy to other forms such as heat or sound.
3. Can the law of conservation of momentum be violated?
No, the law of conservation of momentum is a fundamental law of physics and has been observed to hold true in all physical events. If it appears to be violated, it is likely due to external forces that were not taken into account.
4. How does the conservation of momentum apply to systems with multiple objects?
The law of conservation of momentum applies to systems with multiple objects by considering the total momentum of the system, which is the sum of the individual momenta of each object. As long as there are no external forces acting on the system, the total momentum will remain constant.
5. What is the role of momentum in collisions?
Momentum plays a crucial role in collisions as it is a measure of an object's motion. In collisions, momentum is transferred between objects, allowing us to predict the motion of the objects involved before and after the collision. The law of conservation of momentum also helps us understand and analyze the outcomes of collisions.
