MHB Condition for A Quartic Equation to have a Real Root
  • Thread starter Thread starter anemone
    Condition Root
anemone
MHB
POTW Director
Show $20a^2+20b^2+5c^2\ge 64$ if $y=x^4+ax^3+bx^2+cx+4$ has a real root.
Mathematics news on Phys.org
Made an oopsie! (Crying)
-Dan
Solution of other:
Note that $x=0$ is not a solution for $x^4+ax^3+bx^2+cx+4=0$.
$ax^3+bx^2+cx=-(x^4+4)\\(ax^3+bx^2+cx)^2=-(x^4+4)^2\\\left(2a\dfrac{x^3}{2}+2b\dfrac{x^2}{2}+cx \right)=-(x^4+4)^2 \le (4a^2+4b^2+c^2)\left(\dfrac{x^6}{4}+\dfrac{x^4}{4}+x^2\right)$
by the CauchySchwarz inequality
This gives
$4a^2+4b^2+c^2\ge \dfrac{4(x^4+4)^2}{x^6+x^4+4x^2}$
Let $t=x^2$, now, we have to prove $\dfrac{4(t^2+4)^2}{t^3+t^2+4t}\ge \dfrac{64}{5}$, i.e. $\dfrac{(t^2+4)^2}{t^3+t^2+4t}\ge \dfrac{16}{5}$.
This is true since $\dfrac{(t^2+4)^2}{t^3+t^2+4t}\ge \dfrac{16}{5}$ implies $5(t^4+8t^2+16)\ge 16t^3+16t^2+64t$, or $(t-2)^2(5t^2+4t+20)\ge 0$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
