mosawi
- 9
17) Let A = [1,2 ; -2,-5 ; 2,1 ; 1,-1 ; 1,-2] which is a 5x2 matrix (sorry I don't know how to code a matrix properly).
What conditions must be imposed on vector b for the overdetermined linear system Ax = b (both x and b have arrows on top) to be consistent?
An overtdetermined system - If m > n, then the linear system Ax = b is inconsistent for at least one vector b in ℝ^n.
If m > n (more rows than columns), in which case the column vectors of A cannot span ℝ^m (fewer vectors than the dimension of ℝ^m).
So, there is at least one vector b in ℝ^m that is not in the column space of A, and for that b the system A x = b is inconsistent by Theorem 4.7.1 which states A system of linear equations  is consistent if and only if b is in the column space of A.[STRIKE]So the conditions that must be imposed on b must be to zero out variables? I know this is wrong but I don't really know what to do?[/STRIKE]
******************UPDATE******************
I think I solved it guys, can someone check my solution and tell if its correct if not, what do I need to do to make it correct. I've attached the solution to this poste. Thanks.
