Confused about equation solving
  • B
  • Thread starter JesseK
  • Tags
    Confused
In summary: The equation should be multiplied by ½, but in order to solve for v1, you need to take a square root. That factor "2" before gh (bold text) is just telling you to take the square root of √(v02 - 2gh1).
JesseK
Hey!
I'm confused about this:
½v21 = ½v20 - gh1
v21 = v20 - 2gh1
v1 = √v02 - 2gh1
Soo, what basically happened here when solving the equation for v1? I understand that the equation should be multiplied by ½ and then take a square root in order to solve for v1, but what's that factor "2" before gh (bold text). Where did that come from?
Thank you!
No, you are multiplying by 2. Does that answer your question?
As @Ibix says, multiply both sides of the equation by 2 (so the equal sign still holds -- always do the same operation on both sides of the equation when simplifying it):
[tex]2(\frac{1}{2}v_1^2) = 2(\frac{1}{2}v_0^2 - gh_1)[/tex]
Likes JesseK
JesseK said:
1/2 * 1/2 = 1
What? If I have an apple and I cut it in half, and cut one if the halves in half, you expect the half of a half to be a whole apple?
Yeah, it was my bad, sorry. Obviously 1/2 * 1/2 = 1/4 haha :D
Oh, so every term on both sides of the equation should be multiplied by 2 (those brackets)? Now, I gotcha, thank youu! :D
Likes berkeman
JesseK said:
Hey!
½v21 = ½v20 - gh1
v21 = v20 - 2gh1
v1 = √v02 - 2gh1
The line above confused me, at first, since it looks like you're taking the square root only of the ##v_0^2## term. You really should be using parentheses, like this: v1 = √(v02 - 2gh1)
Also, mathematically speaking, there will be two solutions for ##v_1##:
v1 = ±√(v02 - 2gh1)
Thank you!
FAQ: Confused about equation solving
What is equation solving?
Equation solving is the process of finding the values of unknown variables in an equation. It involves manipulating the given equation using mathematical operations to isolate the variable and solve for its value.
Why is equation solving important?
Equation solving is important in various fields of science, engineering, and mathematics. It allows us to find solutions to real-world problems and make predictions based on mathematical models. It also helps us understand the relationships between different variables in a system.
What are the basic steps in solving an equation?
The basic steps in solving an equation are: 1) Simplify both sides of the equation by combining like terms, 2) Isolate the variable by performing inverse operations, 3) Check the solution by plugging it back into the original equation, and 4) If the solution is not correct, repeat the steps until the correct solution is found.
What are some common mistakes in equation solving?
Some common mistakes in equation solving include: 1) Forgetting to perform the same operation on both sides of the equation, 2) Making a sign error while performing inverse operations, 3) Not distributing a negative sign correctly, and 4) Not checking the solution before considering it final.
How can I improve my equation solving skills?
To improve your equation solving skills, you can practice solving different types of equations, understand the properties of numbers and operations, and familiarize yourself with common mistakes to avoid them. You can also seek help from a tutor or use online resources to learn more about specific techniques and strategies for solving equations.
