Confining Charged Particles with Alternating Electrostatic Fields
In summary: AMYep. I'm wondering about an electrostatic field though.In summary, the conversation discusses the possibility of using an alternating/rotating electrostatic method to confine charged particles, such as electrons inside a cube. One person suggests putting negative charge on all sides of the cube, but another argues that the force inside the cube would not be 0 like in a sphere. The conversation then shifts to discussing the concept of using a "magnetic bottle" to confine charged particles and the potential for using an electrostatic field instead.
Drakkith
Mentor
23,093
7,499
Is it possible to use an alternating/rotating electrostatic method to confine charged particles?
For example, if you want to confine electrons inside a cube, could you use a negative charge that is alternated between each side at a time, on a timescale of nanoseconds between each alternation?
Why not put negative charge on all sides of the cube?
AM
AM
From what i understand, it would be similar to a charged hollow sphere, and the combined charge all at once would cancel itself out inside the sphere. The closer a particle gets to a wall, the more of the sphere or cube is on the other side of it, which cancels out the field on the other side. At least, that's they way I understood from reading it somewhere.
That is correct - for a sphere. But a cube is not a sphere. The force inside a cube that has a uniform surface charge density is the superposition of the forces between three sets of uniformly charged plates positioned at right angles to each other. I would think that the force would be 0 only in the middle.
AM
AM
I think the corners would be the weak point in this. As a particle gets close to the corner, there is more and more of the cube on the other side of it, similar to what happens in a sphere. Does that sound correct?
There is a way to confine a charged particle by using a "magnetic bottle". I can't find any good online sources regarding it, but basically a compound magnetic field created by two coils can make charged particles with proper velocities simply spiral repeatedly from one end to the other.
FAQ: Confining Charged Particles with Alternating Electrostatic Fields
What is the purpose of confining charged particles?
The purpose of confining charged particles is to study and manipulate their behavior and interactions in a controlled environment. This allows scientists to better understand fundamental particles and their properties.
How are charged particles confined?
Charged particles can be confined using various methods, such as electromagnetic fields, electric potentials, or physical barriers. The specific method used depends on the type of particle and the desired outcome of the experiment.
What are the challenges of confining charged particles?
One of the main challenges of confining charged particles is preventing them from interacting with their surroundings, as this can affect their behavior and skew the results of the experiment. Another challenge is maintaining a stable confinement over time, as charged particles can be highly energetic and difficult to control.
What are the potential applications of confining charged particles?
Confining charged particles has many potential applications in fields such as particle physics, materials science, and medicine. It can help improve our understanding of subatomic particles, develop new materials with specific properties, and even aid in the development of new medical treatments.
Can charged particles be confined indefinitely?
Technically, charged particles can be confined indefinitely as long as the confinement method is maintained. However, due to the highly energetic nature of charged particles, it is difficult to maintain a stable confinement for an extended period of time. Eventually, the particles may escape or interact with their surroundings, leading to a breakdown of the confinement.
