Conceptual questions on sound/waves
  • Thread starter chops369
  • Tags
    Conceptual
In summary: Longitudinal_wave.In summary, the child's velocity is greatest mid-way on the way up during simple harmonic motion. The buoy in the ocean is an example of simple harmonic motion since its movement is repeated. The wave created by the falling glacier is a transverse wave, as it has a distinct crest and trough, while a longitudinal wave involves varied compression.
chops369
56
1. A child is swinging in simple harmonic motion. Where in his swing is the velocity the greatest? (Top, bottom, mid-way on the way up, or mid-way on the way down.)
2. A buoy in the ocean is bobbing up and down repeatedly. Explain why this is or isn't an example of simple harmonic motion.
3. A piece of a glacier falls into the ocean creating a large wave. What type of wave is this and how do you know? (Transverse or longitudinal)
N/A
1. I think that the velocity is greatest mid-way on the way up, but I'm not too sure.
2. I think that the buoy in the ocean is an example of simple harmonic motion since its movement is repeated.
3. Well, I know it's a transverse wave, but I don't know how to explain why. I would imagine that it's transverse since it has a distinct crest and trough, and because longitudinal has to do with varied compression.
1. The child is undergoing harmonic motion between the extremes of potential energy at the top and kinetic energy at the bottom of the swing. Where then is tangential velocity the greatest? If you were just looking at the vertical component of velocity, then where would it appear greatest?
2. What is the buoy doing? Following the surface of the water? Is the water experiencing harmonic motion?
3. Consider:
http://en.wikipedia.org/wiki/Transverse_wave
1. You are correct, the velocity is greatest at the mid-way point on the way up in simple harmonic motion. This is because at this point, the restoring force is at its maximum, resulting in the highest velocity.
2. Yes, the buoy in the ocean is an example of simple harmonic motion. This is because its movement is repetitive and can be described by a sinusoidal function, which is a characteristic of simple harmonic motion.
3. The wave created by the falling glacier is a transverse wave. This can be determined by the direction of the wave's oscillations, which are perpendicular to the direction of energy transfer. In longitudinal waves, the oscillations are parallel to the direction of energy transfer. Additionally, transverse waves have distinct crests and troughs, as you mentioned, while longitudinal waves have areas of compression and rarefaction.
Related to Conceptual questions on sound/waves
1. What is the difference between sound and waves?
Sound and waves are closely related but have distinct differences. Sound is a type of wave that carries energy through vibrations in matter, such as air or water. Waves, on the other hand, are disturbances that transfer energy through a medium. Sound is a type of mechanical wave, meaning it requires a medium to travel through, while waves can also be electromagnetic, like light.
2. How does sound travel through different mediums?
Sound travels through different mediums by causing the particles in the medium to vibrate. The particles then transfer this vibration to neighboring particles, creating a wave that travels through the medium. The speed of sound depends on the density and elasticity of the medium, with sound traveling faster through denser and more elastic materials.
3. What is the relationship between frequency and pitch in sound?
Frequency and pitch are closely related in sound. Frequency refers to the number of vibrations or cycles of a sound wave per second, measured in Hertz (Hz). Pitch, on the other hand, is how high or low a sound is perceived by the human ear. Higher frequency sound waves are perceived as higher pitch, while lower frequency sound waves are perceived as lower pitch.
4. How does the Doppler Effect affect sound waves?
The Doppler Effect is the change in frequency of a sound wave due to the movement of the source of the wave or the observer. When a source of sound is moving towards an observer, the frequency of the sound waves increases, resulting in a higher pitch. Conversely, when the source is moving away, the frequency decreases, resulting in a lower pitch.
5. How do sound waves interact with each other?
When two or more sound waves interact, they can either combine or cancel each other out. This is known as superposition. If the waves have the same frequency and are in phase (peaks and troughs align), they will combine and create a louder sound. If they have opposite phases, they will cancel each other out, resulting in silence. This phenomenon is used in noise-cancelling technology to reduce unwanted sounds.
