Conceptual question on wavelength&frequencies
  • Thread starter xregina12
  • Tags
    Conceptual
In summary, ultrasound uses high frequency sound waves to create an image of the fetus in the mother's abdomen, while audible sound with a frequency of 8000 s-1 would not be effective for this purpose due to its lower energy and ability to penetrate through tissue.
xregina12
27
Here is a really simple conceptual question.
Explain why ultrasound can be used to prove the size and position of the fetus inside the mother's abdomen. Could audible sound with a frequency of 8000 s-1 be used for this purpose?
I know that audible sound has too low of a frequency (i.e not enough energy) for it to be used to probe the mother's stomach. However, can someone just further explain to me what this means conceptually? The audible sound just stops at the mother's stomach w/o being able to pass further to show what's inside?
I really appreciate any help.
Ultrasound uses sound waves of very high frequency (above 20,000 s-1) to create a detailed image of the fetus inside the mother's abdomen. This high frequency allows the sound waves to penetrate through the mother's tissue, creating a picture of the fetus on a monitor. Audible sound with a frequency of 8000 s-1 is too low for this purpose because it does not have sufficient energy to penetrate through the mother's tissue and create a picture. Instead, the sound would be blocked by the mother's tissue, making it impossible to measure the fetus' size and position.
FAQ: Conceptual question on wavelength&frequencies
What is the relationship between wavelength and frequency?
Wavelength and frequency have an inverse relationship. This means that as the wavelength increases, the frequency decreases and vice versa. This relationship is described by the equation: speed = wavelength x frequency. In other words, the higher the frequency, the shorter the wavelength and the lower the frequency, the longer the wavelength.
How are wavelength and frequency measured?
Wavelength is typically measured in meters (m) or nanometers (nm). Frequency is measured in Hertz (Hz) or cycles per second. These measurements are used to describe different types of waves, including light waves, sound waves, and radio waves.
What is the significance of wavelength and frequency in the electromagnetic spectrum?
The electromagnetic spectrum is the range of all possible frequencies of electromagnetic radiation. Wavelength and frequency are important because they determine the type of electromagnetic radiation, such as radio waves, microwaves, infrared, visible light, ultraviolet, x-rays, and gamma rays. Each type of radiation has a different wavelength and frequency, which affects how it interacts with matter.
How does wavelength and frequency impact the properties of light?
The wavelength and frequency of light determine its color and energy. Shorter wavelengths and higher frequencies correspond to blue light, while longer wavelengths and lower frequencies correspond to red light. The energy of light is directly proportional to its frequency, meaning that higher frequency light has more energy. This is why ultraviolet and x-rays, which have high frequencies, are more powerful and potentially harmful than visible light.
Can wavelength and frequency be changed?
Yes, both wavelength and frequency can be changed. Wavelength can be altered by changing the medium that the wave is traveling through. For example, the wavelength of light changes when it passes through a different substance, such as air to water. Frequency can be changed by altering the source of the wave. For example, the frequency of sound waves can be changed by adjusting the pitch of a musical instrument.
