B Conductors in the triboelectric series
  • B
  • Thread starter Thread starter KV789
    Conductors Series
In teaching electricity, it's important to clarify the behavior of conductors like copper in the context of the triboelectric series. While copper is a good conductor with loosely held outer electrons, it can become negatively charged when rubbed against insulators like wool or glass. This occurs because the insulators have a stronger affinity for electrons, effectively stripping them from the copper and creating a local positive charge on the metal's surface. The process highlights the balance between electron affinity and conductivity, illustrating that conductors can still lose electrons under certain conditions. Understanding this interaction is key to explaining the nuances of static electricity in educational settings.
KV789
I teach electricity in grade 9. For the concept of conductors, they are described in the textbook as atoms where the outer electrons can easily move from one atom to another (e.g. copper). But I noticed that on the triboelectric series, copper and other metals are listed as having a strong(er) hold on electrons when charged by friction with something like wool or glass (which are considered electric insulators). I guess my question is how do I explain why copper becomes negative when rubbed with insulators like wool/silk/glass if copper also has a weaker hold on its outer electrons as a conductor?
Any insight would be appreciated! Thanks!
Welcome to PF.
That is a really good question, and I also want to know the answer.
Maybe electrons are being wiped from the insulator because they prefer the more positive copper where the surface has been swept clear of some electrons, inducing a local positive charge at the point of contact.
I think this is all about the "wool/silk/glass" and how much it wants to grab an extra electron. Metals can easily give up their conduction band electrons to a receptor. If so, it will then be harder to remove additional electrons from the metal because of the charge imbalance.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
