Confused about Continuous Endpoints: -1 < a < 1?
  • Thread starter Thread starter member 731016
    Confused Continuous
member 731016
Please see below
Please see below
For this problem,
I don't understand why they are saying ##-1 < a < 1## since they are trying to find where ##f(x)## is continuous including the endpoints ##f(-1)## and ##f(1)##
Why is it not: ##-1 ≤ a ≤1##
Many thanks!
Callumnc1 said:
Homework Statement:: Please see below
Relevant Equations:: Please see below
For this problem,
Many thanks!
Because they forgot about the endpoints.
Likes Mark44 and member 731016
Thank you for your reply @PeroK!
They should have done one-sided limits at the end points, in addition to two sided limits at the interior points. As any good maths student will tell you!
Likes member 731016
The part of the proof that you show matches the first line: "If ##-1 \lt x \lt 1##". Is there another part of the proof that you have not shown? If not, then they just made a mistake and left it out.
Likes member 731016
Thank for your replies @PeroK and @FactChecker !
There was a couple of lines that I did not screen shot,
However, did they really need those lines if they had just said ##-1 ≤ a ≤1##?
Many thanks!
The theorems and laws that are referenced in the first part are probably stated only for two-sided limits, so it would not be valid to include the endpoints that are one-sided limits. By separating the endpoints, they can use the phrase "similar calculations" and infer similar one-sided theorems and laws.
Likes PeroK and member 731016
Many thanks!
So, they didn't forget about the endpoints after all!
Likes member 731016
Thank you for your replies @FactChecker and @PeroK!
I think I'm starting to understand. So basically, you can't take the limits of the end points, so you just take the right- and left-hand limits to prove it is continuous.
However, I though you could not do that since the text also states that in order for a function to be continuous at a number a:
However, for the end points they only took the right hand or left hand limit for reach end point. How dose that me it is continuous at ## x = -1, 1## (since the limits at each of those end points DNE)?
For example, for ##x = 1## You cannot take the right-hand limit since there is no graph there (so left-hand limit dose not equal right-hand limit, so limit DNE).
I think this could be something to do with Definition 3.
Many thanks!
