Configuring WiFi router with PPPoE and static IP
The discussion centers on configuring a Wi-Fi router with a broadband connection that uses a static IP and PPPoE settings provided by the ISP. The user seeks clarification on whether they can input both a static IP and the PPPoE username and password on the router. It is noted that the static IP setting is typically for direct TCP/IP connections, while the router should automatically detect PPPoE and prompt for the necessary credentials. Additionally, there is a recommendation to consider a slightly more expensive router that offers better performance, specifically highlighting the advantages of supporting higher speeds and the 5 GHz band for future-proofing. The conversation emphasizes the importance of consulting local resources for specific ISP-related issues.
Wrichik Basu
Insights Author
Before I start, I must say that I haven't yet bought the Wi-Fi router.
We have a broadband connection (no modem, just an RJ45 cable directly into the PC). I want to buy this Wi-Fi router and use the broadband connection to power it. Our ISP provides us a static IP, as well as a username and a password (PPPoE I guess?). I have seen many videos online that show how to configure a static IP, or PPPoE for the router. But can I specify a static IP along with the username and password?
Computer science news on Phys.org
Why use videos, you can download the manual from that Amazon page or you can always find them on the TP-Link site?
Anyway the 'static IP' selection in the menu is for a direct connection into a TCP/IP network: such a connection does not have the concept of a username and password. The modem should 'auto-detect' PPPoE and then it will take you to a screen of settings where you can enter your username and password.
If you have any problems you would be better off asking locally, I don't think there is anyone regularly posting on PF that has experience with ISPs where you are.
I don't know if you can stretch to https://www.amazon.in/dp/B0759QMF85/ - this is INR100 more on Amazon and is a much better router?
Likes Wrichik Basu
The one you linked supports up to 750 Mbps, and the one I bought supports 450 Mbps. Our Ethernet speed is 100 Mbps, so I believe both will give almost same performance.
It's more the support for the 5 GHz band and 802.11ac that makes it more future-proof that I was thinking of.
Likes Wrichik Basu
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
  • · Replies 24 ·
  • · Replies 43 ·
33K
