Confused about enthelpy change in ideal gas
In summary, the state of an ideal gas changed under constant external pressure from 0.3atm and 500K to 2.2atm and 330K. The task is to calculate ΔE, work (w), heat (Q), ΔH, and ΔS. Using relevant equations, the energy change and work were calculated, but there was confusion regarding the enthalpy change. It was initially thought that in a constant pressure process, the enthalpy change would be equal to the heat, but this is not always the case. In this scenario, the system pressure is not constant, so the enthalpy change cannot be equal to the heat. ΔH can be calculated by using Δ(pV)
susdu
24
The state of 3.75mol ideal gas changed from 0.3atm and 500K to 2.2atm and 330K under constant external pressure (Pex = 2.2atm).
Calculate ΔE, work (w) and heat(Q), ΔH, ΔS.
w= -∫PexdV
ΔE=1.5nRΔT=w+Q
ΔH=ΔE+Δ(PV)
ΔS=dQrev/T
I recently started a thermodynamics course and this question seems entry-level but I'm still unable to grasp some fundamental concepts. Calculating the energy change, work and heat was pretty straight forward: I used the appropriate equations to find energy change and work and then used the first law to find the heat.
Problem is when I was asked about the enthalpy change, I thought "ok, this is a constant pressure process, so the enthalpy change is equal to the heat". But apparently this is not the case.
What am I missing?
It's not a constant pressure process. The pressure of the surroundings is constant, but the system pressure is not constant. You already calculated ΔE, and presumably you can calculate the initial and final volumes, so you can get Δ(pV). This will give you ΔH. You can also get ΔH another way, by using nCpΔT, and remembering that Cp=Cv+R for an ideal gas. This should, of course, give you the same answer.
So trivial, should have noticed that. Thank you.
Can you give an example of a constant pressure process where the enthalpy change equals the heat?
(I can't seem to distinguish between the given scenarios)
Hello! It's great that you are taking a thermodynamics course and trying to understand the concepts. Let's break down the problem and try to understand it better.
Firstly, the state of the ideal gas has changed from 0.3atm and 500K to 2.2atm and 330K. This means that the temperature and pressure have both decreased. This also means that the volume of the gas has decreased, as seen from the ideal gas law (PV=nRT).
Now, let's look at the equations you have provided. The work done by the gas is given by the equation w=-∫PexdV, which is the area under the curve on a P-V graph. In this case, since the external pressure is constant, the work done is simply the change in volume multiplied by the external pressure (w=PexΔV).
Next, the change in energy (ΔE) can be calculated using the first law of thermodynamics, which states that ΔE = Q + W. In this case, since the work done is negative (gas is doing work on the surroundings), the change in energy is negative as well, indicating a decrease in energy.
Now, for the enthalpy change (ΔH), we need to consider the fact that enthalpy (H) is defined as H = E + PV. Since the pressure and volume have both decreased, the enthalpy change will not be equal to the heat (Q). This is because the heat only takes into account the change in internal energy, while enthalpy also includes the work done by the gas.
To calculate the change in entropy (ΔS), we can use the equation ΔS = dQrev/T. Since the process is reversible, we can assume that the heat transfer (Q) is equal to the change in internal energy (ΔE) and use that value to calculate ΔS.
I hope this explanation helps you understand the concept of enthalpy change in a constant pressure process. Keep practicing and asking questions to deepen your understanding of thermodynamics. Good luck!
FAQ: Confused about enthelpy change in ideal gas
What is enthalpy change in an ideal gas?
Enthalpy change in an ideal gas refers to the amount of heat that is exchanged between the gas and its surroundings during a process, such as a chemical reaction or a change in temperature or pressure. It is also known as heat change or heat of reaction.
How is enthalpy change calculated in an ideal gas?
Enthalpy change in an ideal gas is calculated using the equation ΔH = q + PΔV, where ΔH is the change in enthalpy, q is the heat exchanged, P is the pressure, and ΔV is the change in volume. This equation is based on the first law of thermodynamics, which states that energy cannot be created or destroyed, only transferred.
What is the significance of enthalpy change in an ideal gas?
Enthalpy change in an ideal gas is significant because it allows us to understand and predict the energy changes that occur during a process. It is particularly useful in studying chemical reactions, as it helps determine the amount of heat that is released or absorbed during the reaction.
How does enthalpy change in an ideal gas relate to internal energy?
Enthalpy change in an ideal gas is closely related to internal energy, which is the total energy of a system. The change in enthalpy is equal to the change in internal energy plus the work done by the system. This relationship is expressed in the equation ΔH = ΔU + PΔV.
Can enthalpy change in an ideal gas be negative?
Yes, enthalpy change in an ideal gas can be negative. A negative enthalpy change indicates that heat is being released from the system to its surroundings, while a positive enthalpy change indicates that heat is being absorbed by the system. This can occur during exothermic and endothermic reactions, respectively.
