Conditions for integral domain to be a PID
In summary, the necessary conditions for R to be a PID are: 1) the existence of a greatest common divisor for any two elements a and b in R, and 2) the fact that every ascending chain in a PID will eventually stabilize. Condition #1 is necessary because it ensures that every ideal in R can be generated by a single element, which is a defining characteristic of PIDs. Condition #2 is necessary because it guarantees that every ideal in R has a maximal element, which is also a defining characteristic of PIDs. While condition #2 implies condition #1, the reverse is not necessarily true, as shown by the example of Z[x]. Therefore, both conditions are necessary for R to be a PID.
oblixps
38
Let R be an integral domain. Then R is a PID if the following 2 conditions hold:
1) any 2 elements [tex] a, b \in R [/tex] have a greatest common divisor which can be written as ra + sb for some [tex] r, s \in R [/tex].
2) If [tex] a_1, a_2, ... [/tex] are nonzero elements of R such that [tex] a_{i+1}|a_i [/tex] for all i, then there is a positive integer N such that [tex] a_n [/tex] is a unit times [tex] a_N [/tex] for all [tex] n \geq N [/tex].
Letting I be any ideal in R with the ordering [tex] x \leq y [/tex] iff y|x, condition #2 implies that each chain of elements in I has an upper bound and thus by Zorn's Lemma, there is a maximal element in I with respect to this ordering, namely, an element that divides every other element in I.
what i am having trouble understanding is why condition #1 is necessary. it seems that if we say a is the element in I that divides every other element, then can't we conclude that I = (a), since (a) is clearly in I and I is in (a) since every element x of I must be contained in (a)?
if there was another such element b in I not equal to a, then since b and a are both maximal elements with respect to this ordering, a|b and b|a which means b = ac for some c and a = bd for some d, which implies that cd = 1 since R is an integral domain. Thus c and d are units so a and b are associates so (a) = (b). Why is the condition that the gcd of a and b exist necessary for R to be a PID?
Disclaimer: I'm very bad at algebra but I believe attempting to answer your question may enlighten us both. Let us try! (Handshake)
I assume that by PID you mean principal ideal domain. The definition of PID is that every ideal is a principal ideal. In other words, this means that every ideal is generated by a multiple of one element.
That being said, I do not understand your conditions. The first states that you have an euclidean division algorithm such that you can have a greatest common divisor, whereas the second appears to be, loosely speaking, mentioning that every ascending chain in a PID will eventually stabilize, i.e., be essentially the same.
I do not see these as necessary conditions for an integral domain to be a PID. Where did you find this definition?
this was actually an exercise in Dummit and Foote. in case you have a copy, it is #4 in section 8.2.
after thinking about it some more, it seems to me that condition #1 follows from condition #2 by taking the ideal I = (a, b) generated by 2 elements a and b. Then from the argument above using condition #2 and Zorn's Lemma, we have I = (a, b) = (c) for some element c that divides all elements of I. But then, it is easy to see from here that gcd(a, b) exists and c = gcd(a, b). We can thus write c = ra + sb for some r, s in R.
so unless I made a mistake somewhere, it seems to me that condition #1 is really not necessary and I'm not sure why it was part of the exercise.
no. condition #2 is not enough.
consider the ring Z[x], the ring of polynomials in x with integer coefficients.
suppose we have a sequence of polynomials:
p1, p2,..., with pj+1|pj for each j, with p1 ≠ 0
well p1 is of finite degree (since its non-zero), so it only has a finite number of irreducible factors. so the degree of the pj's can only go down a finite number of times.
but, you might object: maybe there's an infinite string of pj's where the degree "stays the same". but such a string must occur "at the tail" of the sequence. in that case, since the pj all have the same degree after pN, then for such pj, if:
pj(x) = k(x)pj+1(x), then deg(k) = 0, that is k(x) is a constant, k(x) = aj.
this in turn gives a sequence of integers of the leading coefficients of the pN+i:
a1​, a2,... where ai+1|ai.
now Z IS a PID, and it is clear that we do have some M for which ai = ±a for all i greater than or equal to M.
so, going back to our original sequence of polynomials, after N+M terms (at most), we have pj = ±pN+M, for all j greater than or equal to N+M. so condition #2 is satisfied for Z[x].
HOWEVER, i defy you to find two polynomials in Z[x] such that:
2p(x) + xq(x) = 1
(it is clear that gcd(2,x) = 1, the only divisors of 2 are 1 and 2 (up to sign, that is multiplication by a unit), and 2 does not divide x).
what went wrong? well it turns out the the only element c with c|2 and c|x is 1 (or -1). but (1) = Z[x] (the entire ring), which is not the same as (2,x). in short: it may be that if c = gcd(a,b), that the ideal generated by c is a LOT bigger than the ideal generated by (a,b), because c may not be a R-linear combination of a and b.
THAT is why you need condition #1.
thanks for the counterexample! that helped me see what could happen if that condition wasn't met.
i'm still trying to figure out what went wrong in my argument though. By using Zorn's Lemma, i was able to find an element a in I that divides every element in I so it follows that I is contained in (a). but since a itself is contained in I, we also have that (a) is contained in I and thus I = (a). so it seems to follow that every ideal I can be generated by this "minimal" divisible element.
you've shown that Z[x] satisfies condition #2 so from my above argument, every ideal in Z[x] should have such a minimal divisible element. looking at (2, x) in Z[x] however, I see that the only possible element that could divide every element in (2, x) is 1 (or -1). but (2, x) doesn't contain 1. so I'm suspecting that my argument with Zorn's lemma wasn't careful enough, but i can't seem to figure out where my logic went wrong. could you help me find where I went wrong in my argument?
your argument uses condition #1 in an essential way, you assert:
c = ra + sb (GCD domains in which this is true are called bezout domains. not ALL GCD domains are bezout domains).
you showed that there does indeed exist an element c such that any ideal (a,b) is contained in (c).
but if R is not principal, then not every ideal is of the form (c).
condition #2 is also known as "the ascending chain condition on principal ideals" (ACCP). we can summarize this like so:
A) GCD domain + ACCP = UFD
B) bezout domain + ACCP = PID
as in my counter-example, any UFD which is NOT a PID will satisfy condition 2, but will not satisfy condition 1.
the condition d = gcd(a,b) = ra + sb is exactly what we need to conclude (a,b) = (d).
FAQ: Conditions for integral domain to be a PID
1. What is an integral domain?
An integral domain is a mathematical concept that refers to a commutative ring with no zero divisors. This means that in an integral domain, if the product of two nonzero elements is equal to zero, then both elements must be equal to zero.
2. What does PID stand for?
PID stands for "principal ideal domain". It is a special type of integral domain where every ideal can be generated by a single element, called a "principal element".
3. What are the conditions for an integral domain to be a PID?
In order for an integral domain to be a PID, it must satisfy two conditions: every ideal must be a principal ideal, and the domain must be Noetherian (meaning that every ascending chain of ideals eventually stabilizes).
4. How do I know if a given integral domain is a PID?
To determine if a given integral domain is a PID, you can check if it satisfies the two conditions mentioned above: every ideal is a principal ideal, and the domain is Noetherian. If both conditions are met, then the domain is a PID.
5. Why is it important for an integral domain to be a PID?
PIDs are important in abstract algebra and number theory because they have nice properties that make them easier to work with. For example, in a PID, factorization into irreducible elements is unique, making it easier to solve equations and prove theorems. PIDs also have applications in coding theory, cryptography, and other fields.
