Conditional Binomial Distribution
In summary, the probability that at least 2 of the stations have failed is (certain failure - (C(20,1).1^1*.9^9)/(1-.9^10)) = (certain failure - p(only one failure))
mrmt
Hi guys,
I can't get my head around this, if anyone could help that would be great.
"A robotic assembly line contains 20 stations. Suppose that the probability
that each individual station will fail is 0.3 and that the stations fail indepen-
dently of each other. Given that at least one of the stations has failed, what is
the probability that at least 2 of the stations have failed?"
Binomial distribution as:
fixed no. of identical trials
only 2 outcomes (success/failure)
the trials are independent
Slightly confusing wording, but if we call a "success" failure of a station, what is:
P(X≥2 l X≥1) ?
First I played around with just a reduced sample space i.e. for X≥2 out of the original 20 stations give that X≥1 already, would mean that X≥1 out of the remaining 19? i.e. 1-P(X=0)
(For the above I assumed that although the wording says "at least one station" has already failed, that would have to mean "only one station has failed" as if any more that one station had failed already the probability that X≥2 would be 1 (a certainty).)
I've seen two other similar examples floating around the web, one with
P(X≥2)/P(X≥1)
and another I still can't understand: (figures changed to suit this problem, wording unchanged)
"failure has occurred it is no longer just a possibility
the binomial from 0 to n C(20,s).7^(20-s).3^s no longer applies s the number of failures
since failure is known to have happened we exclude .7^20
we are in that bleak place where success is impossible probability (1 - .7^20) which is parcelled out among the various possibilities of failure to sum to one. We scale these by dividing through by (1 - .7^20)
so the probability of two or more failures is (certain failure - (C(20,1).1^1*.9^9)/(1-.9^10)) = (certain failure - p(only one failure))
(1 - (C(20,1).3^1*.7^19)/(1-.7^20)"
Any help would be great
Cheers
To find [itex] P(X \ge 2 | X \ge 1) [/itex] by "first principles" it is correct to do what you are attempting, namely to visualize the probability space defined by the restriction [itex] X \ge 1 [/itex] as "the space of all possible outcomes". However, I think it is simpler to apply Bayes formula to this problem (and thus do all the calculations in the original probability space).
[itex] P(X \ge 2 | X \ge 1) [/itex] = [itex] P( (X \ge 2)[/itex] and [itex] (X \ge 1))/ P(X \ge 1) [/itex] = [itex] P(X \ge 2)/ P(X \ge 1) [/itex].
If you want to visualize the probability space defined by the restriction [itex] X \ge 1 [/itex], visualize the binomial PDF. The restriction is going to "throw out" the possibility of [itex] X = 0 [/itex]. If you look at the values that are left, the sum of their probabilities will add up to less than 1. They add up to [itex] 1 - P(X = 0) [/itex]. How can you fix that? You can divide them all by [itex] 1 - P(X= 0) [/itex] = [itex] P(X \ge 1) [/itex]. This gives the new PDF for the events in the probability space defined by [itex] X \ge 1 [/itex]. The probability for the event [itex] X \ge 2 [/itex] in the revised PDF is found by summing the probabilities corresponding to that event in the orginal probability space, except that each probability is "inflated" by dividing it by [itex] P(X \ge 1) [/itex].
Stephen,
That's still slowly sinking in - I think I need more coffee
To be completely honest my brain is stuck on how we go from here:
= P((X≥2) and (X≥1))/P(X≥1)
to here:
= P(X≥2)/P(X≥1).
I know that's 101 somewhere but my brain just won't work - it's been something that's been bugging me for days!
Thank you
to here:
= P(X≥2)/P(X≥1).
The event [itex] X \ge 2 [/itex] is the same event as the event [itex] X \ge 2 [/itex] and [itex] X \ge 1 [/itex]. If you know [itex] X \ge 2 [/itex], it is superflous to say [itex] X \ge 1 [/itex].
Abstractly, if [itex] A \subset B [/itex] then [itex] (A \cap B) = A [/itex] so [itex] P(A \cap B) = P(A) [/itex].
Related to Conditional Binomial Distribution
1. What is the Conditional Binomial Distribution?
The Conditional Binomial Distribution is a probability distribution that describes the likelihood of a certain number of successes in a fixed number of trials, given that the probability of success in each trial is constant.
2. How is the Conditional Binomial Distribution different from the regular Binomial Distribution?
The regular Binomial Distribution assumes that the probability of success remains constant throughout all trials. In contrast, the Conditional Binomial Distribution takes into account the possibility of varying probabilities of success in different trials.
3. What is the formula for calculating the Conditional Binomial Distribution?
The formula for calculating the Conditional Binomial Distribution is P(X=x|n,p) = (n C x) * p^x * (1-p)^(n-x), where X is the number of successes, n is the number of trials, and p is the probability of success in each trial.
4. What is the practical application of the Conditional Binomial Distribution?
The Conditional Binomial Distribution is commonly used in areas such as quality control, where the probability of success may vary in different production runs. It can also be used in medical research to analyze the effectiveness of a treatment in different groups of patients.
5. How can I interpret the results of a Conditional Binomial Distribution calculation?
The results of a Conditional Binomial Distribution calculation will give the probability of obtaining a specific number of successes in a fixed number of trials, given the probability of success in each trial. This information can be used to make decisions or predictions based on the likelihood of success in a given scenario.
