MHB Conditional Probability - Faulty Plumbing
The discussion revolves around calculating probabilities related to clients assigned to three motels and the likelihood of faulty plumbing in their accommodations. The probability of faulty plumbing across all motels is calculated as 5.4%. The main confusion arises in determining the conditional probability that a client with faulty plumbing was assigned to Lakeview, denoted as P(L | F). The correct approach involves recognizing that P(L n F) is not equal to P(L)P(F) due to the dependence between the motel assignment and plumbing issues. Ultimately, the correct formula for P(L | F) is established as P(L | F) = P(L)P(F | L) / P(F).
newguy2
This question has been driving me crazy.
A large industrial firm uses three local motels to provide overnight accommodations for its clients.
From past experience it is known that 20% of the clients are assigned rooms at the Ramada Inn, 50% at the Sheraton and 30% at Lakeview. What is the probability that:
P(R) = 'Probability of being assigned to Ramada' = 20% = .20
P(S) = 'Probability of being assigned to Sheraton' = 50% = .50
P(L) = 'Probability of being assigned to Lakeview' = 30% = .30
P(F) = 'The probability of faulty plumbing' = ?
P(F | R) = 'Given room is at Ramada, prob. of faulty plumbing' = 5% = .05
P(F | S) = 'Given room is at Sheraton ...' = 4% = .04
P(F | L) = 'Given room is at Lakeview ...' = 8% = .08
Right?
So...:
A) What is the probability that a client will be assigned a room with faulty plumbing?
P(F) = P(R)P(F|R) + P(S)P(F|S) + P(L)P(F|L) = .20*.05 + .50*.04 + .30*.08 = 5.4% = .054
This makes sense...ok..
But...
B) What is the probability that a person with a room having faulty plumbing was assigned accommodations at Lakeview?
P(L | F) is what we are looking for, yes?
P(L | F) = 'Prob. of being assigned to LakeView, given room has faulty plumbing"
Right?
P(L | F) = P(L n F) / P(F) = P(F | L) P(F) / P(F) = P(F | L)...? This answer is not correct... how come?
P(L | F) = P(L n F) / P(F) = P(L) P(F) / P(F) = P(L)...? This answer is also not correct...
P(L | P(F|L)) = P(L n [F | L]) / P(F | L) = P(L)P(F | L) / P(F | L) = P(L) Still incorrect answer...
But this works...?
P(L | F) = P(L) P(F | L) / P(F) = correct answer?Please clarify all this for me.. What is happening.
Mathematics news on Phys.org
Hello, and welcome to MHB! (Wave)
I've moved your post into its own thread...this way the discussion will be all about your question only, and you'll be more likely to get help too. :)
P(F | L) = P(F n L) / P(L)P(L n F) = P(L | F) P(F)
P(F n L) = P(F | L) P(L)
P(L n F) = P(F n L)
P(L n F) = P(F | L) P(L)
P(F n L) = P(L | F) P(F)
Because P(L n F) != P(F | L) P(F)
it is P(L n F) = P(F | L) P(L)
or... P(L n F) = P(L | F) P(F)
Because P(L n F) != P(L) P(F), ? How come? Independence thing?
so P(L n F) = P(L) + P(F) - P(L u F) ??
I get this is probably not even valid, this was just experimenting trying to see it gave the correct answer
newguy said:
But this works...?
I under stand why this works now anyways, because:
P(L n F) = P(F | L) P(L) = P(L) P(F | L)
Right?
So...:
A) What is the probability that a client will be assigned a room with faulty plumbing?r
But...
Imagine 1000 clients. 20% of them, 200, are assigned to Ramada, 50% of them, 500, are assigned to Sheraton, and 30%, 300, are assigned to Lakeview.
Of the 200 assigned to Ramada, 5%, 10, have faulty plumbing. Of the 500 assigned to Sheraton, 4%, 20, have faulty plumbing. Of the 300 assigned to Lakeview, 8%, 24, have faulty plumbing. That is a total of 10+ 20+ 24= 54 or 54/1000= 0.054, 5.4% of the clients, have faulty plumbing.
Of the 54 people who had faulty plumbing, 24, so 24/54= 0.4444 or 44.44%, were assigned to Lakeview.
Right?
Yes, that is correct.
But this works...?
You seem to be assuming. when you write, for example, "P(L n F)= P(L)P(F)", that "faulty plumbing" is independent of which motel a client is assigned to- and that is clearly not true.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
