Sahil Dev
- 21
Hi,
I shall be grateful if someone can throw light on the heat transfer processes taking place through in this very simple example.
Consider the attached image (pdf). See figure (c) which I have also marked in red block. It is pot lying on a hot plate.
I want to know the heat transfer processes taking place in this mechanism.
1) Firstly, the vessel is heated through the hot plate
2) Heat travels from the hot place to the bottom of the vessel
3) IS this process conduction that is taking place between the hot plate and the bottom of the vessel ?
4) Then the heat travels from the bottom of the vessel to the fluid (Assuming the vessel is filled with fluid). IS this process natural convection as the fluid rises up by buoyancy?
Are all my points 1,2,3,4 correct?
Thanks
Thanks
