Conductor that can completely surround another conductor?
  • Thread starter merrypark3
  • Tags
    Conductor
In summary, the capacitance of any conductor is always smaller than or equal to the capacitance of a conductor which can completely surround it.
merrypark3
30
"demonstrate that the capacitance of any conductor is always smaller than or equal to the capacitance of a conductor which can completely surround it"
Multipole expansion?
Tried to compare each terms of pole-moments of the distribution...
Usually, capacitance is defined in terms of two conductors, one with charge +Q and the other with charge -Q. The capacitance then is the ratio Q/ΔV, where ΔV is the potential difference between the two conductors. I assume that by the "capacitance of a conductor" is meant one of the conductors is at infinity. So look at two conductors, one larger than the other, bearing the same charge Q and compare the ratio Q/ΔV, where ΔV is the potential difference between a given conductor and infinity.
I think the capacitance in this problem is defined in terms of one conductor.
If a conductor of spherical shell of radius R is charged with Q, then the potential is Q/R so the capacitance is R.
So If we limit the case to a concentric spherical shell, then obviously the small one has small capacitance. But for any shape of conductor? How can I demonstrate? I've tried with mutipole expansion, but ,...
Please help me
I will help you, but you have to read and understand what I post. Imagine an irregular conductor, call it A, that has charge Q on it. It is an equipotential, but there is potential difference ΔVA between it and infinity. Its capacitance is CA = Q/ΔVA. Now imagine a second conductor, B, that can completely surround conductor A if called upon to do so. Put the same amount of charge Q on conductor B. It too is an equipotential and its capacitance will be CB = Q/ΔVB. If you can demonstrate that ΔVB is less than ΔVA, then you have answered the question.
Yes, that's right. But, How can I demonstrate that ΔVB is less than ΔVA..
What happens to the potential on conductor B in the limit that its size becomes infinitely large?
zero. I have thought about that. But considering only that case is not enough?
No it is not. What will happen if you bring the boundaries of the huge conductor closer in from infinity. Will its potential rise or fall? What if after that you brought the boundaries in even closer?
the more closer the potential increases. but that process preserves the shape..
I don't know what you mean by this or why it is relevant. You have enough information (and help) to answer the question. Just put it together.
FAQ: Conductor that can completely surround another conductor?
What is a "conductor that can completely surround another conductor"?
A "conductor that can completely surround another conductor" refers to a type of conductor that completely encloses or surrounds another conductor, creating a closed path for electrical current to flow through.
What are some examples of conductors that can completely surround another conductor?
Examples of conductors that can completely surround another conductor include coaxial cables, concentric cables, and waveguides.
How does a conductor that can completely surround another conductor work?
A conductor that can completely surround another conductor works by creating a closed loop for electrical current to flow through. This helps to reduce interference and improve the efficiency of the electrical system.
What are the benefits of using a conductor that can completely surround another conductor?
The main benefit of using a conductor that can completely surround another conductor is that it helps to reduce electromagnetic interference. This can improve the performance and reliability of electrical systems, especially in high-frequency applications.
Are there any limitations or drawbacks to using a conductor that can completely surround another conductor?
One limitation of using a conductor that can completely surround another conductor is that it can be more expensive and difficult to manufacture compared to other types of conductors. Additionally, it may not be suitable for all types of electrical systems.
