Confused about charged rotating disk-Magnetism, reference frame
In summary, the conversation discusses the effects of a rotating charged disk on a magnetic field and the concept of inertial frames of reference. The participants discuss the idea of a reference frame being a point and explain that it is the entire space at a particular velocity. They also discuss the Mach principle and how to determine if a frame is inertial. The conversation ends with a question about the movement of charges under the influence of a moving magnetic field and a summary of the initial problem.
fluidistic
264
For some reason I've thought about the following case : A uniformly non conductor charged disk is rotating with an angular velocity [tex]\vec \omega[/tex].
If I see it in front of me I'd observe a magnetic field since moving charges produce a current which produce a magnetic field according to Ampere's Law. So if I hang a magnet over the rotating disk it would suffer some force because of the magnetic field created by the disk.
However if I chose, as a reference frame, the center of the disk, I'd see no current since no charge is moving. Hence no magnetic field and the magnet wouldn't be deflected at all while being closer and closer to the disk.
It doesn't seem possible so I'm guessing I'm misunderstanding something.
Can you explain what's happening?
Hi fluidistic! :smile:
fluidistic said:
… However if I chose, as a reference frame, the center of the disk, I'd see no current since no charge is moving. Hence no magnetic field …
No, a reference frame can't be a point, it's the whole of space at a particular velocity. :wink:
It seems I'm already confused about this, even before having started to learn about Relativity!
If I'm over the disk (say a 2 meters diameter), I would rotate with it, with respect to the Earth's ground. However I would not see/feel any magnetic field while immobile on it. All changes if I leave the disk and look at it from the ground.
oh, do you mean standing on the disc, and therefore rotating with it?
But that's a non-inertial frame, and so Maxwell's equations wouldn't apply (well, not without adding "fictional forces").
Thanks a lot. And a bit late : Hey tiny-tim (my hero!)
You just reminded me of Coriolis force on Earth although I never studied it.
I have some difficulties with inertial frames of reference and I guess I'm not the only one. For example, what if the Universe is made of the disk, a person in front of it, and me over the disk? Would I still be considered as a non inertial frame of reference?
You're confusing me :redface:
I'm going to bed! :zzz:​
:wink: nighty-night!
Good night! Sorry about that. :rolleyes:
Anyone's welcome to clear my doubt.
Whether or not you are inertial is determined by if you are experiencing any net forces, which you can measure with an accelerometer. What the rest of the universe is doing is not relevant.
fluidistic said:
… what if the Universe is made of the disk, a person in front of it, and me over the disk? Would I still be considered as a non inertial frame of reference?
(yawn :zzz: … just got up :redface: … must eat:-p)
hmm … you're talking about the http://en.wikipedia.org/wiki/Mach_Principle" , and so on …
how do we decide whether the disc (and you) are rotating, or (only! :wink:) the whole of the rest of the universe is rotating?
Would it make you happier if I say that in all moment of inertia exam questions, you can always assume Newtonian space-time and mechanics, and that an inertial observer is always non-accelerating and non-rotating? o:)
Perhaps I’ve not giving this problem enough thought, but when the disk is not rotating then the magnet must be moving. A moving magnetic field produces an electric field which in turn reacts with the charges on the disk.
Good to know. If I was on the center of the rotating disk with an accelerometer in my hands, would it feel some kind of acceleration? (The only acceleration I could guess is the centripetal one)
Good day. I wasn't aware of this information, nice.
About exams questions, I'd solve them as professors want, but this wouldn't limit my questions so that it doesn't really make me happy not to know well physics.
The disk is non conductor, so would the charges move under the electric field created by the moving magnet?
Anyway at time t=0 I could set the Universe like this : I'm over the disk which rotates with respect to an observer which isn't on the disk. I have a magnet in one hand, not moving with respect to me, hence also with respect to the disk. So I don't see any magnetic field due to the rotating disk, unlike the observer outside the disk which sees one and should see the magnet influenced by the magnetic field of the rotating disk. While I wouldn't see any interaction between the magnet and the disk.
I'd love to do the experiment to see what happens. Now where do I get a charged big rotating disk? :rolleyes:
Yes, but I guess I should have been more clear. I was talking about the 6 degree of freedom kind of accelerometers, the kind that can detect 3 directions of linear acceleration and 3 directions of rotation (often called inertial measurement unit).
Recall that the centripetal acceleration is proportional to the radius, so if you were at the center that would be zero, however if you were co-rotating with the disk then that would be measured on one of the gyroscope channels. If you were attached to the edge of the disk then you would measure both the centripetal acceleration and the rotation.
Ah ok! If I understood well this would imply that I'm not in an inertial reference frame so the magnet will indeed be deflected by the magnetic field of the rotating disk. To explain it from my point of view I'd have to use a fictitious force, like in the case of when I'm sat in a car when turning (I'd be pushed on a side, and I'd have to use the centrifugal force).
That's what tiny-tim' second post mention.
Thank you all! Very much.
There’s always some ohmic electrical resistance and some small scale stuff going on but ignoring that there will be an electric force but no movement of charges. This force will be either towards or away from the centre.
The observer outside the disk sees 2 magnetic and 2 electric fields.
He will find that the extra forces between the magnetic fields cancel out against the extra forces of the electric fields.
The maths behind this is somehow too complicated for a Sunday (or Monday).
I think the hardest part will be to detect a magnetic field at all of such a disk. Remember that normally magnetic field are generated by the movement of enormous amounts of electrons. When there’s only a fraction of a fraction of that charge on your disk I would not like to approach it and/or go and sit on it.:biggrin:
FAQ: Confused about charged rotating disk-Magnetism, reference frame
How does a charged rotating disk create a magnetic field?
The rotation of the disk causes the charged particles to move, creating a current. This current produces a magnetic field around the disk.
What is the effect of a reference frame on the magnetic field of a rotating disk?
The magnetic field of a rotating disk is affected by the reference frame in which it is observed. In the reference frame of the disk, the magnetic field is stationary and has a certain strength. However, in a different reference frame, the magnetic field may appear to be moving and have a different strength.
How does the direction of rotation of a disk affect its magnetic field?
The direction of rotation of a disk determines the direction of the current and thus the direction of the magnetic field it produces. If the disk rotates clockwise, the magnetic field will be in one direction, and if it rotates counterclockwise, the magnetic field will be in the opposite direction.
Can the strength of the magnetic field of a rotating disk be changed?
Yes, the strength of the magnetic field of a rotating disk can be changed by altering the speed of rotation, the charge on the disk, or the number of charged particles on the disk.
How does the magnetic field of a rotating disk interact with other magnetic fields?
The magnetic field of a rotating disk can interact with other magnetic fields in a variety of ways. If the other magnetic field is in the same direction as the disk's magnetic field, they will reinforce each other. If the other magnetic field is in the opposite direction, they will cancel each other out. In a perpendicular direction, they will interact in a more complex manner, depending on the strengths and orientations of the two fields.
26K
