Conditions on H and K if H ∪ K is a subgroup
In summary, to prove that if ##H \cup K## is a subgroup of ##G## then ##H \subseteq K## or ##K \subseteq H##, we can assume that ##H \cup K \le G## and then show that if neither H nor K is a subset of the other, it leads to a contradiction. This is because if ##H \cup K## is a subgroup, then ##hk \in H \cup K## for all ##h \in H## and ##k \in K##. Therefore, we can conclude that either ##h \in H## and ##k \in K##, or ##k \in H## and ##h \in K##, contradicting our
Mr Davis 97
1,462
44
Let H and K be subgroups of G. Prove that if ##H \cup K## is a subgroup of ##G## then ##H \subseteq K## or ##K \subseteq H##
Suppose that ##H \cup K \le G##. For contradiction, suppose that neither H nor K is a subset of the other. This implies that there exists an ##h \in H## that is not in ##K## and a ##k \in K## that is not in ##H##. Since ##H## and ##K## are individually subgroups, ##h^{-1} \in H## and ##k^{-1} \in K##. Now since ##h \in H \cup K## and ##k \in H \cup K##, we know that ##hk \in H \cup K##, since we supposed it's a subgroup. We have three cases to check: If ##hk \in (H \cap K)##, then ##(hk)k^{-1} = h \in K##, a contradiction. If ##hk \in (H \cup K) - H## then ##(hk)k^{-1} = h \in K##, a contradiction. If ##hk \in (H \cup K) - K## then ##h^{-1}(hk) = k \in H##, a contradiction.
I wouldn't say suppose here as it sounds as if it could be wrong. It is our given condition, i.e. we accept it as given truth. "... since ##H \cup K## is a subgroup." would be better.
I think you don't need the cases. Just look at ##hk##. It's either in ##H## in which case ##k## is as well, or vice versa for the other possibility. You can say w.l.o.g. ##hk \in H## (the problem is symmetric in ##H## and ##K##) and have only one case to consider.
Likes Mr Davis 97
Related to Conditions on H and K if H ∪ K is a subgroup
1. What is a subgroup?
A subgroup is a subset of a larger group that itself forms a group. In other words, it contains all the necessary elements and operations to be considered a group on its own.
2. How is a subgroup related to the original group?
A subgroup is a smaller version of the original group, with the same operations and structure. It is a subset of the original group that maintains the same properties and follows the same rules.
3. What is the significance of the union of two subgroups?
The union of two subgroups, in this case H and K, forms a larger subgroup that contains all the elements and operations of both H and K. This helps to simplify and streamline the structure of the overall group.
4. What conditions must be met for H and K to form a subgroup?
In order for H and K to form a subgroup, they must both be subgroups of the same larger group and they must have at least one common element. In addition, the operations of H and K must be closed under the larger group's operations.
5. How can the conditions on H and K be determined?
The conditions on H and K can be determined by checking if they fulfill the requirements for being a subgroup, as mentioned in the previous question. This includes checking for closure, associativity, identity, and inverses for both H and K within the larger group.
