Concrete contrast between local and nonlocal hidden variable
In summary: The probability that Alice measures spin-down depends only on \lambda and...The probability that both Alice and Bob measure spin-up depends only on \lambda and...The probability that both Alice and Bob measure spin-down depends only on \lambda and...The probability that either Alice or Bob measures spin-up or spin-down depends only on \lambda.But what you are saying contradicts this.The problem, if any, is that a probability is associated to the hidden variables ##\lambda##. When you see probabilities ##P(a,b,\lambda)##The first thing which comes to you is: how could i sum them to get P(a,
ObjectivelyRational
150
Can someone concretize the difference between a "hypothetical reality" where hidden variables are local and hidden variables are nonlocal in the following context:
Some physical event occurs involving particles A and B (which are/become entangled and will exhibit correlations) at time T and location X. Insofar as any hidden variables exist at this time, they let us assume they are local (whatever that means) as A and B are local to one another at X as must also be any attributes or properties thereof.
At another time or times TA and TB (same or different depending on the reference frame) each particle is respectively measured at locations XA and XB (for example at locations at distances in opposite directions).
Regardless of who is correct about reality, what does one mean when one claims "hidden variables are local" and consequently what would one mean when one says "No, hidden variables are not local, they are nonlocal"?
When we talk about a "local hidden variable theory", it should be parsed as "local [hidden variable theory]", not "[local hidden variable] theory". In other words, it is the model that is local, not the hidden variables. In a local model, signals cannot travel at superluminal speeds. In the context of Bell's theorem, this means that we assume that Alice's detector settings cannot influence the results at Bob's detector, and vice versa (because space-like separation of events is assumed). In a non-local model, such an influence is allowed.
Likes Demystifier
In another thread i recall that Bell wrote the conditionof locality
##P(a,b,\lambda) = P(a,\lambda) P(b,\lambda)##
Here a and b are the result of measurements by distant devices and lambda is the hidden variable. here ##P(a,\lambda)## is not the probabilité to get "a" knowing lamda (if it were a hidden variable it would be 1) but the probability that in the measurement we get a and ##\lambda##
I asked how this property is related with the speed of light or with the past light cones. Have you an idea?
Thanks.
The probability is different to the wavefunction, right? Shouldn't the condition for locality be written in a different way if the hidden variable is variable of the wavefunction?
The "problem", if any, is that a probability is associated to the hidden variables ##\lambda##. When you see probabilities ##P(a,b,\lambda)##
The first thing which comes to you is: how could i sum them to get P(a,b)?
It is the same thing with rhe Young slits. If I give you the probability for each slit you will wonder how to mix them to get the interference pattern. And you will get formulas violated by experiments.
Things might be different if a complex number ##C(a,b,\lambda)## was associated. It might also be a quaternion (proposed by Joy Christian)
What Bell's theorem precludes is to use local hidden variables with probabilities not local variables.
Yes, that is what I was wondering. It's not the hidden variables per se that are disallowed, but the assignment of such variables to a classical probability.
There is a disproof of Bell's theorem by Joy Christian. He is not mainstream.
He is mainly criticised because he associates quaternions to the hidden variables instead of positive numbers (probabilities).
When he does so he find another inequality which is not violated by the experiments.
You can see here how he is appreciated by the physics community
Indeed he is not mainstream.
No, he is mainly critizised because his (unpublished) papers are complete gibberish. Since you linked to Motl's blog, let me link to an even more entertaining blog post by MIT professsor Scott Aaronson: http://www.scottaaronson.com/blog/?p=1028
Likes Markus Hanke
Oh dear, that does not read well. Are here are any other formulations that assign lambda to the wavefunction rather than to the probability?
Christian's ideas are not rejected because they are not mainstream. They are rejected because they are nonsense. Just my opinion (and that of just about everyone who has looked into it).
I don't understand what that means. In the EPR experiment, [itex]\lambda[/itex] is supposed to represent facts about the twin pair that are true at the time they are created. There is no assumption about what [itex]\lambda[/itex] is, whether it's a real number or a quaternion or whatever. But the assumption is that:
  1. The probability that Alice measures spin-up depends only on [itex]\lambda[/itex] and facts about Alice's detector.
  2. The probability that Bob measures spin-up depends only on [itex]\lambda[/itex] and facts about Bob's detector.
  3. There is some probability distribution governing the possible values of [itex]\lambda[/itex].
Now, what is interesting (to me, anyway) is that quantum amplitudes do work exactly like Bell assumed probabilities work. If we let
[itex]\Psi(\alpha, \beta)[/itex] = the probability amplitude that Alice and Bob will both measure spin-up, given that Alice's detector has setting [itex]\alpha[/itex] and Bob's detector has setting [itex]\beta[/itex].
For the spin-1/2 anti-correlated twin pair version of EPR, the quantum prediction for this amplitude is:
[itex]\Psi(\alpha, \beta) = \frac{1}{\sqrt{2}} sin(\frac{\beta- \alpha}{2})[/itex]
Then we can find a "hidden variable" explanation for this amplitude:
[itex]\Psi(\alpha, \beta) = \sum_{\lambda} \psi(\lambda) \psi_A(\alpha, \lambda) \psi_B(\beta, \lambda)[/itex]
This hidden variable model is just this:
  1. [itex]\lambda[/itex] has two possible values: [itex]0[/itex] and [itex]\pi[/itex]
  2. [itex]\psi(0) = \frac{1}{\sqrt{2}}[/itex]
  3. [itex]\psi(\pi) = -\frac{1}{\sqrt{2}}[/itex]
  4. [itex]\psi_A(\alpha, \lambda) = cos(\frac{\alpha - \lambda}{2})[/itex]
  5. [itex]\psi_B(\beta, \lambda) = -sin(\frac{\beta - \lambda}{2})[/itex]
With these choices, we compute:
[itex]\Psi(\alpha, \beta) = \frac{1}{\sqrt{2}} (- cos(\frac{\alpha}{2}) sin(\frac{\beta}{2}) + cos(\frac{\alpha - \pi}{2}) sin(\frac{\beta - \pi}{2}))[/itex]
[itex]= \frac{1}{\sqrt{2}} sin(\frac{\beta- \alpha}{2})[/itex]
Then we square the amplitude [itex]\Psi(\alpha, \beta)[/itex] to get the appropriate probability: [itex]\frac{1}{2} sin^2(\frac{\beta- \alpha}{2})[/itex]
So in a sense, probability amplitudes for QM work like we would expect probabilities to work.
Likes Jilang
Yes, that's exactly what I was asking. It is interesting to me too!
You are right but it is not what i said.
It is not suggested that ##\lambda## could be a quaternion or something like that.
In the Bell machinery there is a map p from ##\Lambda## to [0 1]
This map is supposed to sum to 1. to verify the locality condition. More than that, when integrated it is supposed to give the statistial frequencies. And this does not succeed.
It is not surprising. Suppose that these hidden variables are physical. QM
tells us that waves of probabilities are not the good tool. that amplitudes of probabilities are more useful.
So the idea would be to map (i call this map m) ##\Lambda## to another set of numbers.
We could also have ##m(a,b,\lambda) = m(a,\lambda) m(b,\lambda)## that is locality. and so on
Of course this would need a way to get the frequencies at the end.
Edit: in your model what is the value of ##\psi(a,b,\lambda)##
It's [itex]-\frac{1}{\sqrt{2}} cos(\frac{a- \lambda}{2}) sin(\frac{b- \lambda}{2})[/itex]
I think that a hidden variable model has to explain how the knowledge of the variable gives you the outcomes. As ##\lambda## may be a couple of number, i would have thought that ##\lambda = (1,-1)## would give a = up and b = down and so on.
With this model the hidden variable is exactly the unknown (hidden) outcome that you will observe in the future!
Of course this model is contextual.
That's a misconception about Bell's argument. It's not necessary to assume that the hidden variable uniquely determines the outcomes. What Bell assumed was that for Alice's measurement of her particle's spin, the most complete information about the future outcome must come from local variables: Facts about Alice's detector + facts about her particle. So the probability of her measuring spin-up is assumed to be of the form:
[itex]P_A(\sigma_p, \sigma_a)[/itex]
where [itex]\sigma_p[/itex] is the state of the particle, and [itex]\sigma_a[/itex] is the state of Alice's detector. It is not necessary to assume that the outcome is determined by these variables. The outcome might be random, but with probabilities affected by [itex]\sigma_p[/itex] and [itex]\sigma_a[/itex]. However, in the EPR experiment, there is perfect correlation between Alice's result and Bob's result. Perfectly correlation is not possible unless the outcome is deterministic.
I should say that Bell's notion of a local model allows perfect correlation only if the outcome of measurements is deterministic. Nondeterministic nonlocal interactions can bring about perfect correlations.
Wiki says:
hidden variable theories were espoused by some physicists who argued that the state of a physical system, as formulated by quantum mechanics, does not give a complete description for the system; i.e., that quantum mechanics is ultimately incomplete, and that a complete theory would provide descriptive categories to account for all observable behavior and thus avoid any indeterminism
Maybe you do not agree?
The aim is to avoid indeterminism.
In a hidden variable theory the outcomes have to be determined.
"It’s as if someone announced his revolutionary discovery that P=NP implies N=1, and then critics soberly replied that, no, the equation P=NP can also be solved by P=0."
:biggrin::biggrin::biggrin:
Related to Concrete contrast between local and nonlocal hidden variable
1. What is the difference between local and nonlocal hidden variables?
The main difference between local and nonlocal hidden variables is the scope of their influence. Local hidden variables are only able to affect the outcome of a single particle or system, while nonlocal hidden variables can influence the outcomes of multiple particles or systems that are entangled.
2. How does the concept of hidden variables challenge the principles of quantum mechanics?
The concept of hidden variables challenges the principles of quantum mechanics because it suggests that there are underlying, deterministic variables that determine the outcome of quantum experiments. This goes against the probabilistic nature of quantum mechanics and the idea that particles do not have definite properties until they are observed.
3. What evidence supports the existence of nonlocal hidden variables?
One of the main pieces of evidence for nonlocal hidden variables is the Bell test experiments, which have shown correlations between entangled particles that cannot be explained by local hidden variables. Additionally, the violation of Bell's inequality further supports the idea of nonlocal hidden variables.
4. How does the concrete contrast between local and nonlocal hidden variables impact our understanding of quantum mechanics?
The concrete contrast between local and nonlocal hidden variables highlights the tension between the deterministic nature of classical physics and the probabilistic nature of quantum mechanics. It also raises questions about the true nature of reality and whether there are hidden variables that govern the behavior of particles.
5. Are there any practical implications of the concrete contrast between local and nonlocal hidden variables?
While the concept of hidden variables does not have direct practical implications, understanding the differences between local and nonlocal hidden variables can help us better understand the principles of quantum mechanics and potentially lead to advancements in quantum technologies.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
