Conditions for translational invariance in space/time for a 2-point function?
In summary, the conditions for space/time translational invariance in a two point function are that the lagrangian density must not depend explicitly on x^mu and must only depend on fields and their space-time derivatives up to a finite order. This is true for free-field Green's functions in linear differential equations with constant coefficients and homogeneous boundary conditions. However, quadratic terms that mix fields can cause problems, such as in superconductivity, and can be resolved through using Bogolubov-Valatin transformation. Linear response theory, also known as Kubo formalism, studies the near equilibrium properties of a system under the influence of a small external field.
AJS2011
Hi,
Assume the following action:
[tex] \int d^4 x L[\phi,A]+ \int d^4 x A_{\mu} (x) J^{\mu}(x)[/tex]
What are the conditions on the form of action to have space/time translational invariance for a two point function:
[tex] \left\langle J_{\mu}(x) J_{\nu}(y) \right\rangle = G_{\mu \nu}(x-y) [/tex]
or in general for a function of different fields
[tex] \left\langle \quad f_{\mu}[\phi(x),J(x),A(x)] f_{\nu}[\phi(y),J(y),A(y)] \quad \right\rangle = H_{\mu \nu}(x-y) [/tex]
I appreciate any help in this regard.
Thanks a lot in advance!
From the top of my head, the lagrangian density must not depend explicitely of [itex] x^{\mu} [/tex]. That would spoil translation invariance. I think that this is enough to ensure the invariance of the 2-point function (connected Green functional) wrt space-time translations.
Thanks, dextercioby! Based on what you say, the presence of of non-constant gauge fields will ruin the the translational invariance. However in calculations of the linear response theory to electromagnetic field I see that people have
[tex] \left\langle J_{\mu}(x) J_{\nu}(y) \right\rangle [/tex] where in momentum space they write it as
[tex] \left\langle J_{\mu}(p) J_{\nu}(-p) \right\rangle [/tex]
which obviously is true when we have translational invariance. I am confused!
I didn't say that. The Langrangian functional dependence must be of fields Q and their space-time deriviatives up to a finite order and only that, not directly of x, but rather indirectly, through the fields and their derivatives.
[tex] \mathcal{L} = \mathcal{L}\left(\left\{Q_{a}\right\}_{a=1}^{n}, \left\{\partial_{\mu_{1}}...\partial_{\mu_{k}}Q_a\right\}_{a=1}^{n}, \not{x}^{\not{\mu}}\right), \, k<\infty [/tex]
x-y is assiociated to the momentum p through the Fourier transformation which contains the exponential as [...]p(x-y)[...].
Thanks for the explanation! You are right. Well, I meant an external electromagnetic field for example. For magnetic fied in z direction for example in symmetric gauge we can have
[tex] A_{\mu}= \frac{B_0}{2}(0,y,-x,0)) \rightarrow \vec{B}= B_0 \hat{a}_z[/tex].
Then external A can cause the break down of translational invariance.
Well this means that translational invariance was assumed otherwise it should have been
[tex] \left\langle J_{\mu}(p) J_{\nu}(q) \right\rangle [/tex]
This current-current correlation appears in linear response of a system to external electromagnetic fields which technically as I said above because of being external breaks the invariance, which to me seems incompatible.
For linear differential equations with constant coefficients and homogeneous boundary conditions, then the Green's function are translationally invariant.
Then I think it's easy to see that quadratic terms without mixing, such as ADA or BDB for fields A and B and quadratic differential operator D, will produce free Green's functions that are translationally invariant, since the Green's function G is just the solution to such an equation: DG=1 (the homogeneous boundary conditions will be that the fields vanish on the hypersurface at the infinities of spacetime - this is true for vacuum although not for statistical backgrounds) just from the integration of Gaussians.
However, if you have quadratic terms that mix fields such as ADB or BDA, then I think you might have problems. Fortunately I've never seen such quadratic mixes before (is there a reason for that?).
Anyways, if you establish that the free-field Green's functions are translationally invariant, then I think you can establish that the interacting Green's functions are also translationally invariant, since the interacting ones are made up of products of the free-field ones. That should be the case intuitively, and I don't remember any interacting propagators that weren't translationally invariant either.
Also, what is linear response theory?
Thanks RedX!
In superconductivity such mixing terms appear, and the way around it is through using Bogolubov-Valatin transformation.
Linear response, aka Kubo formalism, studies near equilibrium properties of a system when a small external field is perturbing the system. For example, to study electrical conductivity of a system they apply an electric field and see what the current is due to that field. The term
"linear" reflects the assumption that the response of the system is proportional to the driving force that was assumed to be weak.
Related to Conditions for translational invariance in space/time for a 2-point function?
1. What is translational invariance in space/time?
Translational invariance in space/time refers to the property of a system or function remaining unchanged under shifts or translations in space or time. This means that the behavior or characteristics of the system or function are the same regardless of where or when they are observed.
2. How is translational invariance related to the 2-point function?
The 2-point function is a mathematical tool used to describe the correlation between two points in a system. For a system to exhibit translational invariance, the 2-point function must remain invariant under translations in space and time.
3. What are the conditions for translational invariance in space/time for a 2-point function?
The conditions for translational invariance in space/time for a 2-point function are that the function must be independent of the position and time of the points, and it must also be symmetric with respect to the points.
4. Can a system or function have translational invariance in only one dimension?
Yes, translational invariance can apply to one, two, or three dimensions. For example, a system may exhibit translational invariance in the x-direction but not in the y-direction.
5. Why is translational invariance an important concept in science?
Translational invariance is important because it allows us to make predictions and draw conclusions about a system or function based on its behavior in one location or time. It also simplifies mathematical calculations and analysis by reducing the number of variables that need to be considered.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
