Condtion on transformation to solve the Dirac equation
In summary: PeroK Could you elaborate? I'm asking because I don't see how what you write adds up with the very next line in my professors reasoning, i.e.$$\begin{aligned}\left(\gamma^{\mu} \partial_{\mu}^\prime-m\right) \psi^{\prime}(x^\prime)\neq\left(\gamma^{\mu} \partial_{\mu}-m\right) S \psi(\Lambda x) \\\end{aligned}$$In summary, the conversation discusses the transformation laws of the Dirac equation and the Dirac field under Lorentz transformations. The first approach uses primed and unprimed variables to distinguish between the two
Markus Kahn
112
TL;DR Summary
Given a spinor ##\psi## that solved the Dirac equation and a Lorentz transformation ##x\mapsto x^\prime :=\Lambda^{-1}x## such that ##\psi^\prime (x^\prime)=S\psi(x)## I'd like to show that ##S## has to satisfy
$$\Lambda^\mu{}_\nu S^{-1}\gamma^\nu S = \gamma^\mu$$
for ##\psi^\prime (x^\prime)## to be a solution of the Dirac equation.
The problem is given in the summary.
My attempt: Assume that ##\psi^\prime (x^\prime)## is a solution of the Dirac equation in the primed frame, given the transformation ##x\mapsto x^\prime :=\Lambda^{-1}x## and ##\psi^\prime (x^\prime)=S\psi(x)##, we have
\begin{align*}
0&=(\gamma^\mu \partial_\mu^\prime - m)\psi^\prime (x^\prime) =(\gamma^\mu \partial_\mu^\prime - m)S\psi(x) \\
&=S(S^{-1}\gamma^\mu S \partial_\mu^\prime -m)\psi(x)\\
&=S({S^{-1}\gamma^\mu S \Lambda^{\nu}{}_\mu}\partial_\nu -m)\psi(x).
\end{align*}
For the last equation to reduce to the Dirac equation, and therefore make ##\psi(x)## a solution of the Dirac equation, we need
$${S^{-1}\gamma^\mu S \Lambda^{\nu}{}_\mu}=\gamma^\nu.$$
My Professor did something similar, but not quite the same and I have a hard time judging if what we do is truly equivalent or if I'm just running in circles...
My Professors explanation: We first note that ##\psi^\prime(x^\prime)=S\psi(x)## is equivalent to ##\psi^\prime(x) = S\psi(\Lambda x)##. With this we find
\begin{aligned}
0 &=\left(\gamma^{\mu} \partial_{\mu}-m\right) \psi^{\prime}(x)=\left(\gamma^{\mu} \partial_{\mu}-m\right) S \psi(\Lambda x) \\
&=\left(\gamma^{\nu} S \Lambda_{\nu}^{\mu} \partial_{\mu} \psi-S m \psi\right)(\Lambda x) \\
&=S\left(S^{-1} \gamma^{\nu} S \Lambda_{\nu}^{\mu} \partial_{\mu} \psi-\gamma^{\mu} \partial_{\mu} \psi\right)(\Lambda x) \\
&=S\left(\Lambda^{\mu}{}_{\nu} S^{-1} \gamma^{\nu} S-\gamma^{\mu}\right)\left(\partial_{\mu} \psi\right)(\Lambda x)
\end{aligned}
So the term in the bracket must vanish for invariance of the Dirac equation.
The issue I have with his approach is that I don't really understand the first step, i.e. I don't see why
$$0 =\left(\gamma^{\mu} \partial_{\mu}-m\right) \psi^{\prime}(x)$$
should hold.
should hold.
If you look at the working after this, what must be meant is:
$$0 =\left(\gamma^{\mu} \partial'_{\mu}-m\right) \psi^{\prime}(x')$$
Likes Markus Kahn and vanhees71
The transformation law is
$$\psi'(x')=S \psi(x)=S \psi(\Lambda x'),$$
if ##x'=\Lambda^{-1} x## with ##\Lambda## a proper orthochronous Lorentz transformation. So I'd prefer the first demonstration, which is much clearer in distinguishing the primed and unprimed quantities referring to the two different inertial reference frames.
Likes dextercioby and Markus Kahn
@PeroK Could you elaborate? I'm asking because I don't see how what you write adds up with the very next line in my professors reasoning, i.e.
$$\begin{aligned}
\end{aligned}
@vanhees71 Just to make sure, the part I labeled as "My attempt" has no circular reasoning and is sound? I'm asking because Peskin (and other places) explain it just like my Professor did, so I automatically assumed I'm making some kind of hidden assumption...
I think, it's sound and solid. The problem is with the primes in the argument of the field.
If you want to describe finally the transformation behavior of the quantized field, i.e., the field operators, it reads
$$\hat{U}(\Lambda) \psi(x) \hat{U}^{\dagger}(\lambda) = S \psi(\Lambda x).$$
Here ##\hat{U}(\Lambda)## is the unitary operator representing Lorentz transformations, and the transformation law describes a local realization of the Poincare group on the field operators, i.e., the field operators transform as the classical fields. That may trigger some textbook authors to use this notation also for the unquantized theory, but as I said, I prefer your notation. When I learned QFT this point confused me a lot until I understood the reason behind this somewhat less clear notation.
Likes Markus Kahn
$$\begin{aligned}
\end{aligned}
He has used ##x## to denote the variable in the transformed frame and ##\Lambda x## to denote the variable in the original frame. He's not using a prime on the spacetime coordinate or derivatives. He doesn't, as far as I can see, use any notation to distinguish between ##\partial## and ##\partial'##. He just uses the context.
He only uses a single prime on ##\psi## to indicate that he's starting in the transformed frame. That's the way some people think about these things! If it was up to me, I'd put primes everywhere.
PS
Your notation is ##x \ \rightarrow \ x' = \Lambda^{-1}x##.
His notation is ##\Lambda x \ \rightarrow \ x = \Lambda^{-1} \Lambda x##
Related to Condtion on transformation to solve the Dirac equation
1. What is the Dirac equation?
The Dirac equation is a relativistic wave equation that describes the behavior of spin-1/2 particles, such as electrons, in quantum mechanics. It was developed by physicist Paul Dirac in 1928.
2. What is the condition on transformation to solve the Dirac equation?
The condition on transformation to solve the Dirac equation is known as the Dirac equation invariance condition. This condition ensures that the equation remains unchanged under certain transformations, such as rotations and boosts, in order to maintain its physical meaning.
3. Why is it important to have a condition on transformation for the Dirac equation?
Having a condition on transformation for the Dirac equation is important because it allows us to properly describe the behavior of spin-1/2 particles in a consistent and meaningful way. Without this condition, the equation may not accurately reflect the physical reality of these particles.
4. How is the condition on transformation applied to solve the Dirac equation?
The condition on transformation is applied by imposing certain constraints on the mathematical form of the Dirac equation. This ensures that the equation remains invariant under transformations and leads to physically meaningful solutions.
5. Are there any limitations to the condition on transformation for the Dirac equation?
While the condition on transformation is necessary for solving the Dirac equation, it does have some limitations. For example, it does not account for the effects of external fields or interactions between particles, which may require additional conditions or modifications to the equation.
