Conceptual questions: Limit of energy?
In summary, a photon with no mass will not collapse into a black hole, even with increasing energy. However, if a photon has a very small mass, it could potentially form a black hole at extremely high energies. The concept of mass and energy in relativity is relative and depends on the observer's frame of reference. The mass of an object itself does not change, but the mass of a system can increase with added energy or momentum.
tolove
164
Starting with this equation,
[itex]E^2 = p^2c^2 + m^2c^4[/itex]
With a photon, m = 0... what happens when E starts to get large? Very large. As E approaches infinity, do strange things happen? Will a singularity form?
If we let our photon have a mass, something very small, will the picture change at all?
A very open question, since I'm having trouble here... What's the difference between mass and energy?
Thanks for your time!
For a photon? No. It has no mass and will never collapse into a singularity.
Instead of letting our photon have mass, let's just look at a massive object. We have two ways of increasing E. We can either add momentum, or we can add mass. If we add momentum, then the picture is still the same as the photon. It will never collapse into a black hole because it has no momentum in its own rest frame.
However, if we add mass, then we CAN have it collapse into a black hole once we get it sufficiently massive enough.
An easy way to think of it is that mass is energy in a form that all observers will agree upon. What I mean is that the mass of a baseball is the same no matter what your motion is relative to the baseball. The energy of it, is not, however. The total energy changes depending on if you (or the ball) is moving relative to one another. If I fly by the ball at 0.5c then it's going to have an enormous amount of energy as seen from my point of view compared to if I'm sitting in the stands and watching it fly into left field.
You may be saying, "But energy has mass!"
And you'd be right. However, while the mass of the BALL ITSELF does not change, the mass of the system as a whole does change. As a simple example, let's say I have a system of two ships out in space at rest relative to one another. Let's say the combined mass of the system is 10,000 kg. Now, I have another system with two spaceships identical to the ones in the first example. However, in this system, they are moving at 0.5c relative to one another. The total mass of the system is MORE than 10,000 kg due to the extra kinetic energy.
Make sense?
Ah, I was moved to the relativity subforum. Didn't want to to be strictly related to relativity. Would like to ask a question along the lines of: Does anything interesting happen with particle creation/annihilation when a photon approaches infinite energy? If the question even makes sense! I'm just curious what happens at the extremes, if anything.
Just regurgitating something my professor said today, it's what confused me so much! Photons might carry a very small amount of mass.
I didn't know about relativity affecting mass. We only hop scotched over the subject so far, mentioning length and time. Moving objects gain mass? We can observe a black hole from one reference frame, while in another it's not? This.. doesn't sound right. Resting mass demands distinction? I don't understand why.
With very large amounts of energy the photon can interact with another particle and create new particles.
The possibility exists, but as far as we know, they are massless.
The mass of the object itself never changes. The mass of a SYSTEM of objects is what increases. For example, the mass of a box of marbles that aren't moving is less than the mass of a box of marbles that are bouncing around everywhere. But the mass of the first box of marbles is the same in its own rest frame as it is in the frame of an observer who sees that box in motion. The motion of the box as a whole doesn't affect its own mass. (Rest mass if you want to use that term)
So an object that isn't a black hole in its own frame of reference can never become one by accelerating it to any velocity.
...while the mass of the BALL ITSELF does not change, the mass of the system as a whole does change.
So while a photon in and of itself cannot become a black hole it could, in principal, be of such high energy that when it comes into proximity of a massive particle that the particle/photon system would become a black hole. Is this correct?
What about a 2 photon system where the 2 photons come from opposite directions? In this case any observer who sees one photon red shifted would see the other blue shifted so all observers should agree on the total energy. Does that make it mass?
I would say yes to both of those questions. That's how I understand it at least. But the required energy would be so extreme that I'm not sure it's actually realistic.
No single particle, mass or massless, will form a black hole because of high speed. That's because the gravitational curvature is given by the stress energy tensor in the frame of the particle; speed has no effect. You can think of it this way: as you go faster and faster nothing happens in the frame of the moving particle...it's clock tick normally, it's mass remains invarient, its size remains constant.
For collisions, see here:
http://en.wikipedia.org/wiki/Black_holes#High-energy_collisions
Even colliding electromagnetic waves could in principle produce a black hole...
Yes to most of your points except that the total energy is always frame dependent. There is no way to create a system where the total energy is an invariant.
The first thing you said here is "... because of high speed." When I say "A photon with high energy" am I also saying "A photon with high speed?" Isn't the energy of a mass-less thing is determined by frequency alone, and the speed is fixed? Is frequency similar to velocity?-- just like an isolated system can't determine its own velocity, an isolated energy wave is unable to determine its own frequency?
Also, could you please elaborate on colliding EM waves producing a black hole? Enough mass in one spot will collapse, why doesn't enough energy in one spot collapse? What's significant about collision?
FAQ: Conceptual questions: Limit of energy?
What is the limit of energy in the universe?
The limit of energy in the universe is currently unknown. According to the first law of thermodynamics, energy cannot be created or destroyed, only transferred or converted into different forms. However, the total amount of energy in the universe may be finite or infinite, and this is still a topic of research and debate among scientists.
Is there a maximum amount of energy that can be stored in a physical system?
Yes, there is a maximum amount of energy that can be stored in a physical system. This is known as the maximum entropy limit, which is the maximum amount of energy that can be extracted from a system by performing work. It is determined by the system's temperature and volume, and is a fundamental concept in thermodynamics.
Can energy be created or destroyed?
No, according to the first law of thermodynamics, energy cannot be created or destroyed. It can only be transferred or converted into different forms. This principle is one of the most well-established laws in physics and has been tested and verified through countless experiments.
What is the relationship between energy and mass?
Einstein's famous equation, E=mc^2, describes the relationship between energy and mass. It states that mass and energy are equivalent, and energy can be converted into mass and vice versa. This is known as mass-energy equivalence and is a fundamental concept in modern physics.
Is there a limit to how much energy can be harnessed from renewable sources?
Yes, there is a limit to how much energy can be harnessed from renewable sources. This is due to the laws of thermodynamics, which state that energy cannot be 100% converted from one form to another. For example, solar panels can only convert a certain percentage of sunlight into electricity, and wind turbines can only extract a certain amount of energy from wind. However, advancements in technology and efficiency can continue to increase the amount of energy we can harness from renewable sources.
