Conditions on the coefficients of conics equations
In summary, the equation Ax^2 + Cy^2 +Dx + Ey +F = 0 represents the general form of conic sections. By looking at the coefficients A and C, we can determine which type of conic section it represents: a circle if A=C, an ellipse if AC>0 and A does not equal C, a hyperbola if AC<0 and the coefficients have opposite signs, and a parabola if A=0 or C=0. The general form for a conic with axes at angles to the coordinate axes is Ax^2 + Bxy+ Cy^2 +Dx + Ey +F = 0.
cocoavi
I have been taught that the equation [tex] Ax^2 + Cy^2 +Dx + Ey +F = 0 [/tex] represents a general form of conics.
Then the conditions of the coefficients in the equation could identify which type of conics the equation represents...
Circle: A=C
Ellipse: A does not=C and AC>0
Hyperbola: AC<0 and if the coefficients have opposite signs
Parabola: A=0 OR C=0
The thing that I do not understand is why... I was wondering if anyone knows a way to explain the reasons to me?
I didn't knew about that but it's very interesting. Let's prove it for the circle. We are used to the equation of a circle of radius R centered at (a, b) to be
[tex](x-a)^2+(y-b)^2 = R^2[/tex]
right?
Ok, well if A = C, our cameleonic forumla becomes
[tex]Ax^2 + Ay^2 + Dx + Ey + F = 0 [/tex]
[tex]x^2 + y^2 + \frac{D}{A}x + \frac{E}{A}y + \frac{F}{A} = 0[/tex]
Now notice that
[tex](x + D/2A)^2 = x^2 + \frac{D}{A}x + (D/2A)^2[/tex]
and
[tex](y + E/2A)^2 = y^2 + \frac{E}{A}y + (E/2A)^2[/tex]
So
[tex]x^2 + y^2 + \frac{D}{A}x + \frac{E}{A}y + \frac{F}{A} = (x + D/2A)^2 + (y + E/2A)^2 - (D/2A)^2 - (E/2A)^2 + F/A = 0[/tex]
[tex](x + D/2A)^2 + (y + E/2A)^2 = (D/2A)^2 + (E/2A)^2 - F/A[/tex]
This is the equation of a circle centered at (-D/2A, -E/2A) and whose radius is [itex]\sqrt{(D/2A)^2 + (E/2A)^2 - F/A}[/itex]
The other proofs are probably similar.
:bugeye: whoa... You're really smart to be able to get all of those... but I'm very sorry to say that I don't think I understand it. When the tutor explained it was very simple, it's just that when I got home and started on the homework that I got all confused... :cry: And since I'm only starting on the conics stuff I don't think I would be able to go into more equation proofs. If it's not too rude to ask would it be alright if I get a more simple reason? Say for example the one that I know would be the parabola:
Since x-h=a(y-k)^2 is the equation for the vertical parabola, A in that conics equation would have to equal to 0 because there is no x^2 when you expand x-h=a(y-k)^2.
And since y-k=a(x-h)^2 is the equation for a horizontal parabola, C in that conics equation would have to equal to 0 because there is no y^2 when you expand y-k=a(x-h)^2.
I hope it's not too much of a problem I hope to get something simple like that.. and sorry again ><!
For a parabola, only one squared term is present, either on the x or y. The fact that there is only one squared term in that general form is what generates the parabola, which could be considered a function if the parabola is not turned on its side.
Think of the other three conic sections as consisting of two parts which open either towards each other (circle, ellipse) due to the x^2 and y^2 terms having the same signs or away from each other (hyperbola) due to the x^2 and y^2 terms having opposite signs. Since there are two parts to the other three conic sections, the equation that represent either of those three conic sections can't be considered as functions.
Strictly speaking [tex] Ax^2 + Cy^2 +Dx + Ey +F = 0 [/tex] is the general form for a conic section with axes parallel to the coordinate axes. A general conic can have axes at angles to the coordinate axes- that will give the general formula
[tex] Ax^2 + Bxy+ Cy^2 +Dx + Ey +F = 0 [/tex]
(Didn't you wonder why they skipped over B?)
ooh~ those helped me understand more ^^. Thank you!
Related to Conditions on the coefficients of conics equations
What are the conditions for a conic equation to represent a parabola?
For a conic equation to represent a parabola, the coefficient of the squared term (x^2 or y^2) must be non-zero and the coefficients of the linear terms (x or y) must be zero.
Can a conic equation represent a circle?
Yes, a conic equation can represent a circle if the squared terms (x^2 and y^2) have equal coefficients and there are no linear terms (x and y).
What are the conditions for a conic equation to represent an ellipse?
To represent an ellipse, a conic equation must have non-zero coefficients for both squared terms (x^2 and y^2) and the coefficients of these terms must have different signs.
How can I determine if a conic equation represents a hyperbola?
If a conic equation has squared terms with opposite signs (one positive and one negative) and non-zero coefficients, it represents a hyperbola.
What are the conditions for a conic equation to represent a degenerate conic?
A degenerate conic is a special case where the conic equation represents a single point, a line, or two intersecting lines. This occurs when the coefficient of the squared term is zero and the coefficients of the linear terms are non-zero (for a point), or when the coefficients of both squared terms are zero (for a line or two intersecting lines).
  • General Math
  • Differential Equations
