Conditional Expectation Problem
In summary, the problem involves calculating the conditional expectation and mean squared error for predicting Y with and without first observing X, and then using these values to find the maximum value of c that minimizes the total loss.
ixtabai
Suppose that X and Y have a continuous joint distribution with joint pdf given by
f (x, y) = { x + y for 0 ≤ x ≤ 1 and 0 ≤ y ≤ 1
0 otherwise.
Suppose that a person can pay a cost c for the opportunity of observing the value of
X before predicting the value of Y or can simply predict the value of Y without first observing the value of X . If the total loss is considered to be the cost c plus the mean square error (MSE) of the predicted value, what is the maximum value of c that one
should be willing to pay?
Conditional Expectation: E[Y given X=x] and E[C]
Broke the problem into 2 parts: Part 1 is the Conditional Expectation of predicting Y by first observing X; and Part 2 simply predicting Y
1. Found the Conditional Expectation of Y given X to be 2/3 and the MMSE (Variance) 1/18
2. Found the Expectation of Y to be 7/12 and MMSE (Variance) 11/144
Given this is even the way to go I'm stuck as to where to go next.
In the problem is says Total Loss = c + MMSE Could this be TL= c + 19/144? This can't be this simple...
Thanks for your help.
Hello,
Thank you for your post. It seems like you have made some progress in solving this problem. However, there are a few things that can be clarified and improved upon in your solution.
Firstly, when calculating the conditional expectation of Y given X, you should use the formula E[Y|X] = ∫y*f(y|x)dy, where f(y|x) is the conditional pdf of Y given X. In this case, the conditional pdf is simply (x+y), as given in the problem. Therefore, the conditional expectation becomes E[Y|X] = ∫y*(x+y)dy from 0 to 1, which evaluates to (x+2)/3. This is the correct answer for Part 1 of your solution.
For Part 2, you have correctly found the expectation of Y, but the MMSE (mean squared error) should be calculated using the formula MMSE = E[(Y - E[Y])^2]. This evaluates to 11/144, which is the correct answer for Part 2.
Now, for the total loss, you are correct in thinking that it is TL = c + MMSE. However, you should use the values you have calculated for Part 1 and Part 2, which are (x+2)/3 and 11/144, respectively. Therefore, TL = c + (x+2)/3 + 11/144.
To find the maximum value of c that one should be willing to pay, you can set the derivative of TL with respect to c equal to 0 and solve for c. This will give you the optimal value of c that minimizes the total loss. I hope this helps! Let me know if you have any further questions.
Related to Conditional Expectation Problem
What is the Conditional Expectation Problem?
The Conditional Expectation Problem is a concept in probability and statistics that involves finding the expected value of a random variable given certain conditions or information. It is used to model uncertain situations and make predictions based on available data.
How is the Conditional Expectation Problem different from regular expectation?
The regular expectation, also known as the mean, is the average value of a random variable. The Conditional Expectation Problem takes into account additional information and conditions, such as other variables or events, to calculate a more specific expected value.
What is the purpose of the Conditional Expectation Problem in scientific research?
The Conditional Expectation Problem is commonly used in scientific research to make predictions and draw conclusions from data. It allows researchers to account for uncertainty and make more accurate estimations based on available information.
What are some real-world applications of the Conditional Expectation Problem?
The Conditional Expectation Problem has various applications in fields such as economics, finance, and engineering. For example, it can be used to predict stock market trends, estimate the success of a new product, or determine the optimal design for a structure.
What methods are commonly used to solve the Conditional Expectation Problem?
There are several methods for solving the Conditional Expectation Problem, including the law of total expectation, regression analysis, and machine learning algorithms. The choice of method depends on the specific problem and available data.
