Conduction of heat from metal to air
In summary, heat conduction is the process by which heat is transferred from a material with a higher temperature to one with a lower temperature. In the case of conduction of heat from metal to air, the metal is the hotter material and the air is the cooler material. This transfer of heat occurs through the collision of particles, such as atoms or molecules, in the material. The rate of heat conduction depends on factors such as the type of material, its temperature, and its physical properties. In general, metals are good conductors of heat, while air is a poor conductor. This means that the metal will transfer heat to the air more quickly than the air can absorb it, resulting in a decrease in the metal's temperature and an
Shehbaj singh
A typical example is a iron chair gets cold in winters and wooden chain not. We all know iron is more conductive but how this thing possible at molecular level of conduction of heat from metal to air. In general conduction I know it is possible due to vibration transfer of molecules but how it's possible from metal to air. Please explain at molecular level.
Science news on Phys.org
not so.
Can you refine your question or provide the source you found this?
PS: If you put a whole bunch of different things at room temperature in a cold refrigerator, do you think any will be colder than any other after sufficient time has passed? Some may get colder faster or slower due to conduction, convection [or radiation] but all will end up at the ambient temperature of the refrigerator, right?
alw34 said:
not so.
Okay I am taking about rate of flow of heat. And it's in time limit like we put chairs from indoor to outside for five minutes. That's what I talking about why metal gets cold faster with only contact with air.
Hi,
Conduction electrons...loosely bound electrons...same reason as some materials are insulators [wood] others are conductors [iron] of electricity...
those with loosely bound electrons can diffuse more quickly carrying either heat energy of electrical energy or both from atom to atom...
A few views:
Electrical conductivity of non-metals is determined by the susceptibility of electrons to excitation from the valence band to conduction band...https://en.wikipedia.org/wiki/Valence_and_conduction_bands
https://en.wikipedia.org/wiki/Heat_transfer#Conduction
[has a link to more details]
http://farside.ph.utexas.edu/teaching/sm1/lectures/node86.html
You are probably mistaking your perception of the metal chair being cold for the reality of what temperature it really is. Metal chairs both hold and transfer heat faster than wooden ones, which have a lot of air in them, which insulates them. So a metal one will transfer heat from you faster than a wooden one and because our perceptions of "cold" and "hot" are largely based on heat transfer rate, the metal chair will feel colder even if it is not.
Likes CWatters and PietKuip
alw34 said:
Hi,
A few views:
I know about general conduction but I am talking of process of transfer of heat from metal to air. How it happens at molecular level or it's just not conduction and is radiation.
The heat transfer from <something> to air is effected through convection and radiation. However, the internal transfer of heat through a metal chair is largely due to conduction, which is much faster. Therefore, a metal chair is going to be cold all the way through faster than a wooden chair (since wood is a very bad heat conductor).
When you are thinking about heat exchange due to radiation, you are thinking about significant temperature differences. In other words, any substance has to be pretty hot to lose much heat energy via radiation...an incandescent light bulb for example is pretty hot, 2,000 or more Kelvin I think. Since it's encased in a vacuum, virtually all the heat loss is radiation...and something like 97 or 98% of the power is dissipated that way. The largely infrared radiation heats the bulb of course, so it loses heat via conduction as air passes.
See the chart here and the explanation beneath:
https://en.wikipedia.org/wiki/Thermal_radiation
Everything in universe radiates heat except those with temperature of 0kelvin.
Yes, but if you have two objects (say A and B), then A radiates heat to B and B radiates heat to A. If they have the same temperature, the heat radiated equals the heat received; there is no net heat transfer between A and B. If the temperatures are "close" the net heat transfer is "negligible."
Metal to air heat transfer is, as said above, by convection. If there is a wind, the air molecules adjacent to the metal are constantly being replenished, and thus carry heat from the warm metal. If there is no wind, the heated air expands and rises, creating its own wind so to speak.
For normally experienced situations (like chairs on the patio) the convection is more significant than the radiation term.
Related to Conduction of heat from metal to air
What is conduction of heat?
Conduction of heat is the transfer of thermal energy between two objects or substances that are in direct contact with each other, typically from a hotter object to a colder one.
How does heat transfer occur from metal to air?
In metals, heat is transferred through conduction as the molecules of the metal vibrate and pass on their energy to neighboring molecules. This energy is then transferred to the air molecules through collisions, causing them to vibrate and increase in temperature.
What factors affect the rate of heat transfer from metal to air?
The rate of heat transfer from metal to air is affected by several factors such as the temperature difference between the two substances, the surface area of the metal, the type of metal, and the thickness of the metal. The presence of any insulating materials can also affect the rate of heat transfer.
Why do metals conduct heat better than other materials?
Metals conduct heat better than other materials because they have free electrons that are able to move and transfer thermal energy. These free electrons also explain why metals are good conductors of electricity.
Can the conduction of heat from metal to air be stopped?
While it is not possible to completely stop the conduction of heat from metal to air, it can be reduced by using insulating materials such as foam or fiberglass. These materials can trap air pockets, which act as barriers to slow down the transfer of heat.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
