Conceptual question about internal energy
In summary, the conversation discusses the concept of lighting a stove in a chilly dwelling to increase the internal energy of the air and keep the person comfortable. However, it is pointed out that the air's internal energy does not change with temperature, leading to confusion about the role of the stove. The conversation then delves into the ideal gas law and the effect of heat on temperature, ultimately concluding that the first law of thermodynamics does not apply in this scenario due to the changing number density of the air.
jdstokes
523
From the beginning of chapter 21 Haliday, Resnick and Walker:
`Suppose that you return to your chilly dwelling after snowshoeing through the woods on a cold winter day. Your first thought is to light a stove. But why, exactly, would you do that? Is it because the stove will increase the store of internal (thermal) energy of the air in the cabin, until eventually the air will have enough of that internal energy to keep you comfortable? As logical as this reasoning sounds, it is flawed, because the air's store of internal enrgy will not be changed by the stove. How can that be? And if it is so, why would you bother to light the stove?'
I'm confused by what HRW are saying here. My understanding is that the stove releases heat into the constant-volume environment which raises the internal energy according to the first law of thermodynamics [itex]dU = Q - PdV = Q[/itex].
Am I missing something here?
This is really an ideal gas law problem, not a first law problem.
State the expression for the total internal energy of the air inside the cabin.
Now add heat, dQ. This increases the temperature by dT. P is constant because the atmospheric pressure does not change. The cabin's volume does not change. So PV does not change. If dQ heat is added and temperature increases by dT, what else has to change? Express that quantity as a function of temperature and substitute into your expression for total internal energy of the air in the cabin. You will see why the total internal energy does not change with temperature.
AM
Thanks for your reply Andrew,
[itex] U = \frac{3}{2}NkT[/itex].
[itex]PV = NkT \implies N = PV/kT \implies U = \frac{3}{2}PV[/itex].
That is a very interesting result. So there is less air in a hot room than a cold one? Does this effect of reduced number density contribute to the deaths of small pets in heated cars?
You mention that this is not a first law problem. I'm wondering what is the flaw in the logic which leads to the conclusion [itex]\Delta U = Q[/itex]? Presumably the idenity [itex]W = -PdV[/itex] fails because of the varying number density. What is the correct expression? [itex]W = - PdV + \mu dN[/itex]?
There is no flaw. The first law assumes that the mass does not change. If the mass changes, the first law does not apply. You could analyse the problem by keeping track of what happens to the air that leaves the room, and then the first law would apply. But that would be rather difficult.
AM
That's a fair point, but I think it is possible to save the first law for open systems by introducing an additional term, namely [itex]\mu dN[/itex]. This makes it more `universal' in some sense.
FAQ: Conceptual question about internal energy
What is internal energy?
Internal energy is the total energy contained within a system. It includes the energy of the particles within the system, such as their kinetic and potential energy, as well as the energy associated with the bonds between particles.
How is internal energy different from thermal energy?
Thermal energy refers specifically to the energy associated with the temperature of a system, while internal energy encompasses all types of energy within a system, including thermal energy.
What factors affect the internal energy of a system?
The internal energy of a system can be affected by various factors, such as the temperature, pressure, and composition of the system. It can also be changed by adding or removing energy, such as through heating or cooling.
How is internal energy related to work and heat?
The change in internal energy of a system is equal to the sum of the work done on the system and the heat transferred to the system. This is known as the first law of thermodynamics.
Can internal energy be measured?
Yes, internal energy can be measured using various techniques, such as calorimetry, which involves measuring the amount of heat transferred to or from a system. It can also be calculated using equations based on the first law of thermodynamics.
