Conceptual questions on linear algebra
But that's probably more than you wanted to know!In summary, the range of a linear transformation is the set of all possible "values" of the function. If a L is a linear transformation (linear function) from V to W, then the Image of L is defined as the set of all w in W such that L(v)= w for some v in V. The standard way of writing a linear transformation as a matrix in a specific basis is to apply the linear transformation to each of the basis vectors, writing the result in terms of the basis. The coefficients in each of those form a column of the matrix.
Niles
1,866
Hi all. I have two questions (and two attempts) which I hope you can answer.
1) When I have a linear transformation L : V -> W, and I am asked to find the range (image) of this transformation, what is it exactly I am required to do? (I am not given the matrix A that corresponds to this transformation). Is the range simply the set of functions we get from our transformation L(x)? Sadly, my book doesn't give a proper answer.
2) I have four matrices that span out a vector space W. The four matrices are 2x2 matrices, and they are:
A_1 = (1 0 , 0 0) - (that is 1 0 in top, 0 0 in bottom).
A_2 = (0 1 , 0 0)
A_3 = (0 0 , 1 0)
A_4 = (0 0 , 0 1).
We have another matrix A = (a b , c d) and a linear transformation F : W -> W given by:
F(X) = AX-XA, X is a matrix in W.
I have to find the matrix for F with respect to the basis W spanned by A_1 .. A_4. What I did was to find F(A_1) up to F(A_4) and then express this result as a linear combination of A_1 to A_4, e.g.:
F(A_1) = 0*A_1 - b*A_2 + c*A_3 - 0*A_4. Then (0,-b,c,0)^T is the first column in my matrix. This gives me a 4x4 matrix - is this approach correct?
Thanks in advance,
sincerely Niles.
Part 2) is just fine. The first question is a little unclear. If you are not given a matrix then you need to be told 'something' about the linear transformation. Then you need to use that 'something' to deduce which elements of W can be expressed in the form L(v) for v in V. It's hard to be more specific.
Part 2: Great :-)
Part 1: I can take an example from my book. A linear operator on P_3 (the vector space spanned by polynomials with degree less than three) is given by:
L(p(x)) = p(x) - p'(x).
To determine the image/range of L, I would do this:
L(p(x)) = ax^2+bx+c - 2ax+b = ax^2 + (2ax+b)x + (b+c). Can I say that this is the range?
The range of any function is the set of all possible "values" of the function. In particular, if a L is a linear transformation (linear function) from V to W, then the Image of L is defined as the set of all w in W such that L(v)= w for some v in V. How you would determine that range depends on exactly how you are "given" V. One example, that does not require a "matrix", is the differentiation operator, D, from the vector space of polynomials of degree 2 or less to itself: any "v" is of the form [itex]ax^2+ bx+ c[/itex] and D([itex]ax^2+ bx+ c[/itex])= ax+ b. The range is the set of all polynomials of degree 1 or less.
A_2 = (0 1 , 0 0)
A_3 = (0 0 , 1 0)
A_4 = (0 0 , 0 1).
Thanks in advance,
sincerely Niles.
A standard way of writing a linear transformation as a matrix in a specific basis[/itex] is to apply the linear transformation to each of the basis vectors, writing the result in terms of the basis. The coefficients in each of those form a column of the matrix.
F(A_1)= AA1- A1A=
[tex]\left[\begin{array}{cc}a & 0 \\ c & 0\end{array}\right]-\left[\begin{array}{cc}a & b \\ 0 & 0\end{array}\right]= \left[\begin{array}{cc} 0 & -b \\ c & 0\end{array}\right][/tex]
That can be written as -bA_2 + cA_3. The first column is [0 -b c 0]. Yes, that's exactly what you did and exactly what you got!
Apparently you got this in while I was typing my response:
A little more calculation: [itex]L(p(x))= (3a)x^2+ bx+ (b+c)[/itex]. Since a, b, c can be any real numbers, 3a, b, and b+ c can be any real numbers. The range is just P_3 itself.
Notice, by the way, that the kernel of L is all polynomials in P_3 such that [itex]L(p)= 3ax^2+ bx+ b+c= 0[/itex]. That requires that 3a= 0, b= 0, b+c= 0 so a= b= c= 0. The kernel is just {0}. Notice that the sum of the dimensions of the Kernel and Image is 3+ 0= 3, the dimension of P_3. It is, in general, true that if L:V->W, then the dimension of the kernel of L plus the dimension of the image of L is equal to the dimension of V.
First I want to thank you for your very thorough reply, which was very helpful.
I have one last issue: I want to try and find the kernel of L(p(x)) = p(0)*x+p(1). What I did was:
ker L is L(p(x)) = p(0)*x+p(1) = c*x + (a+b+c) = 0. So all the polynomials that makes c*x + (a+b+c) = 0 is the kernel of L. Since c = 0, I get that a = -b - is this correct?
Again, thank you both for taking the time to help.
Exactly right.
FAQ: Conceptual questions on linear algebra
What is linear algebra?
Linear algebra is a branch of mathematics that deals with the study of linear equations, linear transformations, and their properties. It involves the use of matrices and vectors to solve problems related to systems of linear equations.
What are the applications of linear algebra?
Linear algebra has a wide range of applications in various fields such as physics, engineering, computer science, economics, and statistics. It is used to solve optimization problems, analyze data, and model real-world situations.
What are the basic concepts in linear algebra?
The basic concepts in linear algebra include vectors, matrices, linear transformations, systems of linear equations, eigenvalues and eigenvectors, and determinants. These concepts are used to represent and solve problems related to linear equations and transformations.
How is linear algebra related to other branches of mathematics?
Linear algebra is closely related to other branches of mathematics such as calculus, differential equations, and geometry. It provides a foundation for these branches and is used in their applications.
What are some common challenges in learning linear algebra?
Some common challenges in learning linear algebra include understanding abstract concepts, visualizing high-dimensional spaces, and mastering matrix operations. It also requires strong algebraic skills and the ability to think logically and analytically.
