Conceptual question regarding buoyant force
In summary: For the fluid of lowest density, volume displaced is the highest.In summary, the buoyant forces on the penguin are all equal in the three fluids, as the weight of fluid displaced is the same. However, the amount of fluid displaced is different for each fluid, with the highest density fluid displacing the least amount of fluid and the lowest density fluid displacing the most. This is due to the inverse relationship between density and volume.
coconut62
161
A penguin floats first in a fluid of density p0, then in a fluid of density 0.95p0, and then in a fluid of density 1.1p0. a) Rank the densities according to the magnitude of the buoyant force on the penguin, greatest first. b) Rank the densities according to the amount of fluid displaced by the penguin, greatest first.
Answer:
a) All tie. The gravitational force on the penguin is the same.
b) 0.95p0, p0, 1.1p0.
Why? Since the penguin displaces different amounts of water in the three fluids(as part b suggests) surely the buoyant force must be different? (Buoyant force = weight of fluid displaced) For example when the penguin is in fluid of density 0.95p0 half of the body is in the liquid, and when it is in the fluid of density 1.1p0 only a quarter of the body is in the liquid, how can the buoyant forces tie?
Thanks.
coconut62 said:
Answer:
Keep track of which forces you're playing with, and you'll be fine.
Consider Newtons second law. What would happen if the buoyant force were not equal to the weight?
coconut62 said:
Since the penguin displaces different amounts of water...
What does "amount" mean here? What measure of amount of displaced fluid is relevant for the buoyant force
Volume. Volume x density x gravity = F
No it's not just volume, is it?
Yes.
I think I got it:
For all three fluids, weight of fluid displaced is the same, but
Weight = mg = (rho)(V)g
Therefore rho is inversely proportional to V.
For the fluid of highest density, volume displaced is the least, because just a small volume of this fluid already weights the same as a larger volume of another liquid with a lower density.
Likes Dale
FAQ: Conceptual question regarding buoyant force
1. What is buoyant force?
Buoyant force is the upward force exerted by a fluid (such as water) on an object immersed in it. It is caused by the difference in pressure between the top and bottom of the object.
2. How does the shape of an object affect buoyant force?
The shape of an object does not affect the magnitude of the buoyant force, but it does affect the direction in which the force is exerted. For example, a flat object will experience a buoyant force perpendicular to its surface, while a cylindrical object will experience a buoyant force in all directions.
3. Does the mass of an object affect buoyant force?
Yes, the mass of an object does affect the buoyant force. The more mass an object has, the greater the force of gravity pulling it down. This means that the buoyant force must be greater in order to balance out the downward force and keep the object afloat.
4. How does the density of an object and the fluid it is immersed in affect buoyant force?
The density of an object and the fluid it is immersed in are directly related to the buoyant force. If the object is more dense than the fluid, it will sink. If the object is less dense, it will float. The greater the difference in density, the greater the buoyant force needed to keep the object afloat.
5. What is the relationship between buoyant force, gravity, and volume?
Buoyant force is directly related to the volume of the object immersed in the fluid. This is because the volume of the object determines the amount of fluid it displaces, and the amount of fluid displaced is equal to the buoyant force. Gravity also plays a role, as it is the force that pulls the object down and must be balanced by the upward buoyant force to keep the object afloat.
